adding a doorbell
Posted: Friday 23 December 2016 12:17
by edje1205
I have RFXtrx433E and very happy with its posibilities (after buying KaKu yes it gives more satisfaction :D )
With 2 doorbells 1 is working: (Lifetec/Mignon/Aldi MD17177) I use this for garden bell.
The other one, Envivo Model PO-1413 . Frequency 433.92 is not recognized or yes it is: Setting accepted for 5 minutes new hardware I see a panic button several times or at least a chime, but nothing happened if pressing the bell.
Turned on all protocols, tried to pair the chime and/or switch but no luck.
Is this the right place to do a request to add this to Domoticz or ........?
Thanks in advance !
Re: adding a doorbell
Posted: Friday 23 December 2016 12:56
by b_weijenberg
The Envivo model ENV1348 is only supported for transmit in Ext firmware. See chapter 2.2.2 in the RFXtrx User Guide.
Please check with RFXmngr on a Windows system if you can control your model.
Posted: Friday 23 December 2016 13:53
by edje1205
Thanks for reply b_weijenberg !
It's about Envivo Model PO-1413. Is it the same protocol as ENV1348 ? I daubt about it.
I run Ext2, and checked with RFXmngr: nothing shows up to handle with (last time i tried).
I have last Domoticz firmware V 3.5877 and updated RFXmrx433E 2 days ago.
Protocol in doorbell switch: 5 H 0716 005602.
Posted: Thursday 05 January 2017 11:03
by edje1205
I now have envivo PO-1413 and PO-1461
I can reach both with transmit code 005602 and 003194in rfxmngr :) (the bell rings, no thats not through it confirms pairing)
then I save all settings.
but in domticz 'allow new hardware' and 5 minutes it's not showing up when pushing the button
How can I set the codes in domoticz ?
edit tried manual all doorbells with that codes but nothing happened (there is no envivo there while it is in RFXmngr)
Could it be add ? Or what mark is same: Byronsx does nothing
Teknihall (envivo) does not respond emails about protocols, compare brands etc)
could some one give me a hint ?
Posted: Saturday 07 January 2017 14:44
by edje1205
Returned codes in RFXmngr
Chime command
Packettype = Chime
subtype = Envivo ENV-1348 (PO-1461)
Sequence nbr = 6
ID = 003194 decimal:12692
Signal level = 0 -120dBm
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 6
response = ACK, data correct transmitted
Chime command
Packettype = Chime
subtype = Envivo ENV-1348 (PO-1413)
Sequence nbr = 7
ID = 005602 decimal:22018
Sequence nbr = 7
can I use the decimal codes ?
thnx !
