domoticz version V3.6169
synology nas 112+ latest DSM
i have installed 2 new Fibaro FGWPF-102 ZW5 versions.
I have made new config files so the modules are recognized correctly
They work great, switching, powerconsumption etc everything is working.
Now i have 2 problems
openzwave control panel now seems very slow
before the modules were added and i clicked control panel all the modules would show up instantly.
Now they show up one by one which takes +/- 5 minutes
second problem is that the 2 new modules do not show up in openzwave control panel at the bottom.
if i click statistics i see all the modules(including the new ones) with al the info but the 2 modules do not show up at the bottom.
this is really a problem becauise now i can not force those modules to do a neighbour discover or other commands.
modules in domoticz
all the modules in statistics(so openzwave control panel sees them)
but openzwave control panel does not put them at the bottom of the screen
also the devices show up really slow.
could there be some leftovers from the old fibaro plug i excluded from the config
The old module was not zw5, the new modules are but they have different id's
as far as i can tell this problem was also there before i excluded a module
can this be the cause of this
logfile domoticz
2016-12-17 19:26:45.134 Error: Webserver: File '/ozwcp/cp.js': No such file or directory (2)
2016-12-17 19:47:34.493 Error: Webserver: File '/ozwcp/ozwcp.poll.XXXXXX.xml': No such file or directory (2)
Openzwave control panel does not see modules
YcKe
Re: Openzwave control panel does not see modules
Could it be that you are trying this in firefox?
I'm experiencing the same issue but it's not present when using Chrome.
EDIT: I fixed the issue. The problem was caused by an illegal character that was in the configuration. I'll upload the fix to the OpenZwave github.
Edit 2: In the meanwhile the change has been accepted: https://github.com/OpenZWave/open-zwave ... c3af1833f6
Greetz YcKe
Greetz YcKe
Gravityz
- Domoticz version: 2026.3
Wow YcKe you are a GENIUS. So an illegal character in the config file caused this
Which character because i do not see the change
I made that config file by editting the old fgwpe file so probably a strange typo
Also what should the type of the file be PC or UNIX
when i pull my files from the synology NAS the original files are type PC but i expected UNIX
changed the file and saved it as unix
Voila Zwave panel working again.(i will inspect my other modified files)
Can you also post another pull request for this file.
I made this file from the fgwpe.xml and changed all the registers
i commented out some commandclasses because they are recognised and supported by domoticz itself.
reading however the zwcfg_xxxx.xml file i noticed that commandclass 32 is not added.
this is a very basic class which is supported.
After adding the class to the config file i noticed that the module now makes connections with other modules more easily(maybe this has nothing to do with it)
commandclass 32 however is mandatory for each module
can you add this to the config(without strange characters) i took the entry from other fibaro modules
<!-- COMMAND_CLASS_BASIC supported -->
<CommandClass id="32" action="add" request_flags="5" innif="true" />
YcKe
I'll try to add the commandClass and let you know how it goes.Gravityz wrote:Wow YcKe you are a GENIUS. So an illegal character in the config file caused this
The word "device’s" was replace with "device's". As you can see the accent ' is from a different type. (non ascii)
This was causing the issue as firefox was complaining on it. I tried using chrome also and this one didn't have any problems with it.
Note: The next check-in of the OpenZwave team was to remove all non ascii characters in all config files, so it was not the only config file having problems.
Greetz YcKe
- Domosapiens
- Domoticz version: V3.5981
Well done YcKe !
These files are involved in the "non ascii" modification:
If you own one or more of these devices:
- Update to Version 3.6328
- Remove the node from the zwcfg_0xxxxxxxxx.xml file
- restart Domoticz
config/aeotec/zw116.xml
config/devolo/mt2646.xml
config/fakro/zws12.xml (only in comment section, the "non ascii" could be the reason)
config/fakro/zws230.xml (only in comment section, the "non ascii" could be the reason)
config/fibaro/fgfs101zw5.xml
config/fibaro/fgk10x.xml
config/fibaro/fgpb101.xml
config/ge/12724-dimmer.xml
config/kaipule/im20.xml
config/logicsoft/ZHC5010.xml
config/qubino/ZMNHVDx.xml
config/qubino/ZMNHZDx.xml
config/shenzen_neo/nas-pd01z.xml
config/widom/WDS.xml - Update to Version 3.6328
- restart Domoticz
YcKe
I understand that we need to add the following statement to the config:
A question I have related to this is if those parameters are correct. I don't want to publish anything I'm not sure of
Can anyone confirm if those are correct?
Greetz YcKe
Greetz YcKe
Gravityz
I do not think we get a response it this thread.
maybee just just do a pull request.
i did some more checking and read the zwcfg_xxxx entry for a fgwpe module
it has the mapping command added.
i have changed it and now the entry looks exactly the same as the fgwpe module(which basically has the same as the fgwpf zw5 version )
so do a pull request for this
<CommandClass id="32" action="add" request_flags="4" mapping="37" />
YcKe
Hi GravityzGravityz wrote:I do not think we get a response it this thread.
The change is already added and merged some time ago but domoticz is not yet updated with it.
Greetz YcKe
