Dimming, how to go back to former state
Posted: Wednesday 23 November 2016 18:31
I'm very new to Domoticz and LUA. Although I had an education in programming (1985-1993) in Basic and GWBasic, this is a little bit different.
I want to make a script that turns a dimmer back to it's former state.
I want to dim the spots in my kitchen to 5% when I activate all other lamps in my livingroom. (this is easy with a standard Scene or Group).
So this is not the problem.
Now when I'm in the kitchen I activate a swith to turn the spots to 100%. When I leave the kitchen and press the 'off-switch' the spots goes out. But I want them to turn back to 5%.
When the lamps in the room aren't ON (group is off by switch). And I enter the kitchen and push the switch the spots must go to 100%, and when I put the switch off, the spots have to go OUT (because the roomlamps are OUT also)
How should I make this script? When I see a working script, I'll understand LUA much better and will be able to solve this kind of problems much more easier...
Thanks in advantage,
Hein Melissen (the Netherlands)
