Run a PHP script from a Virtual Switch
jonohunt
Post by jonohunt »
Version: 3.5877
Platform: Raspberry Pi 3
I found some scripts here (scroll down to #PHP-FINDMYIPHONE) and here to activate Find My iPhone via openHAB, and am trying to use them through Domoticz, activated via a Virtual Switch.
This script works fine when run from an editor on my Mac (with my account details filled in)
<?PHP
	// This will prevent any errors that occur from potentially displaying your username/password
	error_reporting(0);
	// This should properly display device names that contain special characters
	header("Content-type: text/html; charset=utf-8");
	// Include the FindMyiPhone class
	include ("class.findmyiphone.php");
	// This is where we log in to iCloud
	try {
		$fmi = new FindMyiPhone("<username>", "<password>");
	} catch (Exception $e) {
		print "Error: ".$e->getMessage();
		exit;
	// This will print out all the devices on your account so you can grab the device IDs
    //$fmi->printDevices();
	$fmi->playSound("<DEVICEID>", "Alexa Found You!");
Alongside this one
<?PHP
 Copyright (C) Alan Beebe ([email protected]).
 Licensed under the Apache License, Version 2.0 (the "License");
 you may not use this file except in compliance with the License.
 You may obtain a copy of the License at
 http://www.apache.org/licenses/LICENSE-2.0
 Unless required by applicable law or agreed to in writing, software
 distributed under the License is distributed on an "AS IS" BASIS,
 WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 See the License for the specific language governing permissions and
 limitations under the License.
  v1.0 - January 2, 2015
class FindMyiPhone {
	private $client = array(
						"app-version" => "4.0",
						"user-agent" => "FindMyiPhone/472.1 CFNetwork/711.1.12 Darwin/14.0.0",
						"headers" => array(
							"X-Apple-Realm-Support" => "1.0",
							"X-Apple-Find-API-Ver" => "3.0",
							"X-Apple-AuthScheme" => "UserIdGuest"
	private $debug;
	private $username;
	private $password;
	private $Apple_MMe_Host;
	private $Apple_MMe_Scope;
	public $devices = array();
     * This is where you initialize FindMyiPhone with your iCloud credentials
     * Example: $fmi = new FindMyiPhone("[email protected]", "MyPassWord123");
     * @param username	iCloud username
     * @param password	iCloud password
     * @param debug		(Optional) Set to TRUE and all the API requests and responses will be printed out
     * @return          FindMyiPhone instance
	public function __construct($username, $password, $debug = false) {
		$this->username = $username;
		$this->password = $password;
		$this->debug = $debug;
		$this->authenticate();
     * This method attempts to get the most current location of a device
     * Example: $fmi->locate("dCsaBcqBOdnNop4wvy2VfIk8+HlQ/DRuqrmiwpsLdLTuiCORQDJ9eHYVQSUzmWV", 30);
     * @param deviceID	ID of the device you want to locate
     * @param timeout	(Optional) Maximum number of seconds to spend trying to locate the device
     * @return          FindMyiPhoneLocation object
	public function locate($deviceID, $timeout = 60) {
		$startTime = time();
		$initialTimestamp = $this->devices[$deviceID]->location->timestamp;
		while ($initialTimestamp == $this->devices[$deviceID]->location->timestamp) {
			if ((time() - $startTime) > $timeout) break;
			$this->refreshDevices($deviceID);
			sleep(5);
		return $this->devices[$deviceID]->location;
     * Play a sound and display a message on a device
     * Example: $fmi->playSound("dCsaBcqBOdnNop4wvy2VfIk8+HlQ/DRuqrmiwpsLdLTuiCORQDJ9eHYVQSUzmWV", "Whats up?");
     * @param deviceID	ID of the device you want to play a sound
     * @param message	Message you want displayed on the device
	public function playSound($deviceID, $message) {
		$url = "https://".$this->Apple_MMe_Host."/fmipservice/device/".$this->Apple_MMe_Scope."/playSound";
		$body = json_encode(array("device"=>$deviceID, "subject"=>$message));
		list($headers, $body) = $this->curlPOST($url, $body, $this->username.":".$this->password);
     * Put a device into lost mode. The device will immediately lock until the user enters the correct passcode
     * Example: $fmi->lostMode("dCsaBcqBOdnNop4wvy2VfIk8+HlQ/DRuqrmiwpsLdLTuiCORQDJ9eHYVQSUzmWV", "You got locked out", "555-555-5555");
     * @param deviceID		ID of the device you want to lock
     * @param phoneNumber	(Optional) Phone number you want displayed on the lock screen
	public function lostMode($deviceID, $message, $phoneNumber = "") {
		$url = "https://".$this->Apple_MMe_Host."/fmipservice/device/".$this->Apple_MMe_Scope."/lostDevice";
		$body = json_encode(array("device"=>$deviceID, "ownerNbr"=>$phoneNumber, "text"=>$message, "lostModeEnabled"=>true));
     * Print all the available information for every device on the users account.
