Domoticz RPC for NIBE Uplink
Posted: Tuesday 01 November 2016 10:21
The Domoticz RPC for NIBE Uplink presents the status of your NIBE heating and hot water system in Domoticz. Depending on what NIBE system you will be able to add up to 50 different virtual sensors in Domoticz. A dream for a home automation enthusiast, don't you think? Currently the Domoticz RPC for NIBE Uplink supports monitoring your heating and hot water system. A vision for the future is to extend the functionality to also being able to control various parameters.
The following picture gives you an idea about how it may look like overviewing the sensors in the Domoticz Gui Technical details
The Domoticz RPC for NIBE Uplink runs as a scheduled job (cron) every 5 minutes fetching data about your Nibe system(s). Doing that, it will not interfere with or delay your Domoticz event system while waiting for various servers to respond. Domoticz RPC for NIBE Uplink is written in python. By answering questions in the setup process, Domoticz RPC for NIBE Uplink will create virtual hardware, virtual devices and a room plan in Domoticz for you. Domoticz RPC for NIBE Uplink has been designed to only update a Domoticz device in case the value has changed. Some devices need regular updates though and these are updated at least once an hour even if there is no change of the actual value. Domoticz RPC for NIBE Uplink is logging to your Domoticz log (filter events on "nibeuplink"). Some heat pumps can have slaves attached to the master unit. Domoticz RPC for NIBE Uplink doesn't currently support slave devices.
Prerequisites
Remove a device that You included when doing the initial setup
This will update the device's configuration file entry. It's normally only necessary to redefine the device in case you are asked to do so.
If for some reason the file nibeUpLink.plist get lost (Normally resides in /tmp or /var/tmp depending on your choise at initial setup) you will see a message in the Domoticz log that you need to reauthenticate with the Nibe server.
From the console run the following command:
Getting debug information
Getting verbose information Useful if You like to check if everything works
Comments and suggestions
If you have any comments, questions or suggestions, please use this thread. Feel more than welcome to show us how it looks on your system, that's always nice.
Getting alarms
Most Nibe systems have a physical alarm output that will reflect the Nibe Systems alarm status, e.g. if there is an error that prevents the system from doing what it normally does (producing heat for example). A dirty filter alarm for example is not considered to be such an error. This alarm output is also watched by Nibe Uplink and can be represented by a virtual device on Domoticz. Its typically called something similar to "F750 X7". It's currently not so well documented by Nibe exactly what kind of alarms that will be passed in the Nibe Uplink API. In addition to the alarm output information (X7) that we receive from Nibe Uplink API, we also get an overall alarm status named "HasAlarmed" (An alarm indication that something in your system's operation is not working as intended). Introduced in version 1.2.0, a new Domoticz virtual alert device is available named "System Alarm" that will reflect the system's current "HasAlarmed" status.
Other considerations
All requests to the NIBE Uplink API are authenticated via the OAuth 2 protocol and Authorization Code Grant flow. Access tokens has to be sent and received. There's a need for the Domoticz RPC for NIBE Uplink to store these access tokens on the disk (SD-card). The directory used for that is the one that you entered at "Directory for app logging and storing access tokens". You may have entered /tmp or /var/tmp. The file nibeUpLink.plist will contain the important refresh token needed for the next API call. If You delete that file You would need to reauthenticate with the Nibe Uplink and You can see a reminder for that in the Domoticz log file. If You have chosen to store the access tokens on a RAM drive they will definitely be lost if You reboot the Raspberry Pi. Personally I store my access tokens on a RAM drive in order to minimize writing to the Raspberry Pi's SD card.
License
This software licensed under the GNU General Public License v3.0
Source code, for nibeuplink.py
Prerequisites
- Domoticz version 4834 or later running on linux (For example Raspbian on a Raspberry Pi).
- Python 2.0 at version 2.7.9 or higher. Check by running
python -V - A Nibe heating system supported by NIBE Uplink. The following models should work according to Nibe: F1126, F1226, F1145, F1245, F1155, F1255, F1345, F370, F470, F750, VVM310, VVM320, VVM325, VVM500, SMO20, SMO40.
- Your Nibe system should already be connected to Nibe Uplink. You have an account, can log in and see the system status. By looking at Service Info you should decide what parameters You would like to include into Domoticz as virtual devices. You probably won't find it useful to include all of them. Print them out, consider them and decide before going ahead installing. (In my system, which is a F750 the system alarm can be fetched by including a device named "X7") You can change your mind afterwards but it will require you to edit config files. You'd want to avoid that if possible.
- You need to access the NIBE Uplink API pages to create an "application". Log in using your NIBE Uplink user credentials. In "My Applications" choose to "Create Application". Name it myNibeSystem. Use Your fantasy to write something in the "Description". For "Callback URL" you should write http://showquerystring.000webhostapp.com/index.php Now when Your application has been created, the 2 pieces of information you will need in the setup process is the value of the Identifier and the Secret fields. Note them or keep the web page open so You can copy and paste them later.
- Optional. Set up a RAM drive on Raspberry Pi. You can use the RAM drive to store access tokens if You wish. Please read other considerations below.
- A good backup of your system including a backup of your Domoticz database in case something goes wrong.
- Access the Domoticz server command line using a terminal software such as PuTTY.
