Hello.
I need help. I've bought new Zwave Usb controler because my old Fibaro HTC1 was not good enough and I using it for VPN Server.
Domoticz (ver. 3.5877) sits on Raspberry Pi2 (next to OSMC). I'm using Zwave Usb - ZME UZB1 and "OpenZwave" on Raspberry Pi.
All Fibaro Dimmers were found by domoticz and working as they should. However I would like to use S2 option in Dimmers to switch on second Dimmer on the other side of my room... (Same as it was working with HTC1). On this forum I found that I have to change "Scene activation functionality: to Functionality Activated" but no matter how many trials I've made it stays on "Functionality Deactivated".
In OpenZwave Control Panel same thing... Log sais
"Error, Node005, ERROR: Dropping command, expected response not received after 1 attempt(s)"
Any idea what I shuuld do with this?
Cheers.
Domoticz - Fibaro S2 - Bi Stable switch
- emme
- Domoticz version: latest
Re: Domoticz - Fibaro S2 - Bi Stable switch
your problem seems to be more zWave network related in device assosiacion/reachability than domoticz configuration
try to remove the 2 dimmers and reinclude them and see what's happend
"We always done this way"
Still the same. Unfortunate only ID changed and it is not in order anymore.
