Milight dimming issue
Posted: Tuesday 27 December 2016 9:38
I just started to use Domoticz on a Raspberrypi with a RFLink attached to it. I am succesfully using this combination for a few 433mhz devices, so I started to experiment with Milight. I bought 3 bulbs al off the typ RGBW (and 3 WW/CW on their way). I can succesfully pair theses Milight RGBW bulbs within Domoticz using the RFLink.
Now, I can turn on/off these bulbs, I can change color (altough with an offset???
) and I can partially dim. This is a strange thing. If I for example have a bulb using the color white which is on 100% brightness (I guess by looking at it), I can dim this lamp successfully to for example 50% (using the slider in Domoticz). If I put the slider back to 100%, nothing happens? If I move the slider to let's say 10%, it dims... By going to 80%, it gets brighter, going to 100%, nothing change again. Only after some playing back and forth it seems to get at 100%. So, going down: always works. Going up: mostly doesn't work. What's going wrong here?
I am using the latest Domoticz stable version (v3.5877) and RFlink v45 (also used v44, but had the same issue). I don't have the Milight Wifi bridge, nor a Milight remote (although this one is on their way). My brother has the same set-up, same issue... Anyone else also experiencing this?