- Issue the following command:
mkdir /home/pi/domoticz/scripts/NibeUplink - Copy the source code at the end of this post and put it in a file that you name nibeuplink.py and place it in the /home/pi/domoticz/scripts/NibeUplink folder.
- Update the list of available packages on your system and upgrade them. Below is an example command that would typically work on a Raspbian on a Raspberry Pi.
sudo apt-get update && sudo apt-get upgrade -y - Install python-pip and the complementary python module named "requests". Below are some command examples that would typically work on Raspbian. The requests module is mandatory and if you encounter any kind of problems when installing requests, do not try to continue before solving the issues first.
sudo apt-get install python-pip pip install requests - Check that the request module is available from the standard user account (typically user pi at a Raspbian system) , working and is at version 2.5.0 or above. Older versions of requests won't work. If you need help how to determine the version of the requests module, have a look at the following page: Finding the module version. (Do not use the sudo command at all when checking and be logged in as the standard user, not root) If the version is not version 2.5.0 or above, things won't work.
- Issue the following command to start the setup process:
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py - You will be asked a lot of questions. Answer them. (If You enter something wrong, press CTRL-C, delete the incomplete config file at /home/pi/domoticz/scripts/NibeUplink/config.json and start over again) Below is an example dialogue. Now when you have reached the Authorization Code retrieval stage, you need to copy the URL that is displayed in your terminal window and open it in a web browser. (This is a one time process) The URL will lead to Nibe's API validation server where you will grant Domoticz access to the Nibe application that You created before. When you have completed that, your browser will redirect you to another web site that will display your Authorization Code. Copy the Authorization Code. (The Authorization Code expires after 30 minutes... don't pause!)
- Enter the Authorization Code in the terminal window and continue the setup. For every resource that is found in Your Nibe system(s) you will be asked if You like to create that as a virtual device in Domoticz. It will also immediately assign a value to it.
- When the script finishes You will see some brief information about Your Nibe system(s)
- Run the script in verbose mode to check that everything seems to work.
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py -v - Now add the script to run automatically in the scheduler. Issue the command and add the following line at the end of the file:
crontab -eCode: Select all
*/5 * * * * /usr/bin/python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py - Exit and save.
- Remove the virtual device in Domoticz
- From the console run the following command:
For every device found in your Nibe system, you will be asked if You'd like to redefine it. Answer 'Yes' only for the device that you wish to remove. Then You will be asked if You would like to create a Domoticz device for it, answer 'No'.
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py --redefine -v
For every device found in your Nibe system, you will be asked if You'd like to redefine it. Answer 'Yes' only for the device that you wish to enable and add in Domoticz. Then You will be asked if You would like to create a Domoticz device for it, answer 'Yes'.
For every device found in your Nibe system, you will be asked if You'd like to redefine it. Answer 'Yes' only for the device that you wish to redefine. Then You will be asked if You would like to create a Domoticz device for it, answer 'Yes'.
- Issue the following command You need to copy the URL that is displayed in your terminal window and open it in a web browser. The URL will lead to Nibe's API validation server where you will grant Domoticz access to the Nibe application. When you have completed that, your browser will redirect you to another web site that will display your Authorization Code. Copy the Authorization Code.
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py -v - Enter the Authorization Code in the terminal window.
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py -VFrom the console run the following command:
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py -dFrom the console run the following command:
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py -vIf you have any comments, questions or suggestions, please use this thread. Feel more than welcome to show us how it looks on your system, that's always nice.
Getting alarms
License
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# This software has been designed to work with Nibe Uplink API https://api.nibeuplink.com/Home/About
# It's aimed for Domoticz running on Raspberry Pi
# This software licensed under the GNU General Public License v3.0
import json
import os
import plistlib
import requests
from urllib import urlencode
import sys, getopt
from datetime import datetime
import time
import logging
# Global (module) namespace variables
redirect_uri = "http://showquerystring.000webhostapp.com/index.php" # Don't alter this or anything else!
baseEndPointUrl = 'https://api.nibeuplink.com'
authorizeEndpointUrl = baseEndPointUrl + '/oauth/authorize'
tokenEndpointUrl = baseEndPointUrl + '/oauth/token'
cfgFile = sys.path[0] + '/config.json'
configChanged = False
newDevicesList = [] # This is a python list
PROGRAMNAME = 'Domoticz RPC for NIBE Uplink'
VERSION = '2.0.0'
MSG_ERROR = 'Error'
MSG_INFO = 'Info'
MSG_EXEC = 'Exec info'
tty = True if os.isatty(sys.stdin.fileno()) else False
isDebug = False
isVerbose = False
def query_yes_no(question, default="no"):
Ask a yes/no question via raw_input() and return their answer.
"question" is a string that is presented to the user.
"default" is the presumed answer if the user just hits <Enter>.
It must be "yes" (the default), "no" or None (meaning
an answer is required of the user).
