backup on USB key
Posted: Wednesday 14 December 2016 17:37
by cycloneseb
hi folk !
I'm starting this discussion in order to have feedback from experimented people...
I would like to make weekly backup of the SD card of my raspberry (on which is running domoticz) and daily backup of the database of domoticz.
Nothing new on this, as a lot of tutorials are dealing with that, but I only found tutorials dealing with backup on a NAS server. In my case, as I don't have a NAS, I would like to do this backup on a 64 GB USB storage key attached to my raspberry.
Someone here in the group has been already developed this ? is a tutorial available to perform this operation ?
Many thanks !
Best regards.
Re: backup on USB key
Posted: Thursday 15 December 2016 12:51
by elmortero
It is basically the same as backing up to a NAS, you just copy to another location.
If you only have on usb key connected following script should be fine, if not you need to alter the script to match your usb key.
If you do not have Monit installed just remove the lines that are related to that (lines 7, 8, 19 and 20)
#!/bin/bash
#script to backup entire domoticz folder
clear
sudo mount /dev/sda1 /media/usb
echo "Backing up Domoticz folder... please standby..."
##Remove following 2 lines if you don't use Monit
echo "First stopping Monit to avoid false alerts or reboots"
sudo /etc/init.d/monit stop
echo "Stopping the Domoticz service"
sudo service domoticz.sh stop
echo "domoticz service stopped- starting backup now"
sudo rsync -aAXv --fake-super --log-file=/home/pi/domoticz/scripts/domobackup.log /home/pi/domoticz /media/usb/home/pi/
echo "Restarting Domoticz... please standby..."
sudo service domoticz.sh restart
echo "domoticz service restarted"
sudo chmod +x /home/pi/domoticz/scripts/domobackup.log
sudo chmod 777 /home/pi/domoticz/scripts/domobackup.log
echo "Starting monit again"
sudo /etc/init.d/monit start
I made a "Push on Button" with the script in the ON action so I don't have to run the script from command line.
You could put a timer on that , or instead of the button use a Cron task to do the backup weekly. I prefer to start the backup manually so that I can do it at a time that is convenient to me without shutting down (even very briefly) domoticz unexpectedly.
Posted: Thursday 15 December 2016 13:00
by Egregius
I never stop domoticz for making a backup :P
I use this script on my nas to backup the complete domoticz folder with versioning:
#!/bin/sh
NOW=$(date +"%Y-%m-%d")
TIME=$(date +"%s")
SOURCE="/volume1/@appstore/domoticz/"
LAST=`cat /volume1/web/secure/backups/domoticz.txt`
LASTFILE=`find /volume1/@appstore/domoticz -type f -printf '%T@ %p\n' | sort -n | tail -1 | cut -f1 -d"."`
if [[ $LAST -ne $LASTFILE ]] || [[ $LAST -lt $MAXTIME ]];then
	DESTINATION="/volume1/homes/guy/backup/domoticz"
	LOGFILE=/volume1/web/secure/backups/logs/domoticz.$NOW.txt
	echo ------------------------------------ START domoticz -- $(date +"%Y-%m-%d %H:%M:%S") UTC+2 | tee -a $LOGFILE
	rsync -aP --exclude-from '/volume1/homes/guy/backup/excludedfiles.txt' --stats --delete-after --ignore-errors --links --link-dest="$DESTINATION/__prev/" "$SOURCE" "$DESTINATION/$NOW" | tee -a $LOGFILE
	rm -f "$DESTINATION/__prev"
	ln -s "$NOW" "$DESTINATION/__prev"
	echo ------------------------------------ END  domoticz -- $(date +"%Y-%m-%d %H:%M:%S") UTC+2 | tee -a $LOGFILE
	echo $LASTFILE > /volume1/web/secure/backups/domoticz.txt
	echo $TIME > /volume1/web/secure/backups/domoticz.time.txt
    unset LAST
    unset LASTFILE
fi
LAST = timestamp of last execution stored in a txt file
LASTFILE = timestamp of newest file in SOURCE folder, also stored in a txt file.
A bit unnecessary in case of Domoticz, I just left it because this is the way I backup multiple things and I use that information in a web page where I can monitor all backup scripts I run.
Posted: Monday 26 December 2016 16:50
by gerritjan
Hello Elmortero I am new here,
I was searching for this!! Elmortero Can you tell me how i make the script running? Can i start it with Blocky to?
What do you mean with: I made a "Push on Button" with the script in the ON action?
My raspberry frequently jams. Therefor I have an old backup of the entire SD card and a backup of resent domoticz.db. Domoticz.db do I copy using ubuntu on the SD card.
Using Scripts I have no experience.
thanks gerritjan.
Posted: Monday 26 December 2016 18:52
by elmortero
First you need to have a Dummy device active in Setup -> Hardware. Create a "device" of the type "Dummy (Does nothing, use for virtual switches only)", I called mine V-Switch
Then, in the Switches screen you can manually create a switch, as hardware you choose the dummy device you made, give a name and for Switch Type you select Push On Button.
Then add the path to the backup script in the On Action.
That's it
Posted: Tuesday 23 January 2018 14:13
by gerritjan
The usb backup worked perfectly with a single adjustment so far. The special thing is that I did not use the backup this last year for recover. That may be because I also changed the password of the raspberrypi!
