Z-Wave factfile and repair: Everspring AN145 AKA Eminent EM6555
Posted: Friday 30 December 2016 12:25
by Domosapiens
Supplier:
Everspring
Website:
http://www.everspring.com/Products/Home ... AN145.aspx
Function:
E27 Screw-in On/Off Module and transceiver
Z-Wave+ AKA GEN5
No
Rebranding:
Eminent EM6555
Device Library from http://www.pepper1.net
http://www.pepper1.net/zwavedb/device/57
Manual
https://cdn.shopify.com/s/files/1/0218/ ... 2014405727
Domoticz experience
Hardware:
Bulky E27 plug module with local switch.
Remarks:
No polling needed. No security.
Configuration:
Reports itself as AN157 (is wrong, seems to be a FW error).
No configuration options
Devices
Only a switch
zwcfg_0xaaaaaaa.xml sample:
All type of useless AN157 stuff
Conclusion
Overpriced and bulky.
But if you can buy them for 12€ or so: take them apart and use the electronics for build-in purposes while improving your mesh-network.
Like shown here: https://www.domoticaforum.eu/viewtopic.php?f=50&t=10978
Repair
If the switch, when switched On, goes On/Off all the time, and the relay is clicking:
Replace the yellow capacitor, used in the 230V power circuit, it is outside it's tolerance.
F.i. from here:
https://nl.aliexpress.com/item/0-47uF-9 ... yId=141908
Please report if you have this error too (to gather reliability info).
Thanks.
Re: Z-Wave factfile and repair: Everspring AN145 AKA Eminent EM6555
Posted: Thursday 07 May 2020 23:33
by PeBe
Big thanks for the tip. I had exactly the same issue with two of my AN157s. They went crazy one day after each other. I had them for 5 years and worked flawless. I found the capacitor degraded as it measured only 250nF. Replaced it with a new X2 capacitor of 470nF and the problem was gone.
Waiting for the 3rd (I have thee) to go ;-)
Cheers,
Peter
Posted: Friday 07 April 2023 0:27
by PeBe
And today the third one went. Same problem.
Cheers,
Peter
Posted: Sunday 01 October 2023 22:00
by PeBe
And today the 220uF/35V elco went bad. So another replacement . . .
Gosh they really use bad quality components.
Cheers,
Peter
