Custom Arduino Sensor/Script
Posted: Tuesday 29 November 2016 23:48
by devtone
I have a Arduino with 4 sensors, LAN connected.
It runs a HTTP server that responds with:
<current>
<light value="630"/>
<co2 value="238"/>
<temp value="25.70"/>
<presure value="103239"/>
</current>
I've created a HTTP poller running the following LUA script:
s = request['content'];
local light = domoticz_applyXPath(s,'//current/light/@value')
local co2 = domoticz_applyXPath(s,'//current/co2/@value')
local temp = domoticz_applyXPath(s,'//current/temp/@value')
local presure = domoticz_applyXPath(s,'//current/pressure/@value')
domoticz_updateDevice(2988507,'',light .. ";" .. co2 .. ";0;" .. temp .. ";0;" .. presure .. ";0")
HTTP poller works as i see the data in the Domoticz log:
2016-11-30 00:03:45.346 CLuaHandler (updateDevice from LUA) : idx=2988507 nvalue= svalue=624;241;0;25.70;0;103246;0 invalue=0 signallevel=12 batterylevel=255
Extra info on the data:
624 = lightsensor
241 = CO2
25.70 = temp
103246 = presure
Re: Custom Arduino Sensor/Script
Posted: Tuesday 29 November 2016 23:54
by devtone
Bonuscode (Arduino):
#include <SPI.h>
#include <Ethernet.h>
#include <Adafruit_BMP085.h>
#include <Wire.h>
Adafruit_BMP085 bmp;
int SensorCO2Value;
int SensorLightValue;
const int SensorCO2=1;
const int SensorLight=0;
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 68, 222);
EthernetServer server(80);
void setup()
Serial.begin(9600);
while (!Serial) {
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
bmp.begin();
void loop()
EthernetClient client = server.available();
if (client) {
Serial.println("Probed");
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
if (c == '\n' && currentLineIsBlank) {
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println();
client.println("<current>");
int sensorReading0 = analogRead(0);
client.print("<light value=\"");
client.print(sensorReading0);
client.println("\"/>");
int sensorReading1 = analogRead(1);
client.print("<co2 value=\"");
client.print(sensorReading1);
client.print("<temp value=\"");
client.print(bmp.readTemperature());
client.print("<presure value=\"");
client.print(bmp.readPressure());
client.println("</current>");
break;
if (c == '\n') {
} else if (c != '\r') {
currentLineIsBlank = false;
delay(1);
client.stop();
Serial.println("disconnected");
Posted: Wednesday 30 November 2016 0:27
by devtone
Got some data with:
local presure = domoticz_applyXPath(s,'//current/presure/@value')
domoticz_updateDevice(1,'',temp .. ";0")
domoticz_updateDevice(2,'',presure .. ";0")
domoticz_updateDevice(3,'',co2 .. ";0")
domoticz_updateDevice(4,'',light .. ";0")
2016-11-30 00:53:59.519 CLuaHandler (updateDevice from LUA) : idx=1 nvalue= svalue=25.60;0 invalue=0 signallevel=12 batterylevel=255
2016-11-30 00:53:59.522 CLuaHandler (updateDevice from LUA) : idx=2 nvalue= svalue=1.0321;0 invalue=0 signallevel=12 batterylevel=255
2016-11-30 00:53:59.525 CLuaHandler (updateDevice from LUA) : idx=5 nvalue= svalue=244;0 invalue=0 signallevel=12 batterylevel=255
2016-11-30 00:53:59.545 CLuaHandler (updateDevice from LUA) : idx=4 nvalue= svalue=627;0 invalue=0 signallevel=12 batterylevel=255
Posted: Wednesday 30 November 2016 1:53
by devtone
Solved.
Can anyone explain the diff between nvalue and svalue? Can't find any info on it..
