Multiple RFlinks
Posted: Wednesday 02 November 2016 22:13
by mistysnip
I have a linux laptop in the basement running Domoticz with an RFlink connected to it. On the first floor, the signal is weak and I would like to add a new RFlink on that floor. Can I do this? I already have a Pi on this floor to which I could connect the second RFLink, but then how do I select the second RFlink in the linux Domoticz?
Any ideas?
*crappy English corrected..
Re: Multiple RFlinks
Posted: Thursday 03 November 2016 9:05
by deennoo
2 ways
1st -on your 1st floor rpi : put domoticz on it as usual and add him to your ground floor domoticz, each of them will have his own device, but 1st floor one will share with ground floor.
2nd - on you 1st floor rpi install ser2net, config it :
http://lesser-evil.com/2013/04/raspberr ... le-server/ (rflink speed is 57600). Once done add a rflink with lan on your ground domoticz and set rpi 1st floor ip + port you choose on ser2net.
And voila !
Posted: Sunday 06 November 2016 11:42
by mistysnip
I think I'll go for the first one, thanks. I've seen an option in domo to add an rflink with lan adapter but I haven't been able to understand how do it. Is this something I buy? Any good info out there? My searches seem to always end up in Dutch forums…
Posted: Sunday 06 November 2016 12:06
by deennoo
Rflink with lan adapter : ser2net solution
Re: RE: Re: Multiple RFlinks
Posted: Wednesday 28 December 2016 10:56
by sincze
deennoo wrote:Rflink with lan adapter : ser2net solution
Yes best option
works like a charm.
Sent from my SM-G925F using Tapatalk
Posted: Wednesday 28 December 2016 12:48
by trixwood
Kinda a lot of work, better use the build in function of domoticz
https://www.domoticz.com/wiki/Setting_up_Device_sharing
Posted: Saturday 31 December 2016 11:26
by sincze
Looked at it at the time. Costed me more euro ( hardware) compared to ser2net solution and requires me to monitor 2 domoticz daemons
or in my case 3.
