Trying to use Popp 009303 Battery Wall Controller with Domoticz
Posted: Wednesday 07 December 2016 23:09
by Letalis
I need some starting help to get on track with Domoticz.
I have included a Popp 009303 Battery Wall Controller to Domotics but need some help to configure this to work with my qubino in the kitchen.
Both on/off and dim.
On Controller
- Controller Popp del1.PNG (275.18 KiB) Viewed 2523 times
- Controller Popp del2.PNG (124.54 KiB) Viewed 2523 times
On Device
- Device Popp.PNG (18.43 KiB) Viewed 2523 times
Re: Trying to use Popp 009303 Battery Wall Controller with Domoticz
Posted: Friday 09 December 2016 19:15
by Letalis
FYI: I can use it in Z-wave.me where I can see all 4 buttons.
Posted: Tuesday 27 December 2016 10:24
by Letalis
Am I alone on trying to use this one?
Posted: Tuesday 27 December 2016 11:06
by Stromsec
Hi, I have also been struggling with this one.
Got it working today by following this guide
https://www.domoticz.com/wiki/Popp_Kfob
Skip the first 2 sections and start at "Adding the Popp Kfob to Domoticz" "3. Add the Controller (Node 1, the zwave USB stick) to all groups of the Kfob"
After this i could successfully add buttons to a scene.
Remember to wake up the popp by go to maintenance mode by pressing all for buttons (flashing green light) and the press button 2 (upper right) this will allow the popp to fetch the new settings.
Posted: Tuesday 27 December 2016 13:20
by Letalis
Stromsec wrote:Hi, I have also been struggling with this one.
Thanks . Now I'm on the way to make this work.
Did you get a "shitload" of lightswitches aswell?
Posted: Wednesday 28 December 2016 9:05
by Stromsec
I only got 4 new devices one for each button.
What are your settings on the popp? I have the same as the ones in the link I provided.
Posted: Wednesday 28 December 2016 21:37
by Letalis
same here.
singleclick
doubleclick
longclick
and a fourth similar to a releaseclick.
When I longclick and release it gives me 2 different devices.
Posted: Monday 02 January 2017 12:48
by swevm
For me devices only show up in Domoticz if I configure buttons to send "scene command".
What I´d love to have is the same learning capabilities that exist for RFX/Tellstick in Domoticz. but that seem not to work for Z-Wave remotes.
Keep in mind that even if you get a device from the Popp remote you cannot interact with is as it´s only capable of sending a state change command, not recieve anything - This mean you cannot interact with the devices that Domotics create for the remote. Also 009303 remotes seem only capable of sending "On" command if configured to send "scene command".
/Magnus
Posted: Monday 02 January 2017 13:05
by soroga
What are your settings ?
Posted: Tuesday 10 January 2017 23:08
by swevm
Took some time to look into this - busy at work
Have updated to latest beta, 6306.
Button configurations I have tested and how they are seen by Domoticz:
"Switch On/Off" - Can control zwave Groups but is not recognized by Domoticz if pressed. However the controlled device state change gets intercepted by Domoticz so it can be used to trigger Domoticz scenes
"Send Scenes" - A device is created by Domoticz when button is pressed on 009303 - This device can be used to trigger Domoticz scenes using Switch|Learn if needed (keep in mind it only send "On" command) - Have noticed that once I change config back to normal On/Off setting created device is still there and I cannot delete it
"Central scene to gateway" - Nothing is detected at all by Domoticz
For me its not how I want it to work as I want to stay independent of Domoticz itself to control zwave devices but still be able to use Domoitcz to trigger state change of other z-wave devices when needed while being able to intercept when a remote button is pressed even if its using basic On/Off configuration. Hence I use zwave groups to allow my zwave remotes to control other zwave devices even if Domoticz is down. Need to stay WifeCompatible.
/Magnus
