My 1-wire barometer is lost since I updated domoticz to the lastest stable (5837) on my raspi.
I can see the device in /mnt/1wire. I see temperature of the device in domoticz, but not the pressure.
My barometer is an old hobby-boards barometer, with pressure in in the following subfolder:
pi@rpi-rfx /mnt/1wire/26.E07ABC000000/B1-R1-A $ ls -l
total 0
-rw-rw-rw- 1 root root 12 Nov 5 20:27 gain
-rw-rw-rw- 1 root root 12 Nov 5 20:27 offset
-r--r--r-- 1 root root 12 Nov 5 20:27 pressure
I also noticed that the humidity is also lost in the same update.
Is it possible to get it back as it used to or should I make a virtual sensor and use it to read the data?
Here is the directory structure:
pi@rpi-rfx /mnt/1wire/26.E07ABC000000 $ ls -l
total 0
-r--r--r-- 1 root root 16 Nov 3 20:19 address
-rw-rw-rw- 1 root root 256 Nov 3 20:19 alias
drwxrwxrwx 1 root root 8 Nov 5 20:32 B1-R1-A
-rw-rw-rw- 1 root root 1 Nov 5 20:32 CA
-r--r--r-- 1 root root 2 Nov 3 20:19 crc8
-rw-rw-rw- 1 root root 24 Nov 3 20:19 date
drwxrwxrwx 1 root root 8 Nov 5 20:32 disconnect
-rw-rw-rw- 1 root root 1 Nov 5 20:32 EE
drwxrwxrwx 1 root root 8 Nov 5 20:32 endcharge
-r--r--r-- 1 root root 2 Nov 3 20:19 family
drwxrwxrwx 1 root root 8 Nov 5 20:32 HIH3600
drwxrwxrwx 1 root root 8 Nov 5 20:32 HIH4000
drwxrwxrwx 1 root root 8 Nov 5 20:32 HTM1735
-r--r--r-- 1 root root 12 Nov 3 20:19 humidity
-rw-rw-rw- 1 root root 1 Nov 5 20:32 IAD
-r--r--r-- 1 root root 12 Nov 3 20:19 id
-r--r--r-- 1 root root 16 Nov 3 20:19 locator
drwxrwxrwx 1 root root 8 Nov 5 20:32 MultiSensor
-rw-rw-rw- 1 root root 12 Nov 5 20:32 offset
drwxrwxrwx 1 root root 8 Nov 5 20:32 pages
-r--r--r-- 1 root root 16 Nov 3 20:19 r_address
-r--r--r-- 1 root root 12 Nov 3 20:19 r_id
-r--r--r-- 1 root root 16 Nov 3 20:19 r_locator
drwxrwxrwx 1 root root 8 Nov 5 20:32 S3-R1-A
-r--r--r-- 1 root root 12 Nov 3 20:19 temperature
-r--r--r-- 1 root root 32 Nov 3 20:19 type
-rw-rw-rw- 1 root root 12 Nov 5 20:32 udate
-r--r--r-- 1 root root 12 Nov 5 20:32 VAD
-r--r--r-- 1 root root 12 Nov 5 20:32 VDD
-r--r--r-- 1 root root 12 Nov 5 20:32 vis
-erkka
1-wire barometer lost.
Moderators: fantom, leecollings
erkka
Re: 1-wire barometer lost.
I downgraded to 2.3530 and voilá, Domoticz found the barometer again. So something has changed in the way domoticz reads 1-wire devices.
I tried 3.4843 SD-Image, but same function as the lastest stable.
Still the humidity sensor of the device is lost with this version also, so dunno how to get it back.
Lebo2d9
- Domoticz version: L stab
I have 3 DS18S20 temperature sensors hooked-up and i don't have any problems with the sensors on the latest version.
V3.5877
I will lookup me settings and config
Kind regards
V3.5877
Kind regards
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
Lebo2d9
back again
my /mnt directory is empty.
my devices are in /sys/bus/w1/devices
I enabled the 1-wire following this procedure.
http://www.raspberrypi-spy.co.uk/2013/0 ... er-sensor/
Kind regards
back again
Kind regards
More to come
More to come
erkka
Yes, in the lastets version all of my temperature sensors and dual counters are found, but my barometer is lost. So I had to check when the change was made how domoticz reads 1-wire devices.
