Aeotec ZW074 MultiSensor Gen5
Posted: Monday 14 November 2016 23:24
I am using the Aeotec ZW074 MultiSensor Gen5 (outdoor sensor) with Domoticz. I have some trouble in understanding the parameter settings. For instance it says:
I do not fully understand how to do the math here and what the 25600 means.
For the next I think I get it a bit:
If I translate 1280 to a hex number it's 500. Does that then mean that at a change of 5% the report is sent?
Still for the luminance parameter that would be 25600 (10) = 6400 (16) and I can't imagine it means 64% change!?
I would be very glad if somebody could come up with some clearer explanation. Thank you!
EDIT: here's a link to a manual for the sensor: https://support.smartthings.com/hc/en-g ... manual.pdf
Yet, it doesn't help me better understand the 0x6400 value (why is it 100 LUX?). The 5% guess above seems right.
43. Luminance Reporting Threshold:
25600
(LUX) (aktuell: 25600)
Threshold change in luminance to induce an automatic report.For the next I think I get it a bit:
2. Humidity Reporting Threshold:
1280
(%) (aktuell: 1280)
Threshold change in humidity to induce an automatic report. Note: The accuracy is 0.1. The high byte is the part of integer, the low byte is the fractional part.Still for the luminance parameter that would be 25600 (10) = 6400 (16) and I can't imagine it means 64% change!?
