LUA different command to same deivce in commandArray
daveinhull
Domoticz version: V2.2657
Post by daveinhull »
Can anyone tell me if it is possible to send two different commands to the same device in LUA's commandArray?
This sounds like a silly question, but the reason is that I'd like to put a light to 100% and then switch it off so that the next time it is switch on at the wall it comes on full brightness. I have a mood switch upstairs that puts the hall and landing lights on very dim for night. However I only have a regular switch downstairs which means I have to hold the button down to get it on full. So the sequence would be:
Turn mood on upstairs at night
When dusk sensor goes off
Turn hall and landing lights on 100% and then switch them off
Then when downstairs switch is used they them on normal brightness
I've tried
    commandArray[1]={['Hall Ceiling'] = 'Set Level 100'}
    commandArray[2]={['Landing Ceiling'] = 'Set Level 100'}
    commandArray[3]={['Hall Ceiling'] = 'Off'}
    commandArray[4]={['Landing Ceiling'] = 'Off'}
But it only seems to do the last command for the device, i.e. off, so pressing the downstairs switch only brings then on dim.
Any thoughts?
Dave
Domoticz running on Windows 10 x64 Shuttle PC
RFComm, 9wall dimmers, 4dual sockets, 3x3way relays, 1x1way relay, 4PIRs, 2magnetic switches, 1radiator valve, WiFi link, coiler switch and controller, compatible security system, & lots of patience
daveinhull
Re: LUA different command to same deivce in commandArray
Anyone got any ideas how to do this or even if it is possible?
jvdz
Domoticz version: 4.107
Post by jvdz »
Only thing I can think of is to do the second command one or a couple of seconds later:
commandArray[3]={['Hall Ceiling'] = 'Off AFTER 3'}
commandArray[4]={['Landing Ceiling'] = 'Off AFTER 3'}
Jos
daveinhull
Thanks Jos, had a feeling in night be something to do with timings. Will give it a try.
