Performance of LUA scripting
felix63
Domoticz version: 2020.1
Post by felix63 »
I am curious as to your experiences in regard to the running of scripts. As far as I can tell there are a couple of ways to automate things in Domoticz.
  • - Blocky scripts
    - File System based lua scripts
    - Database based lua scripts
    - lua scripts using dzVents
as well as PHP, Bash, Perl and Python scripts.
What is your experience with regards to performance issues? Specifically with the 3 different lua options? I kind of preferred the Database based option because of the ease of use and the automatic backup. But I've been reading some post discussing the benefits of alternative solutions but haven't quite found the ultimate answer.
Currently I have about 30 (blocky and lua) scripts in my database. What is your opinion?
cheers,
Lex
Egregius
Domoticz version: v2024.7
Re: Performance of LUA scripting
Post by Egregius »
Test it ;)
Make a blockly/lua/file with a name script_device_zzzzzz ( so it's executed last)
Let the script trigger a light by a pir and look at the difference in time between pir line and switch command.
On my syno I noticed that file based scripts are slightly faster than the ones in database.
And that even empty script cause a delay.
That's the main reason for me to only use 1 lua script. My reaction time went down from 800-1200msec to 42msec!
deennoo
Post by deennoo »
Egregius PHP script is very fast, that true, but need some good knowledge on PHP if you are familliar with PHP that THE solution (his website is a good source)
Another solution :
run http command via LUA, because http request are fast
Not fast as Egreguis script but, fast as you can get a 200% better WAF
ICan provid you elements if you want (a simple lua parser + some new command on lua script) : http://easydomoticz.com/forum/viewtopic ... 706cb2242a
I notice differentes elements to :
chacon 433 switch module are slow and send order 2 times then if you need to drive another 433 modules this take time
chinese door contact/motion sensor + zwave module give fast answer
chinese door contact/motion sensor + milight bulb drive with rflink are fast as lightspeed
http://domo-attitude.fr
heggink
Domoticz version: 12451
Post by heggink »
I switched from Blocky to Lua recently because of the memory issue with blocky causing my system to run out of memory after a few days. Unfortunately, I replaced the blocky's 1:1 with lua script files to then find that 1) domoticz seems single threaded and 2) with 40+ scripts keeps an RPI3 core 90% busy easily. The whole system was sluggish at best and usually downright slow.
After reading this, I consolidated the 42 lua scripts into 6 bigger scripts with lots of elseif's (tricky not to miss events).
Net result is that:
- domoticz hardly gets above 20% and typically hovers around 5-15%
- alexa no longer complains about devices not responding
- everything is a lot snappier
In hindsight it makes sense since I have inputs from 10 plugwise plugs, solar panels, a bunch of zwave plugs, a buncf of PIRs, a bunch of cameras, a p1 'smart'meter generating updates every 10 seconds and so on so masses op inputs every time triggering 42 lua scripts but then, hindsight is an exact science I guess.
Many thanks for this thread. Much happier now! :D :) :mrgreen:
H
P1 meter & solar panel
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
heggink wrote:I switched from Blocky to Lua recently because of the memory issue with blocky causing my system to run out of memory after a few days. Unfortunately, I replaced the blocky's 1:1 with lua script files to then find that 1) domoticz seems single threaded and 2) with 40+ scripts keeps an RPI3 core 90% busy easily. The whole system was sluggish at best and usually downright slow.
Net result is that:
H
Are you sure that a script isn't triggered constantly?
5 to 15% on a Pi sounds like it does and for a Pi3 i bit high.
A pi3 should almost run idle with domoticz.
i have 35 scripts running and overhere it's hovering from 0.4 to max 0.75
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
heggink
Post by heggink »
Not that I have been able to see. Mind you, I dont use the motherboard sensors but track system and domoticz cpu usage myself. System is indeed nearly idle but domoticz usage only uses 1 core so 5-15% is in a single core. With 230+ devices many of which update constantly, I am not surprised with the current cpu usage. Thanks for the feedback btw.
Tieske
Post by Tieske »
Just stumbled on this thread while browsing the forum.
I've only recently started with Domoticz, and one of the things I'm wondering is when the scripts (either Blockly or Lua) get triggered. From what I read above, the scripts get triggered on EVERY event. Is that correct?
commentator
Post by commentator »
Tieske wrote: Saturday 18 March 2017 9:31 Just stumbled on this thread while browsing the forum.
the device scripts are, the time not
heggink
Post by heggink »
Lua yes, dzvents no.
