RFLink & WH5029 weather station
Posted: Monday 02 January 2017 8:53
by eSumo
Hello.
Anyone here uses WH5029 + RFLink + Domoticz?
Wind speed is in my opinion wrong.
Speed is always 0, gusts are small (1-8km/hod) ...
Other values are fine.
Re: RFLink & WH5029 weather station
Posted: Monday 02 January 2017 15:56
by mrccore
Hi.
Do you have the wind sensor in the correct postion to North? I don't have this meteo station you have i have an alecto ws-3500 and in the first day i had to do some ajusts to have the readings correctly... almost correctly....
But in my case my domoticz it's not giving me the reads off the wind from South.
you can see my posts over here http://www.domoticz.com/forum/viewtopic ... 49&t=15066 also i found out that when i was using the beta releases my data was not correct. Are you using the beta or stable release?
Posted: Tuesday 03 January 2017 13:59
by eSumo
Hi.
Yes - my position is corect... My problem is elsewhere. about...
Probably is not WH5029 as WH5029. ;)
...and my configuration is in the signature...
