Adding Node Through Fibaro Switch Route
Posted: Sunday 18 December 2016 18:21
by Nephylim
I've got a problem integrating a TRV into my Network,
the TRV is not reachable by the Controller itself because it is too far away.
I cant add it easily standing next to the controller but it isn't able to send any updates when installed at the radiator.
There is a Fibaro Switch between the two which schould work as a relay but I can't get it to work.
I already tried adding the node while being at the radiator. But it did not work. How can I add the Node to use the switch as relay to the controller?
Thank you for your help
Re: Adding Node Through Fibaro Switch Route
Posted: Sunday 18 December 2016 19:59
by pvm
Did you add it to the network, install on radiator (or put somewhere near) and perform a Z-Wave network heal?
This heal re-routes the traffic
Posted: Monday 19 December 2016 17:06
by Nephylim
That did it. Thank you
