Toggle device?
Posted: Thursday 03 November 2016 12:30
by theolsen
I'm pulling out my remaining hair with what I think should be a simple problem to solve.
I am using presence detection on my phone from a script running on my Asus router.
The script updates one of two virtual devices on either 2.4 or 5.0 Ghz network so that I can tell that my phone is in the house and which network it is connected to.
That works fine.
I have a further dummy device that is updated if either of the 2.4 or 5.0 dummies are on.
The problem is I want the dummy device to only turn on if it was previously off, for example right now if my phone switches from 2.4 to 5.0 the dummy device will be switched on again even though I am already home - I want this to only happen if it is already off...otherwise do not update.
I hope I have explained well.
Thanks in advance.
Re: Toggle device?
Posted: Thursday 03 November 2016 13:58
by Egregius
Use the current state of the switch in a if block of your script.
Re: Toggle device?
Posted: Thursday 03 November 2016 14:05
by theolsen
Thanks Egregius, I was hoping to cheat it in Blockly but you are right..lua is the answer!
Re: Toggle device?
Posted: Thursday 03 November 2016 14:13
by Egregius
Or any other language...
Re: Toggle device?
Posted: Thursday 03 November 2016 16:23
by bloody2k
Would it be possible for you to share the script you use at your router?
Re: Toggle device?
Posted: Thursday 03 November 2016 16:42
by pj-r
theolsen wrote:The problem is I want the dummy device to only turn on if it was previously off, for example right now if my phone switches from 2.4 to 5.0 the dummy device will be switched on again even though I am already home - I want this to only happen if it is already off...otherwise do not update.
Whats the problem with blocky?
if dummy <> on and (dummy24 = on OR dummy5 = on) then
set dummy = on
else if dummy = on and dummy24 <> on AND dummy5 <> on
set dummy = off
end if
Re: Toggle device?
Posted: Thursday 03 November 2016 18:07
by theolsen
bloody2k wrote:Hi
Of course, I cobbled it together from
http://forum.micasaverde.com/index.php?topic=24084.0
I am sure it is far from efficient but it works for me and doesn't miss a beat.
#!/bin/sh
WATCHDOG_SLEEP_SEC=10
MAC_ADDRESS_1=“nn:nn:nn:nn:nn:nn” # Ken
c1_last_state="0"
c3_last_state="0"
MAC_ADDRESS_2=“nn:nn:nn:nn:nn:nn” # Barbie
c2_last_state="0"
c4_last_state="0"
VERAURL1="http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=26&switchcmd="
VERAURL2="http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=27&switchcmd="
VERAURL3="http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=29&switchcmd="
VERAURL4="http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=28&switchcmd="
x=0
y=0
offcount1=0
offcount2=0
offcount3=0
offcount4=0
while sleep $WATCHDOG_SLEEP_SEC
do
if [ "$x" == 180 ]; then
x=0
c1_last_state="0"
c2_last_state="0"
c3_last_state="0"
c4_last_state="0"
fi
x=$(( $x + 1 ))
c1_new_state=`wl -i eth2 assoclist | grep $MAC_ADDRESS_1`
if [ "$c1_new_state" == "$c1_last_state" ] ; then
sleep 0
if [ "$c1_new_state" == "assoclist $MAC_ADDRESS_1" ]; then
c1_last_state="$c1_new_state"
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=27&switchcmd=On"
offcount1=0
offcount1=$(( $offcount1 + 1 ))
fi
fi
c2_new_state=`wl -i eth2 assoclist | grep $MAC_ADDRESS_2`
if [ "$c2_new_state" == "$c2_last_state" ] ; then
sleep 0
if [ "$c2_new_state" == "assoclist $MAC_ADDRESS_2" ]; then
c2_last_state="$c2_new_state"
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=26&switchcmd=On"
offcount2=0
offcount2=$(( $offcount2 + 1 ))
fi
fi
c3_new_state=`wl -i eth1 assoclist | grep $MAC_ADDRESS_1`
if [ "$c3_new_state" == "$c3_last_state" ] ; then
sleep 0
if [ "$c3_new_state" == "assoclist $MAC_ADDRESS_1" ]; then
c3_last_state="$c3_new_state"
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=28&switchcmd=On"
offcount3=0
offcount3=$(( $offcount3 + 1 ))
fi
fi
c4_new_state=`wl -i eth1 assoclist | grep $MAC_ADDRESS_2`
if [ "$c4_new_state" == "$c4_last_state" ] ; then
sleep 0
if [ "$c4_new_state" == "assoclist $MAC_ADDRESS_2" ]; then
c4_last_state="$c4_new_state"
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=29&switchcmd=On"
offcount4=0
offcount4=$(( $offcount4 + 1 ))
fi
fi
if [ $offcount1 -lt 6 ]; then
# give not responding devices 1 minute to respond
sleep 0
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=27&switchcmd=Off"
offcount1=0
fi
if [ $offcount2 -lt 6 ]; then
sleep 0
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=26&switchcmd=Off"
offcount2=0
fi
if [ $offcount3 -lt 6 ]; then
sleep 0
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=28&switchcmd=Off"
offcount3=0
fi
if [ $offcount4 -lt 6 ]; then
sleep 0
wget -qs "http://192.168.1.65:8080/json.htm?type=command¶m=switchlight&idx=29&switchcmd=Off"
offcount4=0
fi
done
Re: Toggle device?
Posted: Thursday 03 November 2016 18:12
by theolsen
set dummy = on
set dummy = off
end if
Good call, I really don't know why I wasn't thinking like that
