Klikaanklikuit Doorbell always ON
Justintime
Post by Justintime »
I have a Doorbell switch Klikaanklikuit ACDB-7000AC
Been busy with a Blocky. To activate my cove lights and a script to take screenshots.
The problem is that the DoorbellSwitch always "ON" is in the device list. When i use the blocky and schemerschakelaar is ON he activates the Blocky. While i want to be activated when the doorbell is switched.
Tried both "on" and "group on"
Tried to convert it to a pushbutton or normal switch but nothing works?
 "ActTime" : 1481311656,
   "ServerTime" : "2016-12-09 20:27:36",
   "Sunrise" : "08:38",
   "Sunset" : "16:25",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 1.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 3,
         "HardwareName" : "RFXCOM",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "13C73CA",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2016-12-09 20:23:27",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Deurbel",
         "Notifications" : "true",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : 7,
         "Status" : "",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "Doorbell",
         "SwitchTypeVal" : 1,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "doorbell",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "345"
   "status" : "OK",
   "title" : "Devices"
Justintime
Re: Klikaanklikuit Doorbell always ON
Okay found a work around....
Made a normal switch with a "group on" command. And made a seperate blocky to switch it off. In the Doorbell blocky it didnt work.
Still i think its strange that a doorbell gives a "ON" state.
Westcott
Post by Westcott »
I think you'll find that just about every wireless doorbell is the same!
You only need to do a devicechanged check, 'cos it sends ON whenever pressed.
This question has been asked nearly a million times...
Justintime
This is the blocky:
Problem is when "licht Fibaro" reached the criterium. Its going to start the blocky. Because the Doorbell is "ON"
But i have reached my goal.
Justintime
2 hours later... This blocky works. If you set the blocky to devices.
No need for extra blocky to set it "off"
Been a while since used blocky with this "new" feature.