The "answer" return value is True for "yes" or False for "no".
valid = {"yes": True, "y": True, "ye": True,
"no": False, "n": False}
if default is None:
prompt = " [y/n] "
elif default == "yes":
prompt = " [Y/n] "
elif default == "no":
prompt = " [y/N] "
else:
raise ValueError("invalid default answer: '%s'" % default)
while True:
sys.stdout.write(question + prompt)
choice = raw_input().lower()
if default is not None and choice == '':
return valid[default]
elif choice in valid:
return valid[choice]
else:
sys.stdout.write("Please respond with 'yes' or 'no' "
"(or 'y' or 'n').\n")
def connected_to_internet(url='http://www.google.com/', timeout=5):
try:
_ = requests.head(url, timeout=timeout)
return True
except requests.ConnectionError:
print('No internet connection available.')
return False
def default_input(message, defaultVal):
if defaultVal:
return raw_input( "%s [%s]:" % (message, defaultVal) ) or defaultVal
else:
return raw_input( "%s :" % (message) )
def create_config():
global cfg;cfg = {}
import socket
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.connect(('8.8.8.8', 0)) # connecting to a UDP address doesn't send packets
local_ip_address = s.getsockname()[0]
cfg['domoticz'] = {}
cfg['domoticz']['hostName'] = default_input('Domoticz web service IP address (or host name)', local_ip_address)
cfg['domoticz']['portNumber'] = default_input('Domoticz web service port number', 8080)
cfg['domoticz']['protocol'] = ''
while cfg['domoticz']['protocol'] <> 'http' and cfg['domoticz']['protocol'] <> 'https':
cfg['domoticz']['protocol'] = default_input('Domoticz web service communication protocol (http or https)', 'http')
if cfg['domoticz']['protocol'] <> 'http' and cfg['domoticz']['protocol'] <> 'https':
print 'Invalid value given for Domoticz web service communication protocol. It must be \'http\' or \'https\''
cfg['domoticz']['httpBasicAuth'] = {}
cfg['domoticz']['httpBasicAuth']['userName'] = \
default_input('Domoticz web service user name (leave blank if no username is needed)', '')
cfg['domoticz']['httpBasicAuth']['passWord'] = \
default_input('Domoticz web service password (leave blank if no passord is needed)', '')
cfg['domoticz']['devices'] = {}
cfg['domoticz']['devices']['device'] = []
cfg['system'] = {}
tmpdir = '/var/tmp' if os.path.isdir('/var/tmp') else '/tmp'
cfg['system']['tmpFolder'] = '/xxxx/yyyy'
while not os.path.isdir(cfg['system']['tmpFolder']):
cfg['system']['tmpFolder'] = default_input('Directory for app logging and storing access tokens', tmpdir)
if not os.path.isdir(cfg['system']['tmpFolder']):
print 'That isn\'t a valid directory name on Your system! Please try again.'
cfg['oAuth2ClientCredentials'] = {}
cfg['oAuth2ClientCredentials']['authorizationCode'] = 'xxxx'
cfg['oAuth2ClientCredentials']['clientId'] = ''
while len(cfg['oAuth2ClientCredentials']['clientId']) <> 32:
cfg['oAuth2ClientCredentials']['clientId'] = default_input('Your Nibe UpLink Application\'s Identifier', '')
if len(cfg['oAuth2ClientCredentials']['clientId']) <> 32:
print 'That doesn\'t look like a valid Identifier. Have a look at https://api.nibeuplink.com/Applications'
print 'Please try again'
cfg['oAuth2ClientCredentials']['clientSecret'] = ''
while len(cfg['oAuth2ClientCredentials']['clientSecret']) <> 44:
cfg['oAuth2ClientCredentials']['clientSecret'] = default_input('Your Nibe UpLink Application\'s secret', '')
if len(cfg['oAuth2ClientCredentials']['clientSecret']) <> 44:
print 'That doesn\'t look like a valid secret. Have a look at https://api.nibeuplink.com/Applications'
# Do we already have a hardware device named 'NIBEUplink' in Domoticz?
payload = dict([('type', 'hardware')])
r = domoticzAPI(payload)
hwIdx = '0'
HWNAME = 'NIBEUplink'
if 'result' in r.keys():
for hw in r['result']:
if hw['Name'] == HWNAME and hw['Enabled'] == 'true':
hwIdx = hw['idx']
break
if hwIdx <> '0':
cfg['domoticz']['virtualHwDeviceIdx'] = int(hwIdx)
else:
# Create a new Hardware Device. We wants it, we needs it. Must have the precious. They stole it from us!
payload = dict([('type', 'command'), ('param', 'addhardware'), ('htype', 15), \
('port', 1), ('name', HWNAME), ('enabled', 'true'), ('datatimeout', 0)])
# Now go fishing for the hardware device Idx
hwIdx = hw['idx']
break
if hwIdx <> '0':
else:
print 'Can not find the newly created virtual hardware device.'
sys.exit(0)
# ROOM PLAN
# Do we already have a room plane named 'NIBEUplink' in Domoticz?
payload = dict([('type', 'plans')])
roomIdx = '0'
ROOMPLAN = 'NIBEUplink'
if 'result' in r.keys(): # Can happen if there are no room plans
for room in r['result']:
if room['Name'] == ROOMPLAN:
roomIdx = room['idx']
break
if roomIdx <> '0':
cfg['domoticz']['roomPlan'] = int(roomIdx)
else:
# Create a new Room Plan
payload = dict([('type', 'command'), ('param', 'addplan'), ('name', ROOMPLAN)])
# Now go fishing for the room plan Idx
break
if roomIdx <> '0':
else:
print 'Can not find the newly created room plan.'
