Multi heaters and sensors, PID and hysterisis heating script
greg
Post by greg »
As a new Domoticz user and member of this forum, it's my pleasure to share the script i've developed to heat my chalet in the french Alps.
This script provides heating control in a room, providing different modes (Comfort, Eco), according to presence in the room and to a couple of setpoints. The heating control is proposed through two differents algorithms (Hysterisis or PID). The script supports multiple temperature control devices used in fallback, and multiple heating devices used simultaneously.
A power consumption computation is made, based on the declared power consumption of each heating device.
Required Domoticz configuration :
- A Thermostat to set the comfort temperature, created with Dummy hardware and a Thermostat device
Variable : sSetPointConfortDeviceName
- A Thermostat to set the eco temperature, created with Dummy hardware and a Thermostat device
Variable : sSetPointEcoDeviceName
- A Mode switch to set and program with timers the heating scenarii, created with Dummy hardware and a Selector Switch device
Variable : sHeatingModeDeviceName
- A Control Mode switch to switch between the Hysterisis and PID ways of control.
Variables : sHeatingControlModeDeviceName
sHeatingControlModePIDName, sHeatingControlModeHysteresisName are used for the name given to either mode.
- A Presence detection switch. The switch would be controlled either by hand or by some external scripts/commands.
Variable : sPresenceDeviceName
- An Electricity consumption meter, created with an Instant+Counter meter
Variable : sPowerMeterDeviceName
Script configuration
- A few variables need to be set in the script, to fit with your Domoticz instance.
- Heaters
One or more heaters have to be declared in an array, together with their power consumption and commands.
Variable : aHeatingDeviceNames
- Temperature sensors
They are declared in a array, with fall back mode implemented. The script is written for sensors that gather both temperature and humidity.
Variable : aTempSensorDeviceNames
- User variables
- fISumLast, a float value initialized to 0, that's the PID current integral value ;
- fTempLastInput, a float value initialized to 0, used for the PID derivative computation ;
- fSetpointLast, a float value initialized to 0, used to check a setpoint change ;
- iResetDeviceMeterTime, an integer value initialized to 0, used to record the power meter reset time.
The PID parameters are to be determined for your own installation. Three parameters need to be calculated,
according to the following formulas :
Kp = ΔPV / ΔCO -- On steady temperature states, ratio of temperature difference for command difference
Tp -- Time needed to reach 63% of the setpoint
θp -- Time between action on the heating and measurable reaction of the temperature sensor
Tc -- Response time, highest value among 0.1Tp or 0.8θp (agressive), 1Tp or 8θp (middle), 10Tp or 80θp (conservative)
Kc = P = (1/Kp)*(Tp/(θp+Tc)) -- Our fPIDKp
I = Kc/Ti -- Our fPIDKi
Td = (Tp x θp)/(2Tp+θp) -- Needed to compute the last constant
D = Kc * Td -- Our fPIDKd
The resulting temperature control is very good for my usage. Here is a temperature graph for going to a setpoint of 15 Celsius :
I thank very much the authors of the following web pages for their wonderful work :
http://brettbeauregard.com/blog/category/pid/
http://www.rhaaa.fr/regulation-pid-comment-la-regler-12
http://controlguru.com
I also thank a lot the members of this forum, and the ones of the french easydomoticz.com forum.
If this script is useful to you, i would be very happy to read about it, especially if it brought more comfort
and energy saving.
Thank you
Greg
Type : Time
Description : Controls heating in a room with hysterisis or PID method
Usage : Place in scripts/lua directory of Domoticz instance
- Heaters
- User variables
This script distributed under the GPL license. Please see https://www.gnu.org/licenses/gpl.html
-- Zone name
local sZoneName = 'Living room'
-- Setpoint
local sSetPointConfortDeviceName = 'Thermostat Confort'         -- Thermostat for comfort Setpoint
local sSetPointEcoDeviceName = 'Thermostat Eco'                 -- Thermostat for eco Setpoint
-- Power Meter
local sPowerMeterDeviceName = 'Consommation Chauffage'          -- Power meter based on configured heating devices consumption
-- Modes
-- These modes belong to the heating mode selector switch
local sHeatingModeDeviceName = 'Mode Chauffage'
local sHeatingModeComfortName = 'Confort'
local sHeatingModeEcoName = 'Eco'
local sHeatingModeForceOnName = 'Force'
local sHeatingModeFrostFreeName = 'Off'
-- Heating control mode (PID or Hysteresis)
local sHeatingControlModeDeviceName = 'Mode Controle Chauffage'
local sHeatingControlModePIDName = 'PID'                             -- Selection switch name for PID
local sHeatingControlModeHysteresisName = 'Hysteresis'         -- Selection switch name for hysterisis mode
local fHysteresis = 0.4                          -- Hysterisis value
-- Sensors
-- Will be choosen in fallback. Second parameter is a delta to the first temp sensor
local aTempSensorDevices = {
                             { 'Living-room 1',0 } ,
                             { 'Chambre Enfant',1.2 }     -- The room is usually ~1.2 deg hotter than the living room
local sPresenceDeviceName = 'Presence'          -- Presence device switch. Heating goes in Eco mode when Presence is Off.
