I have a Raspberry pi 3 with an Aeon Z-Stick gen 5 connected in USB.
2 Aeon Smart switch
When i use Domoticz, i can see my 2 smart switch, and make on or off.
However, never the Volt and current measure are updated. Or only if i go in node management and i refresh info.
One of my Aeon Smart swith is plugged in the wall with a pumpe.
This pump turn on minimum 10 time per day.
This never appear on my graph... no measure of Volt, Watt, ...
What must i do for the measure update automaticaly when pumpe run ?
Measurement doesn't work
- emme
- Domoticz version: latest
Re: Measurement doesn't work
can you show parameter 101 for you smartswitch?
it sholud be setted to 15(default 0 - no report) to return Volt / Ampere / Watt (incl. kWh counter)
"We always done this way"