sys.exit(0)
with open(cfgFile, 'w') as outfile:
json.dump(cfg, outfile, indent=2, sort_keys=True, separators=(',', ':'))
return cfg
def load_config():
try:
with open(cfgFile) as json_data_file:
cfg = json.load(json_data_file)
except IOError:
# Create a new config file
if tty:
cfg = create_config()
else:
sys.exit(0)
except:
logMessage = 'Can not open the config file ' + cfgFile
print logMessage, sys.exc_info()[0]
sys.exit(0)
return cfg
def domoticzAPI(payload):
try:
r = requests.get(cfg['domoticz']['protocol'] + '://' + cfg['domoticz']['hostName'] + ':' + \
str(cfg['domoticz']['portNumber']) + '/json.htm', \
verify=False, \
auth=(cfg['domoticz']['httpBasicAuth']['userName'], cfg['domoticz']['httpBasicAuth']['passWord']), \
params=payload)
except:
print('Can not open domoticz URL: \'' + cfg['domoticz']['protocol'] + '://' + cfg['domoticz']['hostName'] + ':' + \
str(cfg['domoticz']['portNumber']) + '/json.htm\'', sys.exc_info()[0])
sys.exit(0)
if r.status_code <> 200:
print 'Unexpected status code from Domoticz: ' + str(r.status_code)
sys.exit(0)
try:
rJsonDecoded = r.json()
except:
print('Can\'t Json decode response from Domoticz.', sys.exc_info()[0])
sys.exit(0)
if rJsonDecoded['status'] <> 'OK':
print 'Unexpected response from Domoticz: ' + rJsonDecoded['status']
sys.exit(0)
return rJsonDecoded
def logToDomoticz(messageType, logMessage):
payload = dict([('type', 'command'), ('param', 'addlogmessage'), \
('message', '(' + messageType+ ') ' + os.path.basename(sys.argv[0]) + ': ' + logMessage)])
return r
def truncate(x, d):
return int(x*(10.0**d))/(10.0**d)
def findTruncatedValue(rawValue, displayValue):
# Handle a case like this:
# "displayValue": "1339.3kWh", "rawValue": 133931
# "displayValue": "0.314kWh", "rawValue": 314931
# "displayValue": "-245DM", "rawValue": -2456
# "displayValue": "1341.6kWh", "rawValue": 134157
xTest = ''.join(ch for ch in displayValue if ch.isdigit() or ch == '.') # Now "1339.3"
if not xTest.lstrip('-').replace('.','',1).isdigit():
return ''
displayValueNum = float(xTest)
rawValue = abs(rawValue) # Now a positive number
if displayValueNum == rawValue or displayValueNum == 0 or rawValue == 0: return 1
# displayValueNum is now a number and it's not 0
if displayValueNum >= 1:
if int(rawValue / 10) == int(displayValueNum):
return 0.1
elif int(rawValue / 100) == int(displayValueNum):
return 0.01
elif int(rawValue / 1000) == int(displayValueNum):
return 0.001
else:
numDecimalPlaces = len(str(displayValueNum).split('.')[1]) # How many decimal places is there in displayValueNum ?
rawValueFloat = float(rawValue)
if truncate(rawValueFloat / 10, numDecimalPlaces) == displayValueNum:
return 0.1
elif truncate(rawValueFloat / 100, numDecimalPlaces) == displayValueNum:
return 0.01
elif truncate(rawValueFloat / 1000, numDecimalPlaces) == displayValueNum:
return 0.001
elif truncate(rawValueFloat / 10000, numDecimalPlaces) == displayValueNum:
return 0.0001
elif truncate(rawValueFloat / 100000, numDecimalPlaces) == displayValueNum:
return 0.00001
elif truncate(rawValueFloat / 1000000, numDecimalPlaces) == displayValueNum:
return 0.000001
return ''
def redefineDomoDevice(nibeSystem, nibeResource, nibeCategoryName):
global newDevicesList
global configChanged
for c in cfg['domoticz']['devices']['device']:
if c['nibeSystemId'] == nibeSystem['systemId'] and c['nibeParameterId'] == nibeResource['parameterId']:
devNameLong = ((nibeSystem['productName'] + ' ' + nibeResource['title'] + ' ' + nibeResource['designation']).title()).strip()
if not c['enabled']:
devNameLong += ' (Currently not enabled)'
elif c['domoticzIdx'] > 0:
devNameLong += ' (Enabled and current Domoticz idx: ' + str(c['domoticzIdx']) + ')'
if query_yes_no('Redefine : ' + devNameLong, 'no'):
configChanged = True # Do not append to newDevicesList
else:
newDevicesList.append(c)
def getDomoDevice(nibeSystem, nibeResource, nibeCategoryName):
unsupportedDevices = [ 0, 47214, 48745]
if nibeResource['parameterId'] in unsupportedDevices:
#print str(nibeResource['parameterId']) + ' is not a supported device'
return {}
#print str(nibeResource['nibeResourceId']) + ' is a supported device'
#print 'Found : ' + c['nibeTitle']
return c
if not tty:
return {}
nibeResource['title'] = nibeResource['title'].strip()
nibeResource['title'] = nibeResource['title'].replace('compressor', 'compr')
nibeResource['title'] = nibeResource['title'].replace('compr.', 'compr')
if len(nibeResource['title']) > 17:
nibeResource['title'] = nibeResource['title'].replace('operating', 'op')
if nibeResource['unit'] == 'kWh':
# Counter incremental has very little space in the title
nibeResource['title'] = nibeResource['title'].replace('factor', 'fc')
if len(nibeResource['title']) > 21:
nibeResource['title'] = nibeResource['title'][0:21].strip()
elif nibeResource['unit'] == 'A':
# Current meter, Add phase number to name
nibeResource['title'] = nibeResource['title'] + ' (Phase-' + nibeResource['designation'][-1:] + ')'
else:
if len(nibeResource['title']) > 36:
nibeResource['title'] = nibeResource['title'][0:36].strip()
# Avoid dulicate device names for 'heat medium flow'
if nibeResource['title'] == 'heat medium flow': nibeResource['title'] = nibeResource['title'] + ' ' + nibeResource['designation']
productNameShort = nibeSystem['productName'][5:] if nibeSystem['productName'][0:5] == 'NIBE ' else nibeSystem['productName']
devName = (productNameShort + ' ' + nibeResource['title']).title() # Capitalize the first letter of each word
createDev = default_input('\n\nFound a new Nibe Uplink resource: \'' + devNameLong + '\'\nShall I enable it and create a Domoticz Virtual Device for it? : Y/N', 'N')
createDev = (createDev.upper() == 'Y' or createDev.upper() == 'YES') and True or False
entry = {}
entry['enabled'] = False
entry['domoticzIdx'] = 0
if (nibeResource['displayValue'] == 'no' and nibeResource['rawValue'] == 0) \
or (nibeResource['displayValue'] == 'yes' and nibeResource['rawValue'] == 1):
entry['domoticzSensorType'] = 6 # Switch
elif nibeResource['parameterId'] in {9999999,47412} :# Hard coded for alarm
entry['domoticzSensorType'] = 7 # Alert
elif nibeResource['parameterId'] == 43416: # Hard coded for compressor starts, nibeResource['unit'] = ''
entry['domoticzSensorType'] = 113 # Counter sensor (Ordinary)
elif nibeResource['parameterId'] == 10069: # Hard coded for Smart Price Adaption
entry['domoticzSensorType'] = 1004 # Custom sensor
elif nibeResource['unit'] == '%':
entry['domoticzSensorType'] = 2 # Percentage
elif unicode(nibeResource['unit']) == u'\xb0'+'C':
entry['domoticzSensorType'] = 80 # Temp
elif nibeResource['unit'] == 'h' or nibeResource['unit'] == 's':
elif nibeResource['unit'] == 'Hz':
elif nibeResource['unit'] == 'kWh':
elif nibeResource['unit'] == 'kW':
entry['domoticzSensorType'] = 248 # Usage Electric
entry['domoticzSensorType'] = 19 # (Ampere 1-Phase)
elif nibeResource['unit'] == 'DM': # Degree minutes
elif nibeResource['parameterId'] in {40050,43124} : # Hard coded for some unit-less devices
elif nibeResource['unit'] == '':
entry['domoticzSensorType'] = 5 # Text
else:
print 'Unknown Domoticz type: \'' + unicode(nibeResource['unit']) + '\''
entry['domoticzSensorType'] = 0
if createDev and entry['domoticzSensorType'] > 0:
# Create a Virtual Device
payload = dict([('type', 'createvirtualsensor'), ('idx', cfg['domoticz']['virtualHwDeviceIdx']), \
('sensorname', devName), ('sensortype', entry['domoticzSensorType'])])
if entry['domoticzSensorType'] == 1004:
payload['sensoroptions'] = '1;' + nibeResource['unit']
# Now go fishing for the newly created device idx
payload = dict([('type', 'devices')])
devIdx = 0
for dev in reversed(r['result']):
if dev['Name'] == devName and dev['HardwareID'] == cfg['domoticz']['virtualHwDeviceIdx']:
devIdx = dev['idx']
break
if devIdx <> '0':
entry['domoticzIdx'] = int(devIdx)
entry['enabled'] = True
print 'Created Domoticz virtual device (idx) : ' + str(devIdx)
else:
print 'Error: Can not find the newly created virtual device.'