-- Heaters
-- Domoticz Device Name, power in Watts, On command, Off command.
local aHeatingDevices = {
                             { 'Hors-Gel Radiateur Salon Est', 1500 , 'Off AFTER 3', 'On' } ,
                             { 'Hors-Gel Radiateur Salon Sud', 1500 , 'Off AFTER 3', 'On' }
-- PID - Proportional, Integral, Derivative - Parameters
local iHeatingCycleDuration = 10 -- Duration of a heating cycle in minutes, to be adapted to the heating devices
local fPIDKp = 113  -- Change this !
local fPIDKi = 0.05 -- Change this !
local fPIDKd = 30045 -- Change this !
-- Alerts
local sEmailContact = '[email protected]'
-- Debug
local bDebug = true
---------------------------------------------- End of configuration section ----------------------------------------------
-- Variables
local fCurrentTemp = 1000
-- Statics variables
-- Heating commands, constants not to be changed
local sHeatingOnCommand = 'ON'
local sHeatingOnForCommand = 'ONFOR'
local sHeatingOffCommand = 'OFF'
-- Functions
function prDebug(sString)
  if(bDebug) then
   print ( sString )
function addCommand( sDevice, sCommand )
   commandArray[#commandArray+1] = { [sDevice] = sCommand }
function timeDifference(sDeviceName)
   sDeviceTimeChanged = otherdevices_lastupdate[sDeviceName]
   sYear = string.sub(sDeviceTimeChanged, 1, 4)
   sMonth = string.sub(sDeviceTimeChanged, 6, 7)
   sDay = string.sub(sDeviceTimeChanged, 9, 10)
   sHour = string.sub(sDeviceTimeChanged, 12, 13)
   sMinutes = string.sub(sDeviceTimeChanged, 15, 16)
   sSeconds = string.sub(sDeviceTimeChanged, 18, 19)
   t1 = os.time()
   t2 = os.time{year=sYear, month=sMonth, day=sDay, hour=sHour, min=sMinutes, sec=sSeconds}
   return os.difftime (t1, t2)
function round(fNumber, iPrecision)
  local iMult = 10^(iPrecision or 0)
  return math.floor(fNumber * iMult + 0.5) / iMult
function commandHeating(sCommand,iTime)
 local fIntervalEnergy = 0
 local fInstantPower = 0
      -- Send command to heaters, calculate power and energy
       for iHeatingDeviceIndex = 1, #aHeatingDevices do
        local sActiveHeatingDevice = aHeatingDevices[iHeatingDeviceIndex]
        fInstantPower = fInstantPower + sActiveHeatingDevice[2]
        if( sCommand == sHeatingOnForCommand ) then
          fIntervalEnergy = fIntervalEnergy + (tonumber(fInstantPower) / 60 ) * iHeatingCycleDuration
           fIntervalEnergy = fIntervalEnergy + tonumber(fInstantPower) / 60
        if( sCommand == sHeatingOnCommand ) then
         prDebug('Heating device : - '..sActiveHeatingDevice[1]..' - , power : ' .. sActiveHeatingDevice[2]..' Watts gets command : '..sActiveHeatingDevice[3])
         addCommand(sActiveHeatingDevice[1],sActiveHeatingDevice[3])
         prDebug('Heating device : - '..sActiveHeatingDevice[1]..' - , power : ' .. sActiveHeatingDevice[2]..' Watts gets command : '..sActiveHeatingDevice[3]..' FOR '..tostring(iTime))
         addCommand(sActiveHeatingDevice[1],sActiveHeatingDevice[3] .. ' FOR ' .. tostring(iTime))  -- Can be missed :-( --> zwave!