     * This is really useful when you want to get the ID for a device.
     * Example: $fmi->printDevices();
	public function printDevices() {
		if (sizeof($this->devices) == 0) $this->getDevices();
		print <<<TABLEHEADER
        		<PRE>
        		<TABLE BORDER="1" CELLPADDING="3">
        			<TR>
        				<TD VALIGN="top"><B>ID</B></TD>
        				<TD VALIGN="top"><B>name</B></TD>
        				<TD VALIGN="top"><B>displayName</B></TD>
        				<TD VALIGN="top"><B>location</B></TD>
        				<TD VALIGN="top"><B>class</B></TD>
        				<TD VALIGN="top"><B>model</B></TD>
        				<TD VALIGN="top"><B>modelDisplayName</B></TD>
        				<TD VALIGN="top"><B>batteryLevel</B></TD>
        				<TD VALIGN="top"><B>batteryStatus</B></TD>
        			</TR>
TABLEHEADER;
		foreach ($this->devices as $device) {
			$location = <<<LOCATION
			<TABLE BORDER="1">
				<TR>
					<TD VALIGN="top">timestamp</TD>
					<TD VALIGN="top">{$device->location->timestamp}</TD>
				</TR>
				<TR>
					<TD VALIGN="top">horizontalAccuracy</TD>
					<TD VALIGN="top">{$device->location->horizontalAccuracy}</TD>
				</TR>
				<TR>
					<TD VALIGN="top">positionType</TD>
					<TD VALIGN="top">{$device->location->positionType}</TD>
				</TR>
				<TR>
					<TD VALIGN="top">longitude</TD>
					<TD VALIGN="top">{$device->location->longitude}</TD>
				</TR>
				<TR>
					<TD VALIGN="top">latitude</TD>
					<TD VALIGN="top">{$device->location->latitude}</TD>
				</TR>
			</TABLE>
LOCATION;
			print <<<DEVICE
					<TR>
        				<TD VALIGN="top">{$device->ID}</TD>
        				<TD VALIGN="top">{$device->name}</TD>
        				<TD VALIGN="top">{$device->displayName}</TD>
        				<TD VALIGN="top">$location</TD>
        				<TD VALIGN="top">{$device->class}</TD>
        				<TD VALIGN="top">{$device->model}</TD>
        				<TD VALIGN="top">{$device->modelDisplayName}</TD>
        				<TD VALIGN="top">{$device->batteryLevel}</TD>
        				<TD VALIGN="top">{$device->batteryStatus}</TD>
        			</TR>
DEVICE;
		print <<<TABLEFOOTER
        		</TABLE>
        		</PRE>
TABLEFOOTER;
	 *  This is where the users credentials are authenticated.
	 *  The Apple_MMe_Host and Apple_MMe_Scope values are saved and used to generate the URL for all subsequent API calls
	private function authenticate() {
		$url = "https://fmipmobile.icloud.com/fmipservice/device/".$this->username."/initClient";
		list($headers, $body) = $this->curlPOST($url, "", $this->username.":".$this->password);
		$this->Apple_MMe_Host = $headers["X-Apple-MMe-Host"];
		$this->Apple_MMe_Scope = $headers["X-Apple-MMe-Scope"];
		if ($headers["http_code"] == 401) {
			throw new Exception('Your iCloud username and/or password are invalid');
     * This is where all the devices are downloaded and processed
     * Example: print_r($fmi->devices)
	private function getDevices() {
		$url = "https://".$this->Apple_MMe_Host."/fmipservice/device/".$this->Apple_MMe_Scope."/initClient";
		$this->devices = array();
		for ($x = 0; $x < sizeof($body["content"]); $x++) {
			$device = $this->generateDevice($body["content"][$x]);
			$this->devices[$device->ID] = $device;
	 * This method takes the raw device details from the API and converts it to a FindMyiPhoneDevice object
	private function generateDevice($deviceDetails) {
		$device = new FindMyiPhoneDevice();
		$device->API = $deviceDetails;
		$device->ID = $device->API["id"];
		$device->batteryLevel = $device->API["batteryLevel"];
		$device->batteryStatus = $device->API["batteryStatus"];
		$device->class = $device->API["deviceClass"];
		$device->displayName = $device->API["deviceDisplayName"];
		$device->location = new FindMyiPhoneLocation();
		$device->location->timestamp = $device->API["location"]["timeStamp"];
		$device->location->horizontalAccuracy = $device->API["location"]["horizontalAccuracy"];
		$device->location->positionType = $device->API["location"]["positionType"];
		$device->location->longitude = $device->API["location"]["longitude"];
		$device->location->latitude = $device->API["location"]["latitude"];
