Read from another database
fantilator
Domoticz version: 3.5877
Post by fantilator »
I'm having a TE923 compatible weatherstation runnin and login onto my Synology NAS,
instead of configuring it to work with Domoticz, is it possible to pull the data from the database?
I also have a corporate database who captures data from other sensors offsite.
If the possibility is hete to pull data from the database then I can automate more stuff.
Kind regards.
Egregius
Domoticz version: v2024.7
Re: Read from another database
Post by Egregius »
If you can access the database you can retrieve and sent every data you want.
just create a script that pulls the data and sends it to Domoticz and run it by cron.
Last edited by Egregius on Saturday 19 November 2016 23:43, edited 1 time in total.
fantilator
Thanks for the information,
Do you have any clue on how to script this?
Unfortunately Googling does not show examples.
Egregius
Post by Egregius »
Is Domoticz on the same Syno as the database?
The database is a MySQL database in MariaDB?
Do you know something about PHP?
I can only help in PHP, that's the only language I know.
fantilator
Yes, my domoticz runs on the same Syno. Database is indeed Mariadb
I have no experience in PHP.
Thank you
MauraMClark
Post by MauraMClark »
I have a corporate database too. I work at https://help.plagtracker.com/resume-editing.html and I'm searching for any help to structure it. All I knew about it before does not work, thanks for ideas.
jenniehaleyson
Post by jenniehaleyson »
Please could you share at least short instructions on this item? I do not quite understand the sequence of actions.