        if( sCommand == sHeatingOffCommand ) then
         prDebug('Heating device : - '..sActiveHeatingDevice[1]..' - , power : ' .. sActiveHeatingDevice[2]..' Watts gets command : '..sActiveHeatingDevice[4])
         addCommand(sActiveHeatingDevice[1],sActiveHeatingDevice[4])
      -- Energy accounting
       -- Get current power-meter values
       sCurrentPower,sCurrentTotalEnergy = string.match(otherdevices_svalues[sPowerMeterDeviceName], "(%d+%.*%d*);(%d+%.*%d*)" )
       local fCurrentTotalEnergy = tonumber(sCurrentTotalEnergy)
       if(sCommand == sHeatingOffCommand ) then -- No instant power consumption
         addCommand('UpdateDevice', iPowerMeterIdx .. '|0|0;' .. sCurrentTotalEnergy)
         return
       fUpdatedEnergy = fCurrentTotalEnergy + fIntervalEnergy
       if(sCommand == sHeatingOnForCommand ) then -- System heating iTimes minutes
         addCommand('UpdateDevice', iPowerMeterIdx .. '|0|' .. fInstantPower .. ';' .. fUpdatedEnergy)
         addCommand('Variable:iResetDeviceMeterTime',tostring(iTime))
       if(sCommand == sHeatingOnCommand ) then -- System in On/Off mode, heating happends until a stop command
       -- Total instant power update
-- Init
iPowerMeterIdx = otherdevices_idx[sPowerMeterDeviceName]
-- Get time
local sCurrentTime = string.sub(os.date("%X"), 1, 5)
local sCurrentMinute = os.date('%M')
-- Check temperature sensors, choose the first one with response time < 10 min
-- set setpoint delta
for iTempSensorIndex = 1, #aTempSensorDevices do
      prDebug('Temp Sensor Device : '..aTempSensorDevices[iTempSensorIndex][1]..' - Delta to reference : ' .. aTempSensorDevices[iTempSensorIndex][2] )
      sTempSensorDeviceName = aTempSensorDevices[iTempSensorIndex][1]
      sTempSensorDeltaToReference = aTempSensorDevices[iTempSensorIndex][2]
  -- Last seen ?
      local sTempSensorLastSeen = string.sub(os.date("!%X", timeDifference(sTempSensorDeviceName)), 1, 5)
        -- if (sTempSensorLastSeen >= '00:10' and sTempSensorLastSeen < '00:12') then
        if (sTempSensorLastSeen >= '00:10') then
                  prDebug('Temp sensor missing')
          addCommand('SendEmail',sZoneName..' Heating Alert#Temperature sensor '..sTempSensorDeviceName..' has not updated for more than 10m.#'..sEmailContact)
        else -- Sensor has been seen, we use it
          sCurrentTemp,sCurrentHumidity = string.match(otherdevices_svalues[sTempSensorDeviceName],"(%d+%.*%d*);(%d+%.*%d*)")
          fCurrentTemp = tonumber(sCurrentTemp) + tonumber(sTempSensorDeltaToReference)
          prDebug ('Current measured temperature and delta applied : '..fCurrentTemp)
          break
if ( fCurrentTemp == 1000) then return commandArray end -- No temp sensor, end of execution
-- Check for energy accounting timer to reset the meter
local iResetMeterDeviceTime = tonumber(uservariables['iResetDeviceMeterTime'])
if ( iResetMeterDeviceTime > 0 ) then -- There is an ongoing power consumption
    local iNewResetDeviceMeterTime = iResetMeterDeviceTime - 1
     if( iNewResetDeviceMeterTime == 0) then
  -- reset energy counters on time
    addCommand('Variable:iResetDeviceMeterTime',tostring(iNewResetDeviceMeterTime))
-- Get current heating mode
sHeatingMode = otherdevices[sHeatingModeDeviceName]
-- Heating in Eco or Comfort, needs a calculation
if ( sHeatingMode == sHeatingModeComfortName
     or
     sHeatingMode == sHeatingModeEcoName
   then
            -- Inits
            bPresence = false
            fSetPointTemp = 7
            -- Check for presence
            sPresenceDeviceStatus = otherdevices[sPresenceDeviceName]
            if ( sPresenceDeviceStatus == 'On' ) then
                   prDebug('Presence is on')
                   bPresence = true
                   prDebug('Presence is off')
                   bPresence = false
            -- Comfort mode, set heating setpoint to thermostat value, only applies if Presence is true.