sys.exit(0)
# Add the device to the Domoticz room plan
payload = dict([('type', 'command'), ('param', 'addplanactivedevice'), ('idx', cfg['domoticz']['roomPlan']), \
('activetype', 0), ('activeidx', devIdx)])
entry['nibeSystemId'] = nibeSystem['systemId']
entry['nibeParameterId'] = nibeResource['parameterId']
entry['nibeTitle'] = nibeResource['title']
entry['nibeDesignation'] = nibeResource['designation']
entry['nibeCategoryName'] = nibeCategoryName.strip()
if nibeResource['parameterId'] == 43084: # This guy may be 0 for the moment making it hard to guess the factor
entry['valueFactor'] = 0.01
elif nibeResource['parameterId'] == 40016: # Brine out should have 0.1
entry['valueFactor'] = 0.1
elif nibeResource['parameterId'] == 40079: # Current should have 0.1
elif nibeResource['parameterId'] == 40081: # Current should have 0.1
elif nibeResource['parameterId'] == 40083: # Current should have 0.1
elif nibeResource['displayValue'] == '---':
entry['valueFactor'] = 1
elif nibeResource['displayValue'] == 'no' or nibeResource['displayValue'] == 'yes' or \
nibeResource['rawValue'] == -32768:
elif (nibeResource['rawValue'] == 0) and ('0.000' in nibeResource['displayValue']):
entry['valueFactor'] = 0.001
elif (nibeResource['rawValue'] == 0) and ('0.00' in nibeResource['displayValue']):
elif (nibeResource['rawValue'] == 0) and ('0.0' in nibeResource['displayValue']):
entry['valueFactor'] = 0.1 # This may not always be correct
elif (nibeResource['rawValue'] == 0):
elif str(nibeResource['rawValue'] * 1000) in nibeResource['displayValue']:
entry['valueFactor'] = 1000
elif str(nibeResource['rawValue'] * 100) in nibeResource['displayValue']:
elif str(nibeResource['rawValue'] * 10) in nibeResource['displayValue']:
elif str(nibeResource['rawValue']) in nibeResource['displayValue']:
elif str(nibeResource['rawValue'] / 10) in nibeResource['displayValue']:
elif str(nibeResource['rawValue'] / 100) in nibeResource['displayValue']:
elif findTruncatedValue(nibeResource['rawValue'], nibeResource['displayValue']) <> '':
entry['valueFactor'] = findTruncatedValue(nibeResource['rawValue'], nibeResource['displayValue'])
else:
# Change the Domoticz device if it was just created above
# We put this here because now we can access the entry['valueFactor'] now
# When there is a counter created, there is a possibility to change the units and set the offset value
domoSurpriseFc = 1000 if nibeResource['unit'] == 'kWh' else 1
if entry['domoticzSensorType'] == 113:
payload = dict([('type', 'setused'), ('idx', devIdx), ('description', 'Virtual sensor device for ' + devNameLong), \
('switchtype', 0 if nibeResource['unit'] == 'kWh' else 3), \
('addjvalue', nibeResource['rawValue']*entry['valueFactor'] * -1), \
('used', 'true'), ('name', devName), \
('options', 'VmFsdWVRdWFudGl0eSUzQVRpbWUlM0JWYWx1ZVVuaXRzJTNBaCUzQg==' if nibeResource['unit'] == 'h' else '')])
# The options sent above is the string 'ValueQuantity:Time;ValueUnits:h;' that has been URL encoded + Base64 encoded
cfg['domoticz']['devices']['device'].append(entry)
return entry
def updateDomoDevice(domoDevice, nibeResource):
if not domoDevice['enabled']:
return
# Only update if the new value differs from the device value
# or if the device has not been updated for a while
payload = dict([('type', 'devices'), ('rid', domoDevice['domoticzIdx'])])
# Domoticz has another surprise going on when it comes to counters ... Energy (kWh) Gas (m3) Water (m3)
# The counter will be treated with the divider which is defined in the parameters in the application settings.
# For example if the counter is set to "Water" and the value is passed as liters, the divider must set to 1000
# (as the unit is m3).
# It should be used both when reading and writing values
# TODO check more cases
#print r['result'][0]['Data'] #data
#print r['result'][0]['LastUpdate']
if not 'result' in r.keys():
errMess = 'Failure getting data for domoticz device idx: ' + str(domoDevice['domoticzIdx'])
print errMess
logToDomoticz(MSG_ERROR, errMess)
return
xTest = ''.join(ch for ch in r['result'][0]['Data'] if ch.isdigit() or ch == '.' or ch == '-') # Now "-1339.3"
if xTest.lstrip('-').replace('.','',1).isdigit():
domoValueNum = float(xTest) * domoSurpriseFc # This contains the Domoticz device's value as a number
else:
domoValueNum = 0
# Now, looking for a reason to update the sensor
# Does the Domotic's sensor need an update in order not to time out?
sensorTimedOut = False
if 'HaveTimeout' in r['result'][0]:
if (r['result'][0]['HaveTimeout'] and ((datetime.now() - datetime.strptime(r['result'][0]['LastUpdate'], '%Y-%m-%d %H:%M:%S')).seconds >= 3000)):
sensorTimedOut = True
# Does the value reported from Nibe differ from the Domoticz device's value?
valueChanged = False
if domoDevice['domoticzSensorType'] == 7: # Handling the ALERT Device type
domoCompareValue = r['result'][0]['Level']
testValue = r['result'][0]['Data']
if testValue == 'Everything seems to be fine':
domoCompareValue = '9' # Old version used 'Everything seems to be fine', it's to long to fit. This test can be removed in next version.
