What have i done wrong here?
stuiow
Domoticz version: 3.6857
Post by stuiow »
I suspect it's something to do with the timings.
Basically, when its dark and the door is opened, i want lights on and an audible alarm.
It isn't working as shown here though, any thoughts?
Cheers
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
Egregius
Domoticz version: v2024.7
Re: What have i done wrong here?
Post by Egregius »
Your time is during daylight, you need < sunrise OR > sunset for nighttime.
Also your door sensor probably reports open/close, check it with the current states button.
stuiow
Post by stuiow »
Ah, it was the timings, once i put them to what you said, all went well.
Cheers! Now i know where i went wrong with another blocky i did before, i didnt use OR.
stuiow
Post by stuiow »
One things, when I trigger a door sensor to open, not all lights are coming on stright away, is there too much happening at once?
Should i space them apart?
Egregius
Post by Egregius »
Depends if it's 443 or zwave or...
I always put a sleep of 0,4 sec between commands, even for zwave. If not I have a mutex error.
