JSON to query device by name
Posted: Friday 23 December 2016 19:46
Hello All,
i have looked for the feature, but have failed to find. Pls, excuse me, if something similar exists.
Is it possible to extend JSON processing to query device information name, e.g. the following query
could respond with
this would make IoT devices to find respective Idx easier.
As far as i understand current JSON solution can query/filter devices by type. However this could lead to quite big response, which would require far more processing in IoT device, hence more energy consumption, than with proposed solution.
Thank you
http://domoticz:8080/json.htm?type=devices&name=Temp_test1Code: Select all
"ActTime": 1474795292,
"ServerTime": "2016-12-23 12:21:32",
"Sunrise": "07:11",
"Sunset": "19:08",
"result": [
"AddjMulti": 1.0,
"AddjMulti2": 1.0,
"AddjValue": 0.0,
"AddjValue2": 0.0,
"BatteryLevel": 255,
"CustomImage": 0,
"Data": "0.0 C",
"Description": "",
"Favorite": 0,
"HardwareID": 2,
"HardwareName": "test",
"HardwareType": "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal": 15,
"HaveTimeout": false,
"ID": "14053",
"LastUpdate": "2016-12-23 12:21:13",
"Name": "Temp_test1",
"Notifications": "false",
"PlanID": "0",
"PlanIDs": [
0
"Protected": false,
"ShowNotifications": true,
"SignalLevel": "-",
"SubType": "LaCrosse TX3",
"Temp": 0.0,
"Timers": "false",
"Type": "Temp",
"TypeImg": "temperature",
"Unit": 1,
"Used": 1,
"XOffset": "0",
"YOffset": "0",
"idx": "4"
"status": "OK",
"title": "Devices"
}As far as i understand current JSON solution can query/filter devices by type. However this could lead to quite big response, which would require far more processing in IoT device, hence more energy consumption, than with proposed solution.
Thank you
