Doorbird doorbell
Posted: Wednesday 16 November 2016 11:53
by Shrimp
I have installed a Doorbird doorbell and would like to integrate it in Domoticz.
They do have a public lan API (
https://www.doorbird.com/api) but I lack the programming skills/knowledge to get any further.
I would like Domoticz to be aware when someone presses the doorbell (so that it can switch on the light in the hallway).
The API says that i should be able to do a notification request:
Method: GET
Syntax: http://<device-ip>/bha-api/notification.cgi?<parameter>=<value>
They also provide an example:
http://<deviceip>/bha-api/notification.cgi?url=http://foo.bar?doorbell&user=&password=&event=doorbell&subscribe=1
Does anyone have a suggestion on how to use this within Domoticz?
Re: Doorbird doorbell
Posted: Wednesday 16 November 2016 17:28
by borgkitty
(I haven't read the api yet this is just me guessig)are you able to put anything into this?
Syntax: http:// <device-ip>/bha-api/notification.cgi?<parameter>=<value>
what I mean is can you put anything into the parameter? because if you can it would be relative easy to do this
you would set up a dummy switch in domoticz and remember the idx
then within that get you would push it to your server with something similar to json.htm?type=command¶m=udevice&idx=(dummy device idx&nvalue=(on or off or whatever you want)&svalue=79
following the json api of domoticz
https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
Posted: Wednesday 16 November 2016 18:03
by gizmocuz
Seems on Page 7 of the manual you can set a notification URL, in this URL you just do a domoticz json call to a switch to put this on (or a doorbel sensor)
Posted: Wednesday 04 January 2017 21:15
by bmwproboi05
gizmocuz wrote:Seems on Page 7 of the manual you can set a notification URL, in this URL you just do a domoticz json call to a switch to put this on (or a doorbel sensor)
Thanks for the hint to get this working...
Here is what I did to get mine to get the doorbell rang notification
http://<doorbird-ip>/bha-api/notification.cgi?url=http://localhost:8080/json.htm?type=command%26param=switchlight%26idx=5%26switchcmd=On&event=doorbell&subscribe=1
The %26 is used to subsitute the & sign. The doorbird uses & to move on... Here is the response I get back
{"BHA": { "RETURNCODE": "1", "NOTIFICATIONS": [{"event": "doorbell","subscribe": "1","url": "
http://localhost:8080/json.htm?type=com ... =On","user": "","password": "","relaxation": "10"}]}}
<doorbird -ip> - the ip address of the doorbird
localhost - ip of domoticz install. If you are on windows you will need to allow access on your firewall in pc settings. ( I tested this on my pc before moving over to Rpi)
I am trying to see what else I can get working , and will probably make a new post
Posted: Monday 30 January 2017 18:54
by sulley
Is this working well for you? I installed a DoorBird a couple of weeks and I'm finding that the notifications don't fire much of the time. They seem to cycle on and off every couple of days. I've tried rebooting the unit, resetting and re-entering the notifications and triggering a non-Domoticz device and I am sure they are simply not working.
Posted: Saturday 25 February 2017 19:11
by paultie
Just installed the doorbird and this did the trick for me switching based on the motionsensor.
Did a blocky to set the switch to off after a certain time which is the same time of the doorbird for the motion sensor minus 1 second so that there is no conflict.
There is more possible with the API but just started xperimenting with this.
Regards,
Paul
Posted: Saturday 24 February 2018 11:49
by Thomasdc
I am also looking in to this doorbird doorbell.
i was wondering, is it also possible to send notifications to domoticz when there is movement? or only when the doorbell is pushed?
is there an delay on the notifications or is it responding really fast?
Posted: Tuesday 27 February 2018 17:22
by sulley
Yes you can just change event=doorbell to event=motionsensor (but I haven't actually tested this). The response is very fast. I have Domoticz emailing me a capture from the DoorBird camera whenever the button is pressed.
My issue from last year (see earlier post) turned out to be a faulty unit but since getting the new one it's worked perfectly.
Posted: Wednesday 10 October 2018 4:52
by Neuvidor2307
Dear all,
I just want to share my script I'm using in order to receive Doorbird pictures on my smartphone over Telegram when somebody press the doorbird button.