nibeCompareValue = 4 if nibeResource['rawValue'] <> 0 else 1
elif domoDevice['domoticzSensorType'] == 6: # Handling the SWITCH Device type
domoCompareValue = r['result'][0]['Status']
nibeCompareValue = 'On' if nibeResource['rawValue'] == 1 else 'Off'
elif domoDevice['domoticzSensorType'] == 113:# These guys use an offset value that we need to deal with
# Comparing floats in Python is not as simple as it sounds, using str() as a workaround
nibeCompareValue = str(float(nibeResource['rawValue']*domoDevice['valueFactor']*domoSurpriseFc))
domoCompareValue = str((domoValueNum / domoSurpriseFc - r['result'][0]['AddjValue'])*domoSurpriseFc)
else:
# Don't use fractionals
nibeCompareValue = int(nibeResource['rawValue']*domoDevice['valueFactor'])
domoCompareValue = int(domoValueNum / domoSurpriseFc - r['result'][0]['AddjValue'])
elif domoDevice['domoticzSensorType'] == 248 and nibeResource['unit'] == 'kW': # Usage Electric
nibeCompareValue = str(float(nibeResource['rawValue']*domoDevice['valueFactor']*1000))
domoCompareValue = str(domoValueNum)
else:
nibeCompareValue = str(float(nibeResource['rawValue']*domoDevice['valueFactor']))
if nibeCompareValue <> domoCompareValue: valueChanged = True
if isDebug:
print r['result'][0]['Name']
print 'N: ' + str(nibeCompareValue)
print 'D: ' + str(domoCompareValue)
print
elif isVerbose and (valueChanged or sensorTimedOut):
sayThis = 'Updating Domoticz device \'' + r['result'][0]['Name'] + '\' idx: ' + str(domoDevice['domoticzIdx']) + ' due to:'
if valueChanged: sayThis += ' <value changed>. New value is: ' + str(nibeCompareValue) + \
'. Old value was: ' + str(domoCompareValue) + '.'
if sensorTimedOut: sayThis += ' <time condition>'
print sayThis
if not valueChanged and not sensorTimedOut:
return
payload = dict([('type', 'command'), ('param', 'udevice'), ('idx', domoDevice['domoticzIdx']), \
('nvalue', nibeCompareValue), ('svalue', 'OK' if nibeCompareValue == 1 else 'Alert!')])
payload = dict([('type', 'command'), ('param', 'switchlight'), ('idx', domoDevice['domoticzIdx']), \
('switchcmd', nibeCompareValue)])
else: # All other sensor types
('nvalue', 0), ('svalue', nibeCompareValue)])
# Retrieve the authorization code
# It will only run if the variable cfg['oAuth2ClientCredentials']['authorizationCode'] has not been set
def retrieve_authorization_code():
authorization_code_req = {
"response_type": 'code',
"client_id": cfg['oAuth2ClientCredentials']['clientId'],
"state": 'xyz',
"access_type": 'offline',
"redirect_uri": redirect_uri,
"scope": (r'READSYSTEM' +
r' WRITESYSTEM')
r = requests.get(authorizeEndpointUrl + "?%s" % urlencode(authorization_code_req),
allow_redirects=False)
print '\nAuthorization Code retrieval\n==========================\nCopy the URL below and paste into the adress bar of a web browser. After granting access on Nibe Uplink, Your browser will show You the Authorization Code. Then enter that code below .\n'
url = r.headers.get('location')
print baseEndPointUrl + url + '\n'
while len(cfg['oAuth2ClientCredentials']['authorizationCode']) <> 401:
cfg['oAuth2ClientCredentials']['authorizationCode'] = default_input('Authorization Code', '')
if len(cfg['oAuth2ClientCredentials']['authorizationCode']) <> 401:
print 'That doesn\'t look like a valid Authorization Code. Please try again.'
return
# Request new OAuth2 tokens
def requestTokens(grant_type, refreshToken):
logToDomoticz(MSG_INFO, 'Requesting acess tokens using the ' + grant_type + ' grant type')
logging.basicConfig(filename=logFile,level=logging.DEBUG,format='%(asctime)s %(levelname)s %(message)s',filemode='w')
data={}
try:
if grant_type == 'authorization_code':
data={'grant_type' : grant_type, 'code' : cfg['oAuth2ClientCredentials']['authorizationCode'], 'client_id' : cfg['oAuth2ClientCredentials']['clientId'], 'client_secret' : cfg['oAuth2ClientCredentials']['clientSecret'], 'redirect_uri' : redirect_uri}
elif grant_type == 'refresh_token':
logging.info('Using Refresh Token: %s' % refreshToken)
data={'grant_type' : grant_type, 'refresh_token' : refreshToken, 'client_id' : cfg['oAuth2ClientCredentials']['clientId'], 'client_secret' : cfg['oAuth2ClientCredentials']['clientSecret']}
getTokens = requests.post(tokenEndpointUrl, data)
getTokens.raise_for_status()
newTokens = getTokens.json()
accessToken = newTokens['access_token']
expiresIn = newTokens['expires_in']
expiration = int(time.time()) + expiresIn
refreshToken = newTokens['refresh_token']
plistlib.writePlist({'Access Token':accessToken,'Refresh Token':refreshToken,'Expiration': expiration,}, tokenDictionaryFile)
logging.info('Got Access Token: %s' % accessToken)
logging.info('The Access Token is valid for : %s seconds' % expiresIn)
logging.info('Got Refresh Token: %s' % refreshToken)
#tokenPlist = plistlib.readPlist(tokenDictionaryFile)
except requests.exceptions.RequestException, e:
logMessage = 'Can\'t generate tokens: %s' % e
logging.error('========== ' + logMessage + ' ==========')
logToDomoticz(MSG_ERROR, logMessage)
if tty:
print logMessage
print 'The Authorization Code might be too old. Clearing it out so that You can request a new. Please run this script again.'
