Temperature sensor to measure central heating (CV leidingen)
Bartb
Post by Bartb »
Hi.
I am looking for a temperature sensor, supported by RFXCOM, which I can use to measure the temperature of the water in my central heating (CV-leidingen). Can anyone recommend a sensor for this?
I have found the following device, but reviews on whether it works in Domoticz or not, seem contradicting.
Temperatuursensor TFA 30.3139
https://www.conrad.nl/nl/temperatuursen ... &WT.srch=1
Westcott
Re: Temperature sensor to measure central heating (CV leidingen)
Post by Westcott »
The Banggood ones work well with RFXcom and RFlink
Bartb
Post by Bartb »
Have a link or name of the product I can search for?
I need it to have one of these external connectors so that I can attach the sensor to the Central Heating system pipes, and it needs to talk to RFXCOM.
niki_lauda
Post by niki_lauda »
Bartb wrote:Hi.
I bought this one a few years ago and its working very well.
https://weerhuisje.nl/index.php?action= ... 31&lang=nl
Bartb
Post by Bartb »
That's usefull! Thanks!
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
Today I installed two of these for measuring temperature of the pipes my central heating:
https://www.conrad.nl/nl/temperatuursen ... 18426.html
Both work with RFXCOM in Domoticz.
Derik
Post by Derik »
perhaps build a espeasy with some dallas sensors...
You can make with 1 esp a complete readout device for all of your cv devices..[ 10-15 sensors. ]
And for less then a 1 433mhz sensor. [ buy Ebay ]
NickHead
Post by NickHead »
I agree with the Dallas Sensors and ESPEasy, I use a NodeMCU with 3 Dallas Sensors, One Central Heating, One Hot Water
and One In the Fridge, (I had a problem with defrosting for no reason).
Cheap and cheerful, upgradable to more sensors if required, and so much fun to play with.
A lot of stuff that is doing my head in.
MatthijsPH
Domoticz version: 3.5305
Post by MatthijsPH »
Is the one in the fridge battery powered?
NickHead
Post by NickHead »
Sorry about the late reply Matt, I have been busy.
The temp sensors are on a single ESP12 node mcu board powered by a mains 5v PSU.
Effectively, if the fridge mains goes off, all 3 sensors go off, so no need for a battery supply.
It's been stable for a while now.
947539730 : DS : Temperature: 36.50 (28-be-df-26-0-0-80-ce)
947542137 : DS : Temperature: 6.31 (28-ff-41-cf-81-15-2-a9)
947543138 : DS : Temperature: 17.75 (28-92-f6-26-0-0-80-e)
947544233 : WD : Uptime 15699 ConnectFailures 0 FreeMem 26896
whiteduck
Post by whiteduck »
Hi there,
After reading this thread I bought two TFA 30.3139 with the external sensor and have an original USB RFXtrx on the latest firmware (Type 2 1024) but it cannot receive any signals from this device. I am on 3.8153 of Domoticz. The RFXCom happily receives Oregon and other AC/ARC signals.
I contacted Bert @ RFXCom who asked me to use rfxmngr - unfortunately I have no Windows device handy but I used rfxcmd_gc and didn't see anything coming back other than the Oregon's.
I have disabled all other protocols but no joy.
Does anyone have any suggestions?
Thanks a lot
Ian
Domoticz on Ubuntu 16.04 LTS VM
RFXCom USB transceiver
Aeon Labs V2 USB (Zwave)
Various HomeEasy, Oregon devices and sensors. Now using Z-Wave Fibaro FGMS-001, TKB TZ88Es
TP-Link IP310 Cameras
Bartb
Post by Bartb »
Were you able to get it working yet?
I have a similar sensor (TFA 30.3133) and have the following protocols enables for my RFXCOM transceiver.
One of the enabled protocols should allow you to detect/add the sensor.
Schermafbeelding 2018-05-06 om 22.06.19.jpg (53.52 KiB) Viewed 4786 times
whiteduck
Post by whiteduck »
Thank you - no but I know why now - I have the original RFXtrx433 so I lent the temperature sensor to a friend at work - he got it working but has the later RFXtrx433E device.
The excellent Bert from RFXCom offered a competitive upgrade so I will have a think or just live with them not being supported.
Thank you again!
Ian
