Temperature Humidity sensor No Display
Posted: Thursday 15 December 2016 15:27
by parrotface
I have created a combined virtual Temperature / Humidity sensor
It show fixed values in the header until I send data to it and then shows nothng.
From a web browser I send
http://192.168.1.221:6788/json.htm?type ... ue=59.5;97
From Mosquitto I send
mosquitto_pub -h localhost -m '{ "idx" : 186, "nvalue" : 0, "svalue" : "44.0;77" }' -t 'domoticz/in'
From my MQTT device I send
{ "idx" : 0186, "nvalue" : 0, "svalue" : "44.4;88" }
All three examples cause the sensor to show the last seen message with correct time and Date so I asume the syntax is OK.
I have other sensors receiving Temperatures from my MQTT device, also weather info all OK.
The log shows a graph of temperature and humidity OK
But No Values in the sensor Header Bar
have recreated new virtual sensors OK - problem seems to be with combined temperature/humidity
Humidy alone I send
http://192.168.1.221:6788/json.htm?type ... 8&svalue=0
thanks
Re: Temperature Humidity sensor No Display
Posted: Saturday 17 December 2016 10:00
by stlaha2007
Your last sample purely humidity is correct... nvalue contains the humidity and svalue the humiditystatus [0..5]
According to the json-wiki the temp-hum expects the following: nvalue always 0 (zero), svalue TEMP;HUM;HUM_STAT
So you need to send 21 degreesC 67% humidity NoStatus as 21;67;0
Had simular problem within a bash-script ;-)
Posted: Saturday 17 December 2016 18:01
by parrotface
Thanks that works
added ;0 to the end and temp/humidity displays
eg
http://192.168.1.221:6788/json.htm?type ... ue=23;42;0
Many Thanks
Re: RE: Re: Temperature Humidity sensor No Display
Posted: Sunday 18 December 2016 15:38
by stlaha2007
parrotface wrote:Hi
Thanks that works
eg
Many Thanks
Great to hear it works.
Little OffTopic:
I noticed, your writing with MQTT to domoticz. I would like to now why and how. As i have several bash scripts that
write with curl through jsonapi, however one's a week or two the http-interface fails to respond.
Which also need to be backgrounded/daemonized eventually.
