Play Audio alert / Sound using the 3.5 MM Raspberry Pi connector
dutchnld
Domoticz version: 3.5974
Post by dutchnld »
Hi All,
I've been looking all over the forum but couldnt find anything related to my wish...
I'd like to use the 3.5MM audio output of the raspberry pi to play a sound (whatever) when something happens.
How can you trigger a sound when a (virtual) switch turns off/on?
Preferably a long sound, but if it can play a defined .wav or .mp3 thats flexible using the right file.
Usage examples:
- Your door sensor is activated after 2AM, while your sleeping -> Sound alert!
- A button or dummy switch is activated -> you get a (happy) sound alert. (Dishwasher is ready, at a certain time (alarm), etc ...)
I really hope that one of you was able to control the audio-output of a Pi using Domoticz!
Raspberry Pi Model 2 B w/ Domoticz 3.5974 + Monit + Pi-Hole + RaZberry Z-wave module + RFXcom 433 USB
trixwood
Re: Play Audio alert / Sound using the 3.5 MM Raspberry Pi connector
Post by trixwood »
Script the notification yourself :-)
Setup your pi for sound...
http://www.raspberrypi-spy.co.uk/2013/0 ... ine-audio/
Create your own script file in the script folder... use aplay :-) or any of the alternatives...
something like
#!/bin/bash
aplay ~/Luftalarm.wav
(with the right location/name of the music file & player commando...)
Fill it in into Settings->Notification->Custom HTTP/Action (or create a virtual sensor which triggers the script)
And you got what you want...
dutchnld
Post by dutchnld »
Hi trixwood,
Thanks a lot for your suggestion!
With your advice I only got halfway unfortunately.
I'm able to execute a script and play a .wav file perfectly, using the commandline.
Both a .sh and .pl script work.
/home/pi/domoticz/scripts/wavtest.sh
/home/pi/domoticz/scripts/wavtest.pl
But when I enter it in a dummy switch nothing happens.
I use this url in the on/off action:
script:///home/pi/domoticz/scripts/wavtest.sh
or
script:///home/pi/domoticz/scripts/wavtest.pl
Normal domoticz log (error log is empty!):
2016-11-27 22:47:09.252 User: jonas initiated a switch command (410/AlarmScript/On)
2016-11-27 22:47:10.222 Executing script: /home/pi/domoticz/scripts/wavtest.sh
2016-11-27 22:47:11.301 User: jonas initiated a switch command (410/AlarmScript/Off)
2016-11-27 22:47:12.292 Executing script: /home/pi/domoticz/scripts/wavtest.pl
2016-11-27 22:47:13.253 User: jonas initiated a switch command (410/AlarmScript/On)
2016-11-27 22:47:14.239 Executing script: /home/pi/domoticz/scripts/wavtest.sh
Contents of my script:
#!/bin/bash
aplay ~/police_s.wav > /dev/null 2>&1 &
I tried the following:
- changed permissions with sudo chmod +x wavtest.sh (and wavtest.pl)
- changed owner with
sudo chown pi:pi wavtest.pl
sudo chown pi:root wavtest.pl
- changed your script by adding /dev/... (read it in the forum)
- even tried to run the .pl file with a .sh file (works in command line)
Any help is greatly appreciated!
trixwood
Post by trixwood »
replace
with
script://wavtest.sh
script:// points to the script folder of domoticz :-)
oopee
Domoticz version: 3.x
Post by oopee »
If above (script path) does not help, try to include full path to aplay in your script.
dutchnld
Post by dutchnld »
Hi trixwood and oopee,
i tried both your suggestions but still no sound. :(
First I changed the path and tried my dummy switch -> nothing
Then I got into the commandline and typed 'which aplay' and it returned /usr/bin/aplay
So I changed the script to:
#!/bin/bash
/usr/bin/aplay ~/police_s.wav > /dev/null 2>&1 &
My log is still showing no errors and gives this:
2016-11-28 19:51:15.049 User: Admin initiated a switch command (410/AlarmScript/Off)
2016-11-28 19:51:16.019 Executing script: /home/pi/domoticz/scripts/wavtest.sh
2016-11-28 19:51:17.190 User: Admin initiated a switch command (410/AlarmScript/On)
2016-11-28 19:51:18.173 Executing script: /home/pi/domoticz/scripts/wavtest.sh
What I would like to do is have the most simple (hello world?) script to check if the combination of my dummy-switch and the script really works.
Then I only have to focus on the audio script, which then only works in command line.
Thanks again!
pvm
Domoticz version: 4.10538
Post by pvm »
When the script is executed by any other user than pi it will not find the sound file. Replace the ~/ with the full path: /home/pi/
dutchnld
Post by dutchnld »
@pvm you are the (wo)man of the day!!!
problem is solved by adding the full path of the .wav file.
