Best way to control devices
Posted: Thursday 17 November 2016 10:45
Hi!
What's the best way to send http control command to devices in lua scripts?
I'm currently using "openurl"
My devices often are unreachable (bad wifi, chip crash etc)
I think this eventually is making domoticz unstable.
There must be a way for domoticz to control devices that doesn't lead it to eventually crash when those devices are unreachable surely?
(By crash I mean the web ui stops responding, the error log then starts showing domoticz folders as missing etc)
Example of scripts:
commandArray = {};
IP = '192.168.2.170';
Port = '80';
GPIO = 3; -- r=0,g=1,b=2,w=3
DomDevice = 'Bathroom Ceiling Lamp'
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
print("Turning OFF with openurl " .. DomDevice)
commandArray['OpenURL']="http://" .. IP .. ":" .. Port .. "/control?cmd=PWMFADE," .. tostring(GPIO) .. ",0,1"
elseif (devicechanged[DomDevice]=='On') then
print("Turning On with openurl value : " .. tostring(uservariables[DomDevice]))
otherdevices_svalues[DomDevice] = tostring(uservariables[DomDevice])
commandArray['OpenURL']="http://" .. IP .. ":" .. Port .. "/control?cmd=PWMFADE," .. tostring(GPIO) .. "," .. tostring(tostring(uservariables[DomDevice]*10+0)) .. ",1" -- new dimmers now do 0-100!
print("Value openurl sent from domoticz is : " .. otherdevices_svalues[DomDevice])
uservariables[DomDevice] = otherdevices_svalues[DomDevice]
commandArray['Variable:'..DomDevice] = uservariables[DomDevice]
end;
commandArray = {};
DomDevice = 'House Thermostat';
IP = '192.168.2.180'
Port = '80'
function send(msg)
runcommand = "echo "..string.char(34).."POST "..msg.. " HTTP/1.1"..string.char(13)..string.char(10)..string.char(13)..string.char(10)..string.char(34).."| telnet "..IP.." "..Port.." "
print (runcommand)
os.execute(runcommand)
commandArray['OpenURL']="http://" .. IP .. ":" .. Port .. "/control?cmd=thermoset," .. tostring(otherdevices_svalues[DomDevice])
print("Thermoset Rads Set :" .. tostring(otherdevices_svalues[DomDevice]))
Cheers for any ideas!
Example of scripts:
commandArray = {};
Port = '80';
end;
commandArray = {};
Port = '80'
function send(msg)
print (runcommand)
