Scene Timers Read in LUA
Posted: Monday 12 December 2016 12:10
by TimH
it is possible to read out the Timers of a Scene in LUA and the Command(On/Off)?
TimH
Re: Scene Timers Read in LUA
Posted: Monday 12 December 2016 17:51
by jvdz
This is a way to do a JSON call and translate the returned data:
-- LUA to get GASMETER usage
-- Load necessary Lua libraries
http = require "socket.http";
socket = require "socket";
https = require "ssl.https";
JSON = require "JSON";
--~ --Get Scene Timers
local t, jresponse, status, decoded_response,idx
-- ### update the next 2 lines ##########################################
idx=9 -- IDX of the Scene
t = "http://192.168.xx.xx:8080/json.htm?type=scenetimers&idx="..tostring(idx)
jresponse, status = http.request(t)
decoded_response = JSON:decode(jresponse)
result = decoded_response["result"]
-- List all SceneTimers
if result == nil then
print(os.date("%X").." No scene timers found for IDX "..idx)
for i = 1, #result do
record = result[i]
if type(record) == "table" then
day = record["d"]
value = record["v"]
print(os.date("%X").." "..i..
" Active="..record["Active"]..
" Cmd="..record["Cmd"]..
" Date="..record["Date"]..
" Hue="..record["Hue"]..
" Level="..record["Level"]..
" Randomness="..record["Randomness"]..
" Time="..record["Time"]..
" Type="..record["Type"]..
" idx="..record["idx"]
Jos
Posted: Tuesday 13 December 2016 10:49
by TimH
Thank you. I will try it the next days.
Posted: Tuesday 13 December 2016 12:10
by TimH
i have tried your Script but i got some failure with the libraries.
I use a Synology Diskstation to run Domoticz and this don't have the libraries.
Searching the Internet don't look good for Synology Lua Libraries.
Have anybody the right libraries or a idea where i can fount them?
Posted: Tuesday 13 December 2016 12:39
by jvdz
The libraries can be found here:
https://www.domoticz.com/wiki/Remote_Co ... _Libraries
This is a description for a Raspberry Pi so might need tweaking.
Jos
Posted: Wednesday 14 December 2016 8:46
by TimH
thank you for the Link.
I tried to translate it to Synology but i get failure.
Where are defined the Folder, where the location of the Libraries?
Posted: Wednesday 14 December 2016 15:31
by jvdz
I think the error message, you get about not being able to find the require("LIB"), is telling you in which directories it was looking for these functions? at least that is what I seem to remember happening for me on a raspberry.
Jos
Posted: Wednesday 14 December 2016 18:38
by TimH
HI.
error Message in domoticz:
2016-12-14 08:14:03.753 Error: EventSystem: in READOUT: [string "-- LUA to get GASMETER usage..."]:3: module 'socket.http' not found:
no field package.preload['socket.http']
no file '/usr/local/share/lua/5.2/socket/http.lua'
no file '/usr/local/share/lua/5.2/socket/http/init.lua'
no file '/usr/local/lib/lua/5.2/socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http/init.lua'
no file './socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './socket/http.so'
no file '/usr/local/lib/lua/5.2/socket.so'
no file './socket.so'
I have unpack the Files as indicated in the instructions and in the existing LUA-Folder from the Diskstation.
But i Think i must change the locating Folder for the Library.
Posted: Monday 20 March 2017 23:47
by wervisser
Bump...
Did you by any chance got this fixed ?
Posted: Tuesday 15 May 2018 21:24
by niki_lauda
TimH wrote: Wednesday 14 December 2016 18:38
HI.
Did you fix it?
Posted: Tuesday 15 May 2018 21:29
by niki_lauda
wervisser wrote: Monday 20 March 2017 23:47
Bump...
Did you fix it?