After that I also removed the full path of aplay and it still works.
Final script:
#!/bin/bash
aplay /home/pi/police_s.wav > /dev/null 2>&1 &
Usage examples:
- cat entered the house after 9PM (so i can close the lock and won't find dead birds/mice on the stairs they catch in the middle of the night)
- email from specific person/company arrives (it opens a virtual switch via outlook run a program) and can now play a sound!
- when a burglar enters the house it plays a nasty loud noise (although they know where my Pi is then....)
- the doorbutton is pressed and a sound plays (cheap extra doorbel this way) ( i have 2 clickonclickoff doorbells around the house)
- and probably many more i find useful later....
capman
Post by capman »
A want the same thing. But my domoticz is running on a synology , and a running max2play on a seperate raspberry pi. A think that a just use the script and change it to the ip adres of the rpi ?
pvm
Post by pvm »
I'm not a max2play expert but I guess you have to clear the current playlist and put the required track in?
EDsteve
Post by EDsteve »
i am working on something similar. Sound should play after event triggers. My script as posted in this threat:
#!/bin/bash
aplay /usr/share/sounds/alsa/Front_Center.wav  > /dev/null 2>&1 &
The script runs perfectly from the command line with sudo.
But domoticz just shows this without error or sound:
2017-01-20 18:51:41.964 Executing script: /home/fa/domoticz/scripts/creepsound.sh
SOLUTION:
my user was not in the audio group.
For linux noobs like me:
sudo usermod -g <audio> username
MCPXXL
Post by MCPXXL »
Hello
I am really new in pi and scripting as a windows user
I have the same problems like the other or better more of them because everything is a miracle atm
So i got running my aplay script from command prompt with ./mp3.sh on my usb audio
#!/bin/bash
sudo aplay ~/mp3/bob_marley-a_la_la_la_la_long_v2.wav  > /dev/null 2>&1 &
exit 0
On command prompt i run this without messages and sound plays until it ends
pi@raspberrypi:~/domoticz/scripts$ /home/pi/domoticz/scripts/mp3.sh
On Activation:
script:///home/pi/domoticz/scripts/mp3.sh
After a lot of 256 errors i now get this shown in log
2017-03-06 15:20:10.314 Executing script: /home/pi/domoticz/scripts/mp3.sh
But no sound is to hear :-(
Is there any idea what the hell i am to stupid for ?
MCPXXL
Post by MCPXXL »
no one any idea ?
OTiby
Post by OTiby »
I've the same problem
Everything is standard, followed: https://www.raspberrypi-spy.co.uk/2013/ ... ine-audio/
I hear the sound when I run in the command line:
But when I make a dummy switch in Domoticz and add as 'On Action':
script://aplay/home/pi/police_s.wav > /dev/null 2>&1 &
It doesn't work, I don't hear any sound
In Domoticz I use a user: admin
OTiby
Post by OTiby »
Found it,
The script wasn't executable yet..
But now I've another problem, when the music plays, domoticz doesn't execute other events.
So I want to flash a light, it wait till the music is ended.
But in the event maker I set them on at the same moment.. :S
Is the rpi or domoticz not capable to execute this together?
lost
Post by lost »
OTiby wrote: Wednesday 07 November 2018 18:48 The script wasn't executable yet..
1: Your script call line is directly using aplay (not a .sh script file with this line inside): How can aplay be installed without +x rights?
2: Not sure, directly calling aplay, you're last & for running the sound in background is taken into account.
Try making a true script file, with commands launched from it in background when needed, so Domoticz event system does not have to wait till you're command end before going ahead.
I have such speech synthesis notifications (using espeak) that for sure do not lock Domoticz when processed (they are indeed sometimes mixed together when they overlap)!
Futuro135
Post by Futuro135 »
Hi all!
I want domoticz notifications to play through google home mini.
I paird raspberry pi and google home mini.
I made a script that plays an audio file. If I run it from the terminal, then the sound plays in google home. If the script is launched from Domoticz, then the sound plays through the built-in sound card.
Can anyone suggest what to do?
Here is the script
#!/bin/bash
/usr/bin/mplayer -ao alsa /home/pi/mysound.mp3 > /dev/null 2>&1
Remco
Post by Remco »
Hi There, I've got the same script as above; when using in terminal the sounds play well, also on the good 3,5 mm output. only when I want to activate the script in Domoticz it shows in the log that its executed but the sound isn't playing over te speakers on that 3,5mm output. I read something about user rights for the audio group, but which user should I add? Pi and root is recently added and didn't fix the problem.
