Simple turn on between time range
jrich523
Domoticz version: 3.5196
Post by jrich523 »
Hey Guys,
I am trying to do this with blocky but i suppose lui is fine too.
I just want to turn a light on between 4:30 and 9:30pm, so i created a simple IF block and did the time range and inside the Do i just turned the light on.
This sort of works because it will turn the light on, but after it passes 9:30 it never actually shuts off. Is there some simple way to handle this or do i need to do an On event at 4:30 and then a seperate off event at 9:30?
Thanks, just want to make sure im doing this the best way.
thanks
[ Domoticz 3.5196 | Win10 | AeoTec Z-Stick Gen5 ]
Toulon7559
Domoticz version: <2025
Re: Simple turn on between time range
Post by Toulon7559 »
Why use Blocky or lua-script for switching a lamp based on time?
Simpler method: go to Switches, for the subject Switch select 'Timers', and set the time for ON and the time for OFF.
With 'Timers' for each time you can also set a random variation around this time, and you can also make choices for weekdays, for weekends and for selected days.
jrich523
Post by jrich523 »
well crap.... im an idiot.... thanks...
Toulon7559
For alignment with the nominal times for sun's light you may include sunrise or sunset in Timer-setting.
