LUA script to access TOON all data on demand
Posted: Tuesday 27 December 2016 14:48
by MatthijsPH
I am trying to build a lua-script that can access ENECO TOON and retrieve data on demand. This way for instance the actual TOON state can be retrieved from Toon. Offcourse more is possible. Having access to TOON can be handy if you want to update your selector switch without having to guess the current state by the current setpoint or get some other data that is not available in Domoticz.
There is a already a python script wich I forked and documented before.
However I would like to be able to use this functionality from within my lua-scripts and on demand.
I've come a long way in rewriting the python script to LUA and I am now able to receive "handshake" details, log-on to Toon and log-out again. The problem is the middle part in wich TOON State should be received. I'm pretty sure I'm doing something wrong (probably the cURL/get part), but I can't figure out what it is by myself. Hopefully somebody can help me.
The current "test" version of the script can also be found here
-- LUA modules
json = require('dkjson')
local user = 'xxxxxxxxxx'
local pass = 'xxxxxxxxxx'
local debug = 1
-- UUID1
--random = math.random
--function uuid1()
--   local template ='xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'
--   return string.gsub(template, '[xy]', function (c)
--      local v = (c == 'x') and random(0, 0xf) or random(8, 0xb)
--      return string.format('%x', v)
--   end)
--end
-- UUID4
function uuid()
   tmp = assert(io.popen('curl GET https://www.uuidgenerator.net/api/version4'))
   uuid4 = tostring(tmp:read('*all'))
   tmp:close()
   if debug == 1 then
      print('uuid: '..uuid4)
   return uuid4
-- LOGIN
function login()
   -- step 1: get agreement-details from Toon api
   local d1 = '\"username=' .. user .. '&password=' .. pass .. '\"'
   login = assert(io.popen('curl -X POST -d ' .. d1 .. ' https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/login'))
      local token = login:read('*all')
      login:close()
      jsonLogin, pos, err = json.decode(token, 1, nil)
      if debug == 1 then
         if err then print('err: '..err)
         else print('contents: '..token)
   clientId = tostring(jsonLogin.clientId)
   clientIdChecksum = tostring(jsonLogin.clientIdChecksum)
   agreementId = tostring(jsonLogin.agreements[1].agreementId)
   agreementIdChecksum = tostring(jsonLogin.agreements[1].agreementIdChecksum)
   if debug == 1 and jsonLogin.success == true then print('Eneco Toon - sleutel opgehaald') end
   -- step 2: log on to Toon api
   local tmp1 = uuid()
   if debug == 1 then print('login - uuid: '..tostring(uuid4)) end
   local d2 = '\"clientId='..clientId..'&clientIdChecksum='..clientIdChecksum..'&agreementId='..agreementId..'&agreementIdChecksum='..agreementIdChecksum..'&random='..uuid4..'\"'
   if debug == 1 then print('body login: '..d2) end
   auth = assert(io.popen('curl -X POST -d ' .. d2 .. ' https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/start'))
      local check = auth:read('*all')
      auth:close()
      jsonAuth, pos, err = json.decode(check, 1, nil)
      if debug == 1 then
         else print('auth: '..check)
   --uuId = tostring(jsonAuth.displayUuidKpi.uuid)
   --if debug == 1 then print('uuId: '..uuId) end
   if debug == 1 and jsonAuth.success == true then print('Eneco Toon - ingelogd') end
   return clientId, clientIdChecksum
-- LOGOUT
function logout()
   local tmp2 = uuid()
   if debug == 1 then print('logout - uuid: '..uuid4) end
   local d3 = '\"random='..uuid4..'&clientId='..clientId..'&clientIdChecksum='..clientIdChecksum..'\"'
   if debug == 1 then print('body logout: '..d3) end
   logout = assert(io.popen('curl -X POST -d ' .. d3 .. ' https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/logout'))
      local check = logout:read('*all')
      logout:close()
      jsonLogout, pos, err = json.decode(check, 1, nil)
      if debug == 1 then
         else print('logout: '..check)
         if jsonLogout.success == true then print('Eneco Toon - uitgelogd') end
-- GETSTATE
function getState()
   if debug == 1 then print('start getState') end
   i = 1
   repeat
      local tmp3 = uuid()
      --if debug == 1 then print('getstate - uuid: '..uuid4) end
      local d4 = '\"random='..uuid4..'&clientId='..clientId..'&clientIdChecksum='..clientIdChecksum..'\"'
      if debug == 1 then print('body getState: '..d4) end
      getState = assert(io.popen('curl -X GET -d '..d4..' https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/retrieveToonState'))
      local state = getState:read('*all')
      print('getstate: '..state)
         getState:close()
         jsonState, pos, err = json.decode(state, 1, nil)
	 if jsonState.success == true then
	    print("SUCCESS!")
	    stop = true
	    print("FAIL!")
	    i = i + 1
   until (stop or i == 4)
if devicechanged['testSwitch'] then
   local test1 = login()
   local test2 = getState()
   local test3 = logout()
   --local test = uuid()
