Raspb Pi 3 and 1wire
Posted: Saturday 03 December 2016 16:26
by piotrlis
I'm using Pi3 and GPIO 1wire - I'm able to get temp from sample device.
Freshly installed Domoticz - when adding hardware - got only option for OWFS - I'm not using OWFS - how to get it working?
regards
piotrlis
Re: Raspb Pi 3 and 1wire
Posted: Saturday 03 December 2016 20:03
by antwan
Emty: OWFS Path in hardware
Posted: Monday 05 December 2016 8:37
by emme
If you specify OWFS Path, Domoticz assume you are using it (see the wiki), if you leave it empty it will detect 1Wire bus
I've done with no OWFS for my 4 DS18B20 probes on my central heating pipes and works really good!
Posted: Thursday 18 May 2017 17:18
by lynex93
emme wrote:If you specify OWFS Path, Domoticz assume you are using it (see the wiki), if you leave it empty it will detect 1Wire bus
Hi, im trying this, but my domoticz doesnt detect the ds18b20, can u help me?
Thanks in advance
Posted: Friday 19 May 2017 8:28
by emme
first check if the 1wire bus is ok:
put here the result of:
ls -l /sys/bus/w1/devices
Posted: Monday 29 May 2017 21:32
by Lebo2d9
