Script to disable/enable events
Posted: Saturday 12 November 2016 14:01
by Slinkos
I'm thinking to make a virtual switch named "Vacation" for whenever I will be gone from home for a while. My purpose of this switch that when it's on, it will disable the blocky events that I specify in the script), and enable all those events again when I turn the vacation swithc off.
Offcourse I could also rebuild al this events with the statement that "Vacation" has to be off, but I think this is a more clean solution.
Re: Script to disable/enable events
Posted: Monday 14 November 2016 22:45
by Slinkos
Is there no script to do this?
Posted: Tuesday 15 November 2016 0:37
by Domosapiens
Did you look for the possibilities of "Timer Plan" under Setup - Other?
Posted: Tuesday 15 November 2016 19:42
by Slinkos
No... I also can't find the menu you are suggesting.
Posted: Wednesday 16 November 2016 9:20
by Domosapiens
Update your version?
Posted: Wednesday 16 November 2016 11:46
by toreandre
One way would be to make your events check for the vacation switch status.
If the vacation switch is OFF then execute events, if its ON do nothing.
Posted: Wednesday 16 November 2016 18:35
by lukcinek
Slinkos wrote:Hi all,
You should add uservariable in Settings-->More Options-->User variables
Put some name of Your Variable --> MyScriptRun
Type of Variable --> Integer
Variable --> 1
You must add some LUA code to Your Events.
I paste my code that turns off my lights automatically when some time elapses and no motion is discovered.
script_time_nomotion.lua
local motion_switch = 'PiR - Kitchen'
local nomotion_uservar = 'nomotionCounter'
local status_switch = 'Lamp - ON'
local noRun = uservariables["MyScriptRun"]
local no_motion_minutes = tonumber(uservariables[nomotion_uservar])
if (otherdevices[motion_switch] == 'Off') then
no_motion_minutes = no_motion_minutes + 1
--print('<font color="red">No motion has been detected for: ' ..no_motion_minutes.. ' minutes</font>')
no_motion_minutes = 0
if tonumber(noRun) == 1 then
if otherdevices[status_switch] == 'On' and no_motion_minutes > 10 then --change the 30 to the amount of minutes you prefer
nomotion_uservar= "0"
commandArray[status_switch]='Off'
commandArray['Variable:' .. nomotion_uservar] = tostring(no_motion_minutes)
You must modify this script...sorry I don't know nothing about programming:(
You should make virtual switch (Vacation) and in field:
--> Enable action put something like this:
http://192.168.0.15:8080/json.htm?type=command¶m=updateuservariable&vname=MyScriptRun&vtype=integer&vvalue=1
--> Disable action put something like this:
http://192.168.0.15:8080/json.htm?type=command¶m=updateuservariable&vname=MyScriptRun&vtype=integer&vvalue=0
Change 192.168.0.15:8080 to Your ip and port.
In my case when I turn On my Virtual switch --> My Lua script works and my lights in kitchen Turns off when some time elapses and no motion is discovered.
When i turn Off my Virtual switch --> My lua script doesn't work and my kitchen light are turned on all the time.
Sorry for my English.
Best regards
Posted: Wednesday 16 November 2016 20:51
by Slinkos
Domosapiens wrote:Update your version?
I am on the latest stable