            if( (sHeatingMode == sHeatingModeComfortName) and bPresence ) then
                fSetPointTemp = tonumber(otherdevices_svalues[sSetPointConfortDeviceName])
                prDebug ('Heating in *Comfort mode*, Setpoint : '..fSetPointTemp..' at '..sCurrentTime)
            -- Eco mode, setpoint adjusted. Use this setpoint if no Presence.
            if( sHeatingMode == sHeatingModeEcoName or bPresence == false) then
               fSetPointTemp = tonumber(otherdevices_svalues[sSetPointEcoDeviceName])
                prDebug ('Heating in *Eco mode*, Setpoint : '..fSetPointTemp..' at '..sCurrentTime)
                        -- Control mode
            local sControlMode = otherdevices[sHeatingControlModeDeviceName]
            prDebug('Heating Control mode : ' .. sControlMode)
            if( sControlMode == sHeatingControlModeHysteresisName ) then -- Control mode set to hysteresis
                             -- Decision to heat or not
                             -- Is it cold ?
                             if(fCurrentTemp <= (fSetPointTemp - fHysteresis) ) then
                                 prDebug ('Heating needed with delta : ' .. fCurrentTemp - fSetPointTemp)
                                 -- startHeating(aHeatingDeviceNames) --GH get rid of variable
                                 commandHeating(sHeatingOnCommand)
                             -- Is it warm ?
                            if(fCurrentTemp >= (fSetPointTemp + fHysteresis) ) then
                                 prDebug ('Stopping heating needed with delta : ' .. fCurrentTemp - fSetPointTemp)
                                 -- stoptHeating(aHeatingDeviceNames)
                                 commandHeating(sHeatingOffCommand)
            if( sControlMode == sHeatingControlModePIDName ) then -- Control mode set to PID
                   -- We control the execution frequency
                   if( sCurrentMinute % iHeatingCycleDuration == 0) then -- We run the cycle
                                -- Set PID coefficients according to sample time
                                local fPIDTKi = fPIDKi * iHeatingCycleDuration * 60
                                local fPIDTKd = fPIDKd / (iHeatingCycleDuration * 60)
                                -- Current temperature error
                                 fTempError = fSetPointTemp - fCurrentTemp
                                 -- Compute new Integral
                                        -- If Setpoint changed, reset the integral action
                                         if( fSetPointTemp ~= tonumber(uservariables['fSetpointLast']) ) then
                                          fISum=0
                                          -- Get the last Integral
                                          fISum = uservariables['fISumLast']
                                 fISum = fISum + (fPIDTKi * fTempError)
                                 -- if(fISum > 255) then fISum = 255 end
                                 if(fISum > 255) then fISum = 255 end -- Integral limitation
                                 if(fISum < 0) then fISum = 0 end
                                 -- Derivative computation
                                 local fDeltaInput = fCurrentTemp - uservariables['fTempLastInput']  -- to number
                                 -- Sum up the PID output
                                 local fPIDOutput = fPIDKp * fTempError + fISum - fPIDTKd * fDeltaInput
                                 prDebug('PID Output : fPIDKp * fTempError = ' ..fPIDKp..' * '..fTempError..' = '..fPIDKp*fTempError..', fISum + '..fPIDTKi * fTempError..'  = '..fISum..', -fPIDTKd * fDeltaInput = '..fPIDTKd..' * '..fDeltaInput..' = -' .. fPIDTKd*fDeltaInput..', Output : '..fPIDOutput)
                                 if(fPIDOutput > 255) then fPIDOutput = 255 end
                                 if(fPIDOutput < 0) then fPIDOutput = 0 end
                                 -- Update user variables for next cycle
                                 addCommand('Variable:fTempLastInput',tostring(fCurrentTemp))
                                 addCommand('Variable:fISumLast',tostring(fISum))
                                 addCommand('Variable:fSetpointLast',tostring(fSetPointTemp))
                                  -- Heating cycle duration calculation
                                 if( fPIDOutput > 0 ) then -- heat
                                    fCycleDuration = round(fPIDOutput * iHeatingCycleDuration / 255,0)
                                    if( fCycleDuration == 0 ) then fCycleDuration = 1 end -- Heating is needed, let's go for at least 1 minute
                                    prDebug('Going to heat for : ' ..fCycleDuration..' minutes during the next '..round(iHeatingCycleDuration*60)..' seconds ('..iHeatingCycleDuration..' minutes) period.' )
                                    commandHeating(sHeatingOnForCommand,fCycleDuration)
                                  else -- Output null or negative, stop the heating
                                    prDebug('No heating needed')
            end -- Time period
       end -- PID mode
-- Heating forced on
if ( sHeatingMode == sHeatingModeForceOnName )
   then
            prDebug('Heaters forced On')
-- Heating forced off
if ( sHeatingMode == sHeatingModeFrostFreeName )
   then
            prDebug('Heaters forced Off - Anti-frost mode')
Skippiemanz
Domoticz version: 4.10233
Re: Multi heaters and sensors, PID and hysterisis heating script
Post by Skippiemanz »
Greg,
Looks nice!
