Increase Output time for command
Posted: Wednesday 23 November 2016 13:37
by mavhack
Is there anyway to increase the output timing to produce a longer period?
I have several Energenie light switches, they will turn off, not a problem, but wont turn on. On the Energenie remote, I have to hold the on button for about 2 seconds for them to activate. Apparently this is normal. The pulse from Domoticz and RFX is too short.
Simon
Re: Increase Output time for command
Posted: Thursday 24 November 2016 14:04
by DJBenson
I've got a couple of Energenie MIHO002 (the single sockets) and a MIHO005 (the 4-gang socket) and I get similar issues, the MIHO002's will sometimes turn off but not on again (of the 3 only 1 exhibits this behaviour) whilst the MIHO005 will sometimes be completely unresponsive until I use the green button on the device to turn all the sockets off and back on again.
I was putting this down to an issue with the signal strength but one socket (probably the most hidden one) always responds correctly where the others (visible in the same room) do not, so I wonder if it's the issue you describe.
