Event don't start on variable state change
sorampage
Domoticz version: LastStab
Post by sorampage »
I think find a small problem with Blockly and variables.
If an event start when a variable state change, the event doesn't start ... You MUST add "TIME>00:00" for event check state of your variable every minutes.
Is problem known?
Thx.
Egregius
Domoticz version: v2024.7
Re: Event don't start on variable state change
Post by Egregius »
sorampage wrote: Is problem known?
Yes, search forum.
sorampage
Post by sorampage »
I actualy use an hidden dummy switch, but it can be more clean with variables...
@Egregius, if you have a solution, share it !
sorampage
Post by sorampage »
The domoticz Wiki say .. User variables can trigger events ... No user variable can't trigged an event..
https://www.domoticz.com/wiki/User_variables
Is that a problem that is known? Is there a resolution?
Egregius
Post by Egregius »
http://www.domoticz.com/forum/viewtopic ... op#p107174
I don't use uservariables as I believe that causes needless stress on Domoticz, I use MemCached for that.
chrisfraser05
Post by chrisfraser05 »
This is odd.....
I have a blocky event that works, it's only based on the user variable state. I never had to do the time fix.