How it works :
- I defined in the doorbird application a HTTP command into favorite. This command activate a domoticz "Push ON" button
http://192.168.xxx.xxx:8063/json.htm?type=command¶m=switchlight&idx=79&switchcmd=On
- I defined in domoticz the "Push ON" button parameters in order to execute a "Doorbell.sh" script when the "Push ON" button is activated
script:////home/pi/domoticz/scripts/Doorbell.sh
- The Doorbell.sh script is called by Domoticz, it automatically send a telegram to me and my wife's smartphone with 3 pictures
=> First picture correspond to the picture stored into the doorbird memory when the doorbell was pressed
=> Second picture is taken 2s after doordbird button is pressed with live request
=> Third picture is taken 4s after doordbird button is pressed with live request
#!/bin/bash
Doorbell.sh script
## Doorbell.sh script ##
## Send Doorbird D101S pictures to telegram message script ##
# Telegram configuration
TelegramUser01="Activated"
TelegramUser02="Desactivated"
TelegramUser03="Desactivated"
Token_1="xxxxxxxxx:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
Token_2="xxxxxxxxx:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
Token_3="xxxxxxxxx:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ChatID1="xxxxxxxxx"
ChatID2="xxxxxxxxx"
ChatID3="xxxxxxxxx"
# Doorbird D101S configuration
DoorbirdIP="xxx.xxx.xxx.xxx"
DoorbirdLogin="xxxxxx0001"
DoorbirdPassword="xxxxxxxxxx"
DoorbirdUrlImage="http://$DoorbirdIP/bha-api/image.cgi?http-user=$DoorbirdLogin&http-password=$DoorbirdPassword"
DoorbirdUrlHistory="http://$DoorbirdIP/bha-api/history.cgi?index=1&http-user=$DoorbirdLogin&http-password=$DoorbirdPassword"
# Snapshot configuration
SnapFile1="/var/tmp/DoorbirdSnapshot1.jpg"
SnapFile2="/var/tmp/DoorbirdSnapshot2.jpg"
SnapFile3="/var/tmp/DoorbirdSnapshot3.jpg"
PauseBetweenSnap=2
#Script beginning
# send telegram (text only)
if [ "$TelegramUser01" == "Activated" ]
then curl -s -X POST "https://api.telegram.org/bot$Token_1/sendMessage?chat_id=$ChatID1&text=Baptiste, Quelqu'un vient de sonner à la porte !"
fi
if [ "$TelegramUser02" == "Activated" ]
then curl -s -X POST "https://api.telegram.org/bot$Token_2/sendMessage?chat_id=$ChatID2&text=Noémie, Quelqu'un vient de sonner à la porte !"
fi
if [ "$TelegramUser03" == "Activated" ]
then curl -s -X POST "https://api.telegram.org/bot$Token_3/sendMessage?chat_id=$ChatID3&text=Quelqu'un vient de sonner à la porte !"
fi
# get second Picture
wget -O $SnapFile2 $DoorbirdUrlImage
# pause
sleep $PauseBetweenSnap
# get another Picture
wget -O $SnapFile3 $DoorbirdUrlImage
# pause
# get first Picture
wget -O $SnapFile1 $DoorbirdUrlImage
# send telegram (multiple pictures) to user 1
then curl -s \
-X POST "https://api.telegram.org/bot"$Token_1"/sendMediaGroup" \
-F chat_id=$ChatID1 \
-F media='[{"type":"photo","media":"attach://photo_1","caption":"When Doorbell button was pressed"},{"type":"photo","media":"attach://photo_2","caption":"Other picture 1"},{"type":"photo","media":"attach://photo_3","caption":"Other picture 2"}]' \
-F photo_1="@$SnapFile1" \
-F photo_2="@$SnapFile2" \
-F photo_3="@$SnapFile3"
fi
# send telegram (multiple pictures) to user 2
then curl -s \
-X POST "https://api.telegram.org/bot"$Token_2"/sendMediaGroup" \
-F chat_id=$ChatID2 \
fi
# send telegram (multiple pictures) to user 3
then curl -s \
-X POST "https://api.telegram.org/bot"$Token_3"/sendMediaGroup" \
-F chat_id=$ChatID3 \
fi
# Delete all pictures
rm $SnapFile1
rm $SnapFile2
rm $SnapFile3
