Installation on Debian 7
Posted: Thursday 24 November 2016 7:58
I have problem for install Domoticz on a Debian 7.
If I follow the Wiki page, I have an error during the execution of make command :
Scanning dependencies of target lua
[ 0%] Building C object lua/src/CMakeFiles/lua.dir/lauxlib.c.o
[ 1%] Building C object lua/src/CMakeFiles/lua.dir/lbaselib.c.o
[ 1%] Building C object lua/src/CMakeFiles/lua.dir/lbitlib.c.o
[ 2%] Building C object lua/src/CMakeFiles/lua.dir/lcorolib.c.o
[ 2%] Building C object lua/src/CMakeFiles/lua.dir/ldblib.c.o
[ 2%] Building C object lua/src/CMakeFiles/lua.dir/liolib.c.o
[ 3%] Building C object lua/src/CMakeFiles/lua.dir/lmathlib.c.o
[ 3%] Building C object lua/src/CMakeFiles/lua.dir/loslib.c.o
[ 4%] Building C object lua/src/CMakeFiles/lua.dir/lstrlib.c.o
[ 4%] Building C object lua/src/CMakeFiles/lua.dir/ltablib.c.o
[ 5%] Building C object lua/src/CMakeFiles/lua.dir/loadlib.c.o
[ 5%] Building C object lua/src/CMakeFiles/lua.dir/linit.c.o
[ 5%] Building C object lua/src/CMakeFiles/lua.dir/lapi.c.o
[ 6%] Building C object lua/src/CMakeFiles/lua.dir/lcode.c.o
[ 6%] Building C object lua/src/CMakeFiles/lua.dir/lctype.c.o
[ 7%] Building C object lua/src/CMakeFiles/lua.dir/ldebug.c.o
[ 7%] Building C object lua/src/CMakeFiles/lua.dir/ldo.c.o
[ 8%] Building C object lua/src/CMakeFiles/lua.dir/ldump.c.o
[ 8%] Building C object lua/src/CMakeFiles/lua.dir/lfunc.c.o
[ 8%] Building C object lua/src/CMakeFiles/lua.dir/lgc.c.o
[ 9%] Building C object lua/src/CMakeFiles/lua.dir/llex.c.o
[ 9%] Building C object lua/src/CMakeFiles/lua.dir/lmem.c.o
[ 10%] Building C object lua/src/CMakeFiles/lua.dir/lobject.c.o
[ 10%] Building C object lua/src/CMakeFiles/lua.dir/lopcodes.c.o
[ 10%] Building C object lua/src/CMakeFiles/lua.dir/lparser.c.o
[ 11%] Building C object lua/src/CMakeFiles/lua.dir/lstate.c.o
[ 11%] Building C object lua/src/CMakeFiles/lua.dir/lstring.c.o
[ 12%] Building C object lua/src/CMakeFiles/lua.dir/ltable.c.o
[ 12%] Building C object lua/src/CMakeFiles/lua.dir/ltm.c.o
[ 13%] Building C object lua/src/CMakeFiles/lua.dir/lundump.c.o
[ 13%] Building C object lua/src/CMakeFiles/lua.dir/lvm.c.o
[ 13%] Building C object lua/src/CMakeFiles/lua.dir/lzio.c.o
Linking C static library liblua.a
[ 13%] Built target lua
Scanning dependencies of target domoticz_gch
[ 14%] Generating stdafx.h.gch/.c++
[ 14%] Built target domoticz_gch
Scanning dependencies of target sqlite
[ 15%] Building C object sqlite/CMakeFiles/sqlite.dir/sqlite3.c.o
Linking C static library libsqlite.a
[ 15%] Built target sqlite
Scanning dependencies of target revisiontag
-- Found Git: /usr/bin/git (found version "1.7.10.4")
[ 15%] Built target revisiontag
Scanning dependencies of target mqtt
[ 16%] Building CXX object MQTT/CMakeFiles/mqtt.dir/mosquittopp.cpp.o
[ 16%] Building C object MQTT/CMakeFiles/mqtt.dir/mosquitto.c.o
[ 17%] Building C object MQTT/CMakeFiles/mqtt.dir/logging_mosq.c.o
[ 17%] Building C object MQTT/CMakeFiles/mqtt.dir/memory_mosq.c.o
[ 18%] Building C object MQTT/CMakeFiles/mqtt.dir/messages_mosq.c.o
[ 18%] Building C object MQTT/CMakeFiles/mqtt.dir/net_mosq.c.o
[ 18%] Building C object MQTT/CMakeFiles/mqtt.dir/read_handle.c.o
[ 19%] Building C object MQTT/CMakeFiles/mqtt.dir/read_handle_client.c.o
[ 19%] Building C object MQTT/CMakeFiles/mqtt.dir/read_handle_shared.c.o
[ 20%] Building C object MQTT/CMakeFiles/mqtt.dir/send_client_mosq.c.o
[ 20%] Building C object MQTT/CMakeFiles/mqtt.dir/send_mosq.c.o
[ 21%] Building C object MQTT/CMakeFiles/mqtt.dir/socks_mosq.c.o
[ 21%] Building C object MQTT/CMakeFiles/mqtt.dir/srv_mosq.c.o
[ 21%] Building C object MQTT/CMakeFiles/mqtt.dir/thread_mosq.c.o
[ 22%] Building C object MQTT/CMakeFiles/mqtt.dir/time_mosq.c.o
[ 22%] Building C object MQTT/CMakeFiles/mqtt.dir/tls_mosq.c.o
[ 23%] Building C object MQTT/CMakeFiles/mqtt.dir/util_mosq.c.o
[ 23%] Building C object MQTT/CMakeFiles/mqtt.dir/will_mosq.c.o
Linking CXX static library libmqtt.a
[ 23%] Built target mqtt
[ 23%] Building CXX object CMakeFiles/domoticz.dir/main/stdafx.cpp.o
c++: internal compiler error: Erreur de segmentation (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
make[2]: *** [CMakeFiles/domoticz.dir/main/stdafx.cpp.o] Erreur 4
make[1]: *** [CMakeFiles/domoticz.dir/all] Erreur 2
make: *** [all] Erreur 2
And if I download the tar file on your download page, I have the following error :
./domoticz: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by ./domoticz)
./domoticz: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by ./domoticz)
Thank you for your help
Best regards
Stéphane
Best regards
Stéphane
