MySensors Problem version and nodes
Posted: Friday 23 December 2016 17:55
Hello everyone,
Im stuck at the installation of Mysensors to domoticz.
I have setup a test set with a serial connection between NRF2401+ and Rpi B+
Through Rpi i linked USB to ttyUSB30. And hardware to ttyUSB30 and BAUD 115200
As node i'm testing with Arduino nano connected with NRF2401+
I followed the instructions on :
https://forum.mysensors.org/topic/2437/ ... 1-x?page=1
and
https://www.mysensors.org/build/raspberry
i'm using DOMOTICZ V3.5877 (Rpi B+) only mysensors for test
What i've seen in domoticz, there's not version number mentioned for mysensors. just a question mark symbol, like Version ?
Is this normal ?
Result on Raspberry Pi
pi@testdomo:~/MySensors $ sudo ./bin/mysgw -d
mysgw: Starting gateway...
mysgw: Protocol version - 2.1.0-beta
mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0-beta
mysgw: TSF:LRT:OK
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: TSM:INIT:TSP OK
mysgw: TSM:INIT:GW MODE
mysgw: TSM:READY:ID=0,PAR=0,DIS=0
mysgw: MCO:REG:NOT NEEDED
mysgw: Listening for connections on 0.0.0.0:5003
mysgw: MCO:BGN:STP
mysgw: MCO:BGN:INIT OK,TSP=1
mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
mysgw: TSF:MSG:BC
mysgw: TSF:MSG:FPAR REQ,ID=1
mysgw: TSF:PNG:SEND,TO=0
mysgw: TSF:CKU:OK
mysgw: TSF:MSG:GWL OK
mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
mysgw: TSF:MSG:PINGED,ID=1,HP=1
mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
mysgw: TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
mysgw: TSF:MSG:READ,1-1-0,s=3,c=0,t=0,pt=0,l=0,sg=0:
mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
mysgw: TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=2,l=2,sg=0:1
mysgw: TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=2,l=2,sg=0:0
And through Arduino serial monitor:
Request registration...
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
Node registration=1
Init complete, id=1, parent=0, distance=1, registration=1
TSP:MSG:SEND 1-1-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:1
TSP:MSG:SEND 1-1-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:0
However i cant find or add devices in domoticz site, Ive tried 'Allow for 5 minutes' function in Settings - Setup
According the log i got this:
2016-12-23 17:25:54.665 Domoticz V3.5877 (c)2012-2016 GizMoCuz
2016-12-23 17:25:54.670 Build Hash: 15b013c, Date: 2016-11-10 16:44:33
2016-12-23 17:25:54.671 System: Raspberry Pi
2016-12-23 17:25:54.671 Startup Path: /home/pi/domoticz/
2016-12-23 17:25:54.983 Active notification subsystems: http (1/12)
2016-12-23 17:25:54.988 WebServer(HTTP) started on address: :: with port 8080
2016-12-23 17:25:55.011 WebServer(SSL) started on address: :: with port 443
2016-12-23 17:25:55.022 Proxymanager started.
2016-12-23 17:25:55.026 Starting shared server on: :::6144
2016-12-23 17:25:55.029 TCPServer: shared server started...
2016-12-23 17:25:55.029 RxQueue: queue worker started...
2016-12-23 17:25:57.033 EventSystem: reset all events...
2016-12-23 17:25:57.035 EventSystem: reset all device statuses...
2016-12-23 17:25:57.037 EventSystem: Started
2016-12-23 17:25:58.035 MySensors: Using serial port: /dev/ttyUSB30
Did i forgot something or is something missing ?
Thanks in advance!!!! Keep up the fantastic work !!!!
and
Is this normal ?
mysgw: TSF:LRT:OK
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: MCO:BGN:STP
mysgw: TSF:MSG:BC
mysgw: TSF:CKU:OK
Node registration=1
