Help with multi zone heating script?
Posted: Tuesday 13 December 2016 18:21
by erikjanverweij
Is there someone who can help me write a lua multi zone heating script? I have a blocky script working with setdevicetemperature, but the script is not so reliable and sometimes the Heater keeps burning.
My setup is:
Aronlabs gen5 z-wave stick
2 danfoss z-wave radiator valves (Bathroom and studio)
2 temperature sensors (bathroom and studio)
I added a qubino relay switch to the CV heating so that I can overrule the on-of thermostat.
For now the livingroom is controled by the on-of thermostat and I want to write a script to seperately heat the studio and bathroom.
In the future I want to expand My setup and add also the livingroom to the script with extra valves and temperature sensors.
Hope there is someone who can help.
Re: Help with multi zone heating script?
Posted: Tuesday 13 December 2016 21:37
by Egregius
Seems pretty straight forward.
If bathroom is to cold or studio is to cold switch heater on.
But how will you prevent overheating of the living room?
If you want some advanced control you can look look at 'badkamer_temp' and 'verwarming' of my pass2php script:
https://egregius.be/2016/lua-pass2php-v ... te-script/
Posted: Wednesday 06 September 2017 9:54
by erikjanverweij
Beceause the old heater passed away, i installed a new one and I upgraded my configuration with an OTGW and 2 extra valves in the living room.
The configuration now looks like this:
Living room with thermostat connected to OTGW:
- actual temperature: woonkamer actueel
- desired temperature: woonkamer gewenst
- radiator valve 1: radiator woonkamer 1
- radiator valve 2: radiator woonkamer 2
Bathroom:
- actual temperature: badkamer actueel
- desired temperature: Badkamer gewenst
- radiator valve: radiator badkamer
Studio:
- actual temperature: werkkamer actueel
- desired temperature: Werkkamer gewenst
- radiator valve: radiator werkkamer
The question is how to control the rooms seperate and still be able to trigger the heating device to start/stop via the OTGW. As the thermostat controls the temperature in the living room but also triggers the OTGW to heat.
Is there another OTGW setpoint I can use so that the living room will not be influenced when i dont need to?
Could Anyone help me with writing a script?
Posted: Thursday 21 September 2017 9:05
by dervogt
I have setup the additional relay as switch in my domotics (I am using a piface relay to switch the low voltage control line from my thermostat to the circulation pump) and using this code in one of my scripts to control the heating, note that I am first triggering the pump to switch on as there are minimum two valves below their setpoint temperature:
if ((otherdevices[HeatingSwitch] == 'On') and (otherdevices[PresenceSwitch] == 'On')) then -- It's time to heat the house
if (otherdevices[BoilerSwitch] == 'Off') then --If a minimum of 'MinValves' valves are on by more that pre-set value BoilerOnPercent
if printDebug == true then
print ("Test On 1/3 passed - Boiler is OFF ")
if (PercentMax > BoilerOnPercent) then
print ("Test On 2/3 passed - Radiators are open beyond the threshold ")
if (ValveCount >= MinValves) or (PercentMax >= ValvePercentOveride) then
print ("Test On 3/3 passed - Either multiple valves are open or override count is reached ")
commandArray[BoilerSwitch]='On' -- turn on boiler
ValveCount = ValveCount + 1
table.insert(commandArray, {['OpenURL'] = 'http://127.0.0.1:8080/json.htm?type=command¶m=updateuservariable&vname=valvecount&vtype=2&vvalue='..ValveCount})
if printData == true then
print ("Command sent - Turn ON Boiler ")
