Qubino ZMNHBD1 2 relay - Not responding for itself
Posted: Sunday 11 December 2016 11:26
I have a flush 2 relay (Node003) that was communicating via a relay (Node004 Aeotec smartswitch 2) to the controller (Node001 - Razberry). Communications were fine with the Qubino being 1 hop away for the controller.
The Controller is running on a Raspberry Pi 2B with Domoticz 3.6081 and OpenZWave.
I then added an Aeotec multi sensor 6 (Node014) which sits next to the Node003 Qubino. Node014 reports it's neighbour as Node003. No problems. And can communicate. But Node003 no longer responds to queries and no longer sends reports. Both the Qubino and the Multisensor show (Almost always) as ID 0x0000 and Type 0x0000.
Does the Qubino flush 2 relay have any known issues with acting as a relay? I know it's talking because I can see messages coming in the OZW log... e.g.
2016-12-11 09:22:05.211 Info, Node003, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=3): 0x01, 0x04, 0x00, 0x41, 0x03, 0xb9
2016-12-11 09:22:05.214 Detail, Node003, Received: 0x01, 0x09, 0x01, 0x41, 0xd3, 0x9c, 0x01, 0x04, 0x10, 0x01, 0xed
2016-12-11 09:22:05.214 Info, Node003, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2016-12-11 09:22:05.214 Info, Node003, Protocol Info for Node 3:
2016-12-11 09:22:05.215 Info, Node003, Listening = true
2016-12-11 09:22:05.215 Info, Node003, Beaming = true
2016-12-11 09:22:05.215 Info, Node003, Routing = true
2016-12-11 09:22:05.215 Info, Node003, Max Baud Rate = 40000
2016-12-11 09:22:05.215 Info, Node003, Version = 4
2016-12-11 09:22:05.215 Info, Node003, Security = false
2016-12-11 09:22:05.215 Info, Node003, Basic device class (0x04) - Routing Slave
2016-12-11 09:22:05.215 Info, Node003, Generic device Class (0x10) - Binary Switch
2016-12-11 09:22:05.215 Info, Node003, Specific device class (0x01) - Binary Power Switch
2016-12-11 09:22:05.216 Info, Node003, COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_SWITCH_BINARY
2016-12-11 09:22:05.216 Info, Node003, Mandatory Command Classes for Node 3:
2016-12-11 09:22:05.216 Info, Node003, COMMAND_CLASS_SWITCH_BINARY
2016-12-11 09:22:05.216 Info, Node003, COMMAND_CLASS_SWITCH_ALL
2016-12-11 09:22:05.216 Info, Node003, Mandatory Command Classes controlled by Node 3:
2016-12-11 09:22:05.216 Info, Node003, None
