My temerature sensors are offline
Chelsea64
Post by Chelsea64 »
Since a time back my virtual temperatures sensors are offline. I can see in devices setup that they get temperatures values every 10 minutes. One of them are starmarked to be shown in my dashboard. In there I can read temperature . But why offline ?
Skickat från min SM-G935F via Tapatalk
Slinkos
Domoticz version: 3.4834
Re: My temerature sensors are offline
Post by Slinkos »
I had the same issue with a virtual temp. sensor that was filled via a ESP8266 that I programmed myself. Also a friend of mine had the exact same problem. Never solved it, just stopped using it.
PeM1664
Post by PeM1664 »
hi check your hardware I used to have this kind of problem and it was always hardware.
show if hardaware isn't in short circuit, in W1 is easy to make one
after
restart domoticz with
sudo /etc/init.d/domoticz.sh/ restart
or stop and start
