wunderground error
Posted: Tuesday 15 November 2016 18:24
by gennapium
After updating to the last beta is get the error:
2016-11-15 18:20:45.059 Error: WUnderground: Invalid data received, or no data returned!
But when using the test from the wiki with the api key and location it is working fine.
Any idea what is going wrong ?
Re: wunderground error
Posted: Tuesday 15 November 2016 18:54
by Siewert308SW
gennapium wrote:Hi,
Same here,
Sollution is to change your weather station name.
Before updating i used IGRONING16 as station id.
I changed it to pws:IGRONING16 under Settings->Hardware->your weatherunderground station
Posted: Tuesday 15 November 2016 19:01
by gennapium
I use gennep (my hometown) as location, setting it to pws:Gennep doen't do the trick. Also just updated to 3.5921. Also not the solution.
Posted: Tuesday 15 November 2016 19:05
by gennapium
Great,
Just updated location to pws:IHEIJEN2 and now it is working !!
Posted: Tuesday 15 November 2016 19:06
by Siewert308SW
gennapium wrote:I use gennep (my hometown) as location, setting it to pws:Gennep doen't do the trick. Also just updated to 3.5921. Also not the solution.
Gennep is a global name and when used it will seek the nearnest station.
New beta forces to use one station instead of several.
So you need the pws id for you station which is not gennep
for example:
pws:ILIMBURG180
edit: see you already found the right pws id...
Posted: Saturday 26 November 2016 17:52
by Grobbebol
Thanks for the tip..
I had the same problem after the update. Changed "Veendam" to pws:IGRONING56 under "Instellingen"-> Hardware -> Weather Underground and than the tab "Locatie". Everything OK now.
Posted: Sunday 27 November 2016 0:59
by guantolento
good evening,
i take the same solution, but in the log i have always the same error:
now i setting the psw:IBERGAMO2
in the log i find the follow error:
"2016-11-27 00:46:17.407 Error: WUnderground: Invalid data received, or no data returned!"
my version is the latest beta i find V3.5985
tomorrow i control the log again. bye bye.
Posted: Sunday 27 November 2016 9:31
by bizziebis
WU is not reliable anymore for the last month. If they don't get their system sorted out we better search for an alternative.
Posted: Sunday 27 November 2016 9:52
by schulpr
It should be PWS in stead of PSW.
Verzonden vanaf mijn iPad met Tapatalk
Posted: Sunday 27 November 2016 10:46
by guantolento
Posted: Sunday 27 November 2016 15:12
by guantolento
i control my log now, and after the modifie apported during this night, from about after 30 min the error log disappared and all work ok.
Posted: Sunday 27 November 2016 19:16
by Derik
bizziebis wrote:WU is not reliable anymore for the last month. If they don't get their system sorted out we better search for an alternative.
OWM ...
Is stable to..
Posted: Tuesday 03 January 2017 7:56
by forum026
I'm using pws:IARNHEM39, but have two questions about this.
1. I noticed some error messages "Error: WUnderground: Error: this key does not exist". But system is also retrieving correct data. How can I find which device (Temp/UV/Visability) is related to this error?
But in the logging I noticed that, at least some data is retreived.
2. In the Domoticz WIKI is mentioned that data is retrieved once in 10 minutes. I my logging it seems to several times within 1 minute (I got warning email from WUnderground). I could not find how to reduced this amout of requests. Can someone point me how to change this interval?
