thermostat secure 321
Posted: Thursday 10 November 2016 19:13
Hello .... I have 2 popp valves working properly and I have an existential doubt with the thermostat secure 321 ...
I have it integrated and working in principle correctly, but I have 2 doubts about it ...
.-1 There is an option, which by default is disabled, which is "Temperature sensor reading" ... I understand that it means "the sensor read the temperature" not? .... Are you supposed to ALWAYS read the temperature? .... so that is a thermostat hahaha .... So what sense has that option? .... and that is in disable above? .... I have put it in enable just in case ... And this Is a theoretical question ......
I remember when I was jeedom, that one of the plug-in thermostats, allowed to indicate the "operating mode" or "Algorithm" in "hysteresis" and another "temporary" Link to the operation of the plug ... http://blog.domadoo.fr/guides/plugin-th ... chauffage/ If the temostato in question works in a specific way, as it is possible to "tell" you by software that works from Other way? ..... Or am I mixing concepts? ....
The thermostat is secure, so I put it in the manual and I read it out there, it's type TPI (Integral Proportional Time) ..... So Of "time", if it was in jeedom, you should select the option of operating mode "temporary" not? ... In Domoticz is not selectable this topic or as it is ... According to the plugin of jeedom, if you put it in "Time" mode ...: In the case of the time mode, the control of the heating or cooling is set to a predetermined cycle and the execution of the length of the command is a function of the difference between the set point and The temperature measured by the sensor. The algorithm will also calculate the heating (or cooling) time during a cycle as a function of inertia and room insulation.
I have noticed that it puts "... And the temperature measured by the sensor" ..... this is not in direct relation with the option that I put "disable" of "Temperature sensor reading": ... Equal I'm "spinning very thin" but since we spend in these toys, that unless they save us something not? Jejeje I configured the DIP of the thermostat as the manual indicates, for gas boiler, but nothing more ...
I´m from Spain, and the text is trasnlated from "google traslator"... sorry
Thanks...
Thanks...
