Set up switch module Philio PAN06-1A
Posted: Saturday 03 December 2016 16:08
by normanth
I am a beginner in home automation. Can someone give me a tip, how I set up the switch module under Domoticz?
Server hardware: Synology NAS
USB Stick: ZME UZB1
(Hardware Idx: 6, Name: ZMEUZB1, Activated: yes, Type: RFXCOM - RFXtrx868 USB 868MHz Transceiver Version: 0, Port: /dev/ttyACM0)
Switch module: Philio PAN06-1A
In the manual of the switch module I found, that I have 2 minutes for auto inclusion after switch to main power - the LED is flashing.
But if I press the button in Domoticz for auto inclusion there appears a message that there was no signal.
I tried the manual switch setup of Domoticz. But I don't find the switch module under type and I don't know where I can find the correct codes.
Does anyone have a tip as I go a step further? Or does someone know a simple guide? I'm sorry but I did not find anything.
Thanks alot!
Norman
Re: Set up switch module Philio PAN06-1A
Posted: Saturday 03 December 2016 16:36
by normanth
is it correct, that I use "RFXCOM - RFXtrx868 USB 868MHz Transceiver" for my ZME UZB1?
Thanks, Norman
Posted: Saturday 03 December 2016 17:34
by normanth
I have found the solution:
- Add configuration for PAN06-1A:
viewtopic.php?t=9778
- Add USB Stick to Domoticz:
http://www.vesternet.com/resources/appl ... ELvWlxrUol
-> Hardware type of USB stick: OpenZWave
-> Setup > node management > include node
Norman
