Setpoint POPP thermostat
Posted: Sunday 04 December 2016 17:48
by QuuN
Hi All,
Recently I purchased 2 POPP thermostats (kinda the same as the Danfoss LC-13, but with different firmware).
I included both thermostats and they are available in domoticz.
However when I try to alter the setpoint, domoticz gets a time-out
This happens to both thermostats. Anyone knows how to fix this?
Regards,
QuuN
Re: Setpoint POPP thermostat
Posted: Sunday 04 December 2016 18:26
by Egregius
What is your wakeup interval?
Posted: Sunday 04 December 2016 18:53
by QuuN
300 sec, although I lowered this to 60 sec for testing purposes.
Since that didn't do the trick, I put both back to 300
Posted: Sunday 04 December 2016 23:01
by Egregius
I often see the timeouts, but they're updated. For me no big deal.
I guess yours don't update?
Are they awake in OZWCP if you push the middle button?
Posted: Monday 05 December 2016 9:31
by QuuN
Unfortunately it doesn't update its setpoint. Didn't know if the time-out had something to do with it.
I haven't checked in OZWCP if they are awake when I push the button, though the thermostat needs to be awake when I change the wakeup interval. SInce this works fine, I guess the wake up part works fine. I will check this later today to be sure.
Edit: Just checked my OZWCP groups, and I noticed the following:
Both thermostats have no groups assigned. Maybe that has something to do with the fact that I'm unable to send a setpoint? I do get the current temperature of both thermostats.
Posted: Thursday 05 January 2017 7:55
by QuuN
Since this topic was kinda dead, I was in doubt of posting the solution I finally found but here goes.
First I tried all kind of things, for example altering the manufacturer_specific.xml file, excluding/reincluding the valve, setting the valve to factory settings, updating all kinds of libraries and so on.
Eventually I noticed there was an update for domoticz, which I then installed on my rpi. Instead of the unknown danfoss device, my ozwcp now says POPP thermostat after reincluding. Everything works fine now.
Posted: Thursday 05 January 2017 8:06
by ropske
Good to know it works now for you
Can you assign now a Group to your thermostats?
Posted: Thursday 26 January 2017 23:38
by Rocketgi
I have the same problem and for me isnt any update of domoticz avialble.
I use domoticz on synology 216play.
Has anybody an idea or a solution?
I cant change the temperature else the date and time.
But changing the wake up works...
Devise found is danfoss unknown bit i have the popp radiator control.
Thanks for any help.
Posted: Friday 27 January 2017 6:55
by Rocketgi
Argh.
Autoupdate has failed.
With the jadahl new beta version the thermostate works fine.
Posted: Thursday 29 June 2017 22:38
by thibf0xx
I have set up the Popp thermostat with a Gen5 AETOC key.
Setting the target temperature with Setpoint works like a charm, however the temperature sensor is stuck at 0 degrees;
In the device section, the temperature sensor is recognised as a LaCrosse TX3, is that also the case for you?
Thanks in advance.
