Not reconnecting serial port
Posted: Friday 23 December 2016 16:24
I have a weird problems since i switched to mysensors 2.0, with 1.5.4 i never had this problem. (same hardware)
Domoticz seems to lose the connection to the serial gateway, and is not reconnecting.
Sometimes it comes back, manny times it won't.
A restart of the system sometimes works, manny time's it dosn't.
A disconnect/reconnect of the gateway from the usb port sometimes works, manny time's it dosn't.
It is the correct port :
tree /dev
Sometime's it reconnects and when i try to activate a mysensor switch, boom the connection is lost.
I tried :
Switching USB ports for the gateway on my machine => nope
Different arduino gateway => nope
And now i am a little bit lost.
Off frustation a ordered the components for a ethernet gateway, but ths is still annoying, and the components will not come in before newyear is suppose
I cam accros a post on the MySensors forum https://forum.mysensors.org/topic/4945/ ... -power-rpi with the same problem, but no sollution. I will cross link this post on the same thread.
I hope someone can push me in the right direction.
With regards
Peer
tree /dev
I tried :
With regards
Peer