		$device->model = $device->API["rawDeviceModel"];
		$device->modelDisplayName = $device->API["modelDisplayName"];
		$device->name = $device->API["name"];
		return $device;
	 * This method refreshes the list of devices on the users iCloud account
	private function refreshDevices($deviceID = "") {
		$url = "https://".$this->Apple_MMe_Host."/fmipservice/device/".$this->Apple_MMe_Scope."/refreshClient";
		if (strlen($deviceID) > 0) {
			$body = json_encode(array("clientContext"=>array("appVersion"=>$this->client["app-version"], "shouldLocate"=>true, "selectedDevice"=>$deviceID, "fmly"=>true)));
	 * Helper method for making POST requests
	private function curlPOST($url, $body, $authentication = "") {
		$ch = curl_init($url);
		curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "POST");
		curl_setopt($ch, CURLOPT_POSTFIELDS, $body);
		curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
		curl_setopt($ch, CURLOPT_VERBOSE, 1);
		curl_setopt($ch, CURLOPT_HEADER, 1);
		curl_setopt($ch, CURLOPT_USERAGENT, $this->client["user-agent"]);
		if (strlen($authentication) > 0) {
			curl_setopt($ch, CURLOPT_USERPWD, $authentication);
		$arrHeaders = array();
		$arrHeaders["Content-Length"] = strlen($request);
		foreach ($this->client["headers"] as $key=>$value) {
			array_push($arrHeaders, $key.": ".$value);
		curl_setopt($ch, CURLOPT_HTTPHEADER, $arrHeaders);
		$response = curl_exec($ch);
		$info = curl_getinfo($ch);
		$header_size = curl_getinfo($ch, CURLINFO_HEADER_SIZE);
		$responseBody = substr($response, $header_size);
		$headers = array();
		foreach (explode("\r\n", substr($response, 0, $header_size)) as $i => $line) {
			if ($i === 0)
            	$headers['http_code'] = $info["http_code"];
			else {
            	list ($key, $value) = explode(': ', $line);
            	if (strlen($key) > 0)
	            	$headers[$key] = $value;
        if ($this->debug) {
        	$debugURL = htmlentities($url);
        	$debugRequestBody = htmlentities(print_r(json_decode($body, true), true));
        	$debugHeaders = htmlentities(print_r($headers, true));
        	$debugResponseBody = htmlentities(print_r(json_decode($responseBody, true), true));
        	print <<<HTML
        		<PRE>
        			<TR>
        				<TD VALIGN="top"><B>URL</B></TD>
        				<TD VALIGN="top">$debugURL</TD>
        			</TR>
        			<TR>
        				<TD VALIGN="top"><B>Request Body</B></TD>
        				<TD VALIGN="top"><PRE>$debugRequestBody</PRE></TD>
        			</TR>
        			<TR>
        				<TD VALIGN="top"><B>Response Headers</B></TD>
        				<TD VALIGN="top"><PRE>$debugHeaders</PRE></TD>
        			</TR>
        			<TR>
        				<TD VALIGN="top"><B>Response Body</B></TD>
        				<TD VALIGN="top"><PRE>$debugResponseBody</PRE></TD>
        			</TR>
        		</TABLE>
        		</PRE>
HTML;
		return array($headers, json_decode($responseBody, true));
class FindMyiPhoneDevice {
	public $ID;
	public $batteryLevel;
	public $batteryStatus;
	public $class;
	public $displayName;
	public $location;
	public $model;
	public $modelDisplayName;
	public $name;
	public $API;
class FindMyiPhoneLocation {
	public $timestamp;
	public $horizontalAccuracy;
	public $positionType;
	public $longitude;
	public $latitude;
But won't work when run from Domoticz on my Raspberry Pi with this pasted into the ON part of the Virtual Switch
script:///home/pi/custom_scripts/turn-on-jono-iphone.php
It shows the following error message in Domoticz's logs:
'Error: Error executing script command (/home/pi/domoticz/scripts/turn-on-jono-iphone.lua). returned: 512'
I'm new to Domoticz (and the Raspberry Pi), so I'm hoping it's something easy or obvious to get working. Do I need to install or setup PHP on the Pi first, or should it run automatically?)
I also tried running it through a lua script
os.execute('curl --url "http://10.0.1.20/home/pi/domoticz/scripts/turn-on-jono-iphone.php"')
But that wouldn't work either. It shows the following error message in Domoticz's logs:
Anyone know how to get this working? :)