Could it be used for a normal boiler heating system?
Is it the case of just leaving the watts out of does is need more?
greg
Post by greg »
Thank you ! I guess it can be used with a normal boiler heating system. I would be careful with the minimum time the boiler would need to heat to be effective. You can maybe tweak the line "if( fCycleDuration == 0 ) then fCycleDuration = 1 end -- Heating is needed, let's go for at least 1 minute" to accomodate with a minimal heating time.
The Watts are not needed, it's cosmetic ;-)
Cheers
Abbadon
Post by Abbadon »
great piece of work, i will test it in my flat.
Thank you
edit. i add json line to update selector (comfort/eco) when persence button is on/off
commandArray[1]={['OpenURL']='http://ip:port/json.htm?type=command&param=switchlight&idx=180&switchcmd=Set%10Level&level=10' }
commandArray[1]={['OpenURL']='ip:port/json.htm?type=command&param=switchlight&idx=180&switchcmd=Set%20Level&level=20'}.
humi chart: humi 100% when heat is ON, humi 1% when is off
Bez tytułu.png (60.56 KiB) Viewed 5486 times
Blueone
Post by Blueone »
I'm very interested in this script and especially the PID part but it is all a bit new for me. Do you have some tips for calculating the the pid parameters?
- What does this exactly mean?
-My setpoint is set at 20.5 which I can increase with 0.5, is is 63% of the time it takes for the heating system to increase the temp wit 0.5?
-clear, can be easily measured, is it in minutes or seconds?
Can you explain this a bit more?
what is the Ti value in this formule
Thanks for your reply!
greg
Post by greg »
Sorry for my late reply. Please find answers below :
Blueone wrote: Kp = ΔPV / ΔCO -- On steady temperature states, ratio of temperature difference for command difference
PV is the room's temperature ;
CO - Controller Output - , is the power percentage of the heaters.
The variable indicates the temperature change that will follow a change in the heating power.
To calculate this value, i put the system in place with basic values (i really recommend you to create
a spreadsheet to compute those), until the temperature is steady. I then have a look at the computed
values, especially the heating percentage. If the heaters are on for 3 minutes on 10 minutes cycles, then
they are running at 30%, it's the first CO. I keep the record of the steady temperature in the room, that's the first PV.
Then, i raise the setpoint, and wait until the temperature is steady again. The heaters are now maybe
running at 70%, it's the second CO. The measured temperature in the room is the second PV.
Blueone wrote: Tp -- Time needed to reach 63% of the setpoint
Yes, if you increase the setpoint with 0.5, and it takes one hour to reach it, Tp=2268 seconds.
Blueone wrote: θp -- Time between action on the heating and measurable reaction of the temperature sensor
It's in seconds.
Blueone wrote: Tc -- Response time, highest value among 0.1Tp or 0.8θp (agressive), 1Tp or 8θp (middle), 10Tp or 80θp (conservative)
It the speed at which the heating system will react. When it's agressive, the system will surpass the setpoint,
while when conservative, the system will take more time to reach the setpoint, but won't exceed it.
Blueone wrote: Kc = P = (1/Kp)*(Tp/(θp+Tc)) -- Our fPIDKp
Actually, Ti = Tp.
