YAAS - Yet Another Alarm Script
Posted: Friday 23 December 2016 15:57
by emme
Ok... this is nothing new...
but it's my way to handle alarms and notification.... and I wish to share and ear your opinion about
My setup works like this:
All PIRs, Magnets, Tamper and flood/gas sensors have the same 4 digits prefix (PIR_, MAG_ etc etc)
Based on the Donoticz Security Panel Status it takes actions
Actions are NOT included here.... this script simply update few variables that will trigger other scripts (not yet implemented) for eventually other actions
Probes and Tampers does not conseder the Domoticz Security panel status
(actually the Arm Home status is not implemented yet)
After 2 minutes with no events, alarm resets and restart:
local PIR = 'PIR_'       -- Prefisso per devices Sensori Movimento
local MAG = 'MAG_'       -- Prefisso per contatti magnetici
local TMP = 'TMP_'       -- Prefisso per TAMPER
local PRB = 'PRB_'       -- Prefisso per sonde (Allagamento e Gas)
local SECSTATUS = globalvariables['Security']   -- Stato impianto allarme
local AllOff = true      -- Switch per valutazione allarme cessati
local DEBUG = false
local prfPrompt = '>>> [SECURITY] <<< '
if DEBUG and SECSTATUS ~= 'Disarmed' then print(prfPrompt..'Stato impianto: '..SECSTATUS) end
function timeDiffVar(vName)
    t1 = os.time()
    updTime = uservariables_lastupdate[vName]
    year = string.sub(updTime, 1, 4)
    month = string.sub(updTime, 6, 7)
    day = string.sub(updTime, 9, 10)
    hour = string.sub(updTime, 12, 13)
    minutes = string.sub(updTime, 15, 16)
    seconds = string.sub(updTime, 18, 19)
    tDiff = os.difftime(t1,t2)
    return tDiff
    if SECSTATUS == 'Disarmed' and uservariables['Alarm_generic_Staus'] ~= '0' then
        table.insert (commandArray, {['Variable:Alarm_Generic_Status'] = '0' })
        table.insert (commandArray, {['Variable:Alarm_Sirena'] = '0' })
-- Valutazione allarme
    for devName, devStatus in pairs(devicechanged) do
        -- TUTTO INSERITO
        if (string.sub(devName,1,4) == PIR or string.sub(devName,1,4) == MAG) and uservariables['Alarm_Generic_Status'] == '0' and SECSTATUS == 'Armed Away' then
            if devStatus == 'On' then
                AllOff = false
                print(prfPrompt..'Riscontro: '..devName.. ' Cambio valore: '..devStatus..' Allarme ON')
                table.insert (commandArray, {['Variable:Alarm_Generic_Status'] = '1' })
                table.insert (commandArray, {['Variable:Alarm_Sirena'] = '1' })
                table.insert (commandArray, {['SendNotification'] = 'ALLARME#Attivato '..devName..' Innesco Sirena' })
        -- SONDE E CONTROLLI PERDITE (indipendenti dallo stato del SecPanel)
        elseif string.sub(devName,1,4) == PRB and uservariables['Alarm_PRB_Status'] == '0'then
                AllOff = false
                print(prfPrompt..'ALLARME SONDE: '..devName.. ' Cambio valore: '..devStatus..' Silenzioso')
                table.insert (commandArray, {['SendNotification'] = 'SENSORI SICUREZZA#Attivato '..devName..' Richiesta di Verifica Immediata!!!!' })
                table.insert (commandArray, {['Variable:Alarm_PRB_Status'] = '1' })
        -- TAMPER!!!!
        elseif string.sub(devName,1,4) == TMP then
                AllOff = false
                print(prfPrompt..'ALLARME TAMPER: '..devName.. ' Cambio valore: '..devStatus..' Allarme ON')
                table.insert (commandArray, {['SendNotification'] = 'ALLARME#Attivato Tamper '..devName..' Innesco Sirena' })
-- Azzeramento Allarmi
    if AllOff and uservariables['Alarm_Generic_Status'] ~= '0' and timeDiffVar('Alarm_Generic_Status') >= 120 then
        print(prfPrompt..'Allarme cessato... Ripristino')
        table.insert (commandArray, {['Variable:Alarm_PRB_Status'] = '0' })
        table.insert (commandArray, {['SendNotification'] = 'ALLARME CESSATO#Fine Attività, Azzeramento allarmi e ripristino stato: '..SECSTATUS })
-- Annullamento Sirena
    if uservariables['Alarm_Sirena'] == '1' and timeDiffVar('Alarm_Sirena') >= (tonumber(uservariables['Alarm_Sirena_Min'] * 60)) then
        table.insert (commandArray, {['SendNotification'] = 'SIRENA#Spegnimento Sirena. \n Ripristino stato: '..SECSTATUS })
what do you think about?
ciao
M
