1Wire Issues
alarm_guy1
1Wire Issues
Hi guys,
I have an issue that I posted in bus/problems, but had no response to.
in my list of hardware I no longer have 1wire, even in the recent update, there are a few extras but no 1wire.
Is there anything I can do to force the list, I have restarted my PI but still nothing.
I wanted to add 3 temp sensors for the lounge kitchen and hall,
Currently I have 1 sensor the Pi can see it and Domoticz can sort of see it as per the attached screenshot, but it doesnt know it is a 1wire device.
I am attaching a screenshot of my list too (this is 2 screenshots as the new list is longer
- Screenshot of Part identified temp sensor
- Screenshot 2014-01-18 14.07.23.png (189.18 KiB) Viewed 5575 times
- Screenshot 1 of Hardware list
- Screenshot 2014-01-18 14.07.10.png (189.93 KiB) Viewed 5575 times
- Screenshot 2 of Hardware list
- Screenshot 2014-01-18 14.04.53.png (168.21 KiB) Viewed 5575 times
Hendrik
Re: 1Wire Issues
is 1-wire on your startup list from your raspberry?
CubieTruck with Domoticz
RfxTrx 433Mhz Usb, Rfx Sensor, Z-Wave
Slave Raspberry Pi with Domoticz, Piface, P1 usb
- elythomaslumber
- Domoticz version: 2023.1
Re: 1Wire Issues
Did you enable 1-Wire in the SetUp/Hardware?
alarm_guy1
Re: 1Wire Issues
Hi elythomaslumber, thanks for the reply, but this is my issue 1wire is not in Setup\Hardware type list.
Hi Hendrik how do I tell if 1wire is on the startup list on the Pi?
cheers
cheers
Hendrik
Re: 1Wire Issues
You need to add two lines that must be loaded after reboot
These are: w1-gpio and w1-therm
This can be done with:
sudo nano / etc / modules
and then add them under the last line
it should resemble the following
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Parameters can be specified after the module name.
snd-bcm2835
ipv6
w1-gpio
w1-therm
snd-bcm2835
ipv6
w1-gpio
w1-therm
alarm_guy1
Re: 1Wire Issues
Thanks for the continued support,
I ran
I got a blank Nano screen (no other lines of text)
So I copied and pasted the following
snd-bcm2835
ipv6
w1-gpio
w1-therm
and saved it as 1wire (I assume it is in /etc/modules) but i cant find it
what do I do now?
cheers
I ran
snd-bcm2835
ipv6
w1-gpio
w1-therm
what do I do now?
cheers
Raspberry Piet
Re: 1Wire Issues
Type
sudo nano /etc/modules
instead of
instead of
alarm_guy1
Re: 1Wire Issues
My god man you are a genius, many many thanks working a treat now
cheers
well chuffed
cheers
well chuffed
- gizmocuz
Re: 1Wire Issues
There is a wiki about this since years
http://www.domoticz.com/wiki/1Wire
enercon
Re: 1Wire Issues
Hi Gents,
I have the same symtons, lost the one wire devices when i upgraded, i have reinstalled from scratch and have w1-gpio and w1-therm in /etc/modules, but nothing in the setup/hardware/type dropdown for 1 wire?
Any help would be appreciated.
Paul
Re: 1Wire Issues
I made the errors go away by commenting out the w1 modules in /etc/modules and commenting out the device tree setup in /boot/config/txt
#dtoverlay=w1-gpio
I was seeing w1_bus_master popping up in top every 2 seconds or so and hogging 30% of the raspberry cpu.
error and cpu load now gone... raspberry B+ running at 0.19 load avg with mjpeg streamer on port 9090 also running on same RPi as domoticz and functioning as a domoticz webcam by using the ImageURL ?action=snapshot
really old webcam as well!
WOW Awesome!
mjpeg_streamer... Awesome
domoticz... Awesome
V41... Awesome
Linux... Awesome
RPi... Awesome
Arduino universe... AWESOME
#dtoverlay=w1-gpio
WOW Awesome!
domoticz... Awesome
V41... Awesome
Linux... Awesome
RPi... Awesome