print '\n\nBelow is some debugging help:\n=============================='
for k, v in data.iteritems():
print k, ' = ', v
print '\n\n'
sys.exit(0)
except:
logMessage = 'Can\'t create the token dictionary file'
if tty:
print logMessage
sys.exit(0)
return accessToken
# Validate the OAuth2 tokens
def validateTokens():
# First let's read the Token Dictionary plist
accessTokenValid = False
try:
refreshToken = tokenPlist["Refresh Token"]
accessToken = tokenPlist["Access Token"]
expiration = tokenPlist["Expiration"]
if expiration - time.time() > 30:
accessTokenValid = True
logMessage = 'Current access token valid for ' + str(int(expiration - time.time())) + ' seconds'
if isVerbose:
logToDomoticz(MSG_INFO, logMessage)
except:
if not tty:
logToDomoticz(MSG_ERROR, 'You need to run \'python ' + os.path.realpath(__file__) + '\' from a console to obtain a new Authorization Code')
sys.exit(0)
# No file!? Man that's bad. Maybe this is the first time the script runs. Let's make an Authorization Request
errorText = 'There is no dictionary file ' + tokenDictionaryFile + '' \
+ ' (That is perfectly normal if this is the first time that the script runs)'
logToDomoticz(MSG_ERROR, errorText)
if tty:
print errorText
accessToken = requestTokens('authorization_code', '')
if not accessTokenValid:
# The old refresh token is used to obtain a new access token and a new refresh token
accessToken = requestTokens('refresh_token', refreshToken)
return accessToken
def get_system_list(accessToken):
authorization_header = {"Authorization": "Bearer %s" % accessToken}
r = requests.get(baseEndPointUrl + "/api/v1/systems", headers=authorization_header)
if r.status_code == requests.codes.ok:
if isDebug: print 'HTTP/1.1 200 OK'
else:
print "Nibe server responded with an error code: ", r.status_code
sys.exit(0)
if isDebug: print "get_system_list: ", r.text, "\n"
return r.text
def get_system_status(accessToken, systemid):
r = requests.get(baseEndPointUrl + "/api/v1/systems/" + str(systemid) + "/status/system", headers=authorization_header)
if isDebug: print "get_system_status: ", r.text, "\n"
return r.text
def get_system_config(accessToken, systemid):
r = requests.get(baseEndPointUrl + "/api/v1/systems/" + str(systemid) + "/config", headers=authorization_header)
if isDebug: print "get_system_config: ", r.text, "\n"
return r.text
def get_system_unit_status(accessToken, systemid, systemUnitId):
r = requests.get(baseEndPointUrl + "/api/v1/systems/" + str(systemid) + "/status/systemUnit/" + systemUnitId, headers=authorization_header)
if isDebug: print "get_system_unit_status: ", r.text, "\n"
return r.text
def get_serviceinfoCategories(accessToken, systemid):
r = requests.get(baseEndPointUrl + "/api/v1/systems/" + str(systemid) + "/serviceinfo/categories?parameters=true", headers=authorization_header)
if isDebug: print "get_serviceinfoCategories: ", r.text + '\n'
return r.text
def list_systems(accessToken):
systemlist = json.loads(get_system_list(accessToken))
if isVerbose: print 'Number of systems: ' + str(systemlist['numItems'])
if isVerbose: print ''
for nibeSystem in systemlist['objects']:
if isVerbose: print 'Product Name: ' + nibeSystem['productName']
if isVerbose: print 'Serial number: ' + nibeSystem['serialNumber']
if isVerbose: print 'System ID: ' + str(nibeSystem['systemId'])
if isVerbose: print 'Has alarmed: ' + str(nibeSystem['hasAlarmed'])
# climate system 1
systemUnitId = 0
if isDebug: systemUnitStatus0 = json.loads(get_system_unit_status(accessToken, nibeSystem['systemId'], str(systemUnitId)))
if isDebug: systemStatus = json.loads(get_system_status(accessToken, nibeSystem['systemId']))
serviceinfoCategories = json.loads(get_serviceinfoCategories(accessToken, nibeSystem['systemId']))
# Append the hasAlarmed to the serviceinfoCategories parameters
has_alarmed_dict = {'parameterId': 9999999,
'name': '9999999',
'title': 'system alarm',
'designation': '',
'unit': '',
'displayValue': str(int(nibeSystem['hasAlarmed'])),
'rawValue': int(nibeSystem['hasAlarmed'])
for s in serviceinfoCategories:
if s['categoryId'] == 'STATUS' :
s['parameters'].append(has_alarmed_dict)
if redefineDevices:
for nibeResource in s['parameters']: # nibeResources:
redefineDomoDevice(nibeSystem, nibeResource, s['name'])
if configChanged:
cfg['domoticz']['devices']['device'] = newDevicesList # Replace the devices list in config file
print '\n\n\n'
#catResources = json.loads(p)
domoDevice = getDomoDevice(nibeSystem, nibeResource, s['name'])
if domoDevice: updateDomoDevice(domoDevice, nibeResource)
#print "Unit: " + p['unit']
if configChanged:
logMessage = 'Updated the config file at ' + cfgFile
if isVerbose: print logMessage
def print_help(argv):
print 'usage: ' + os.path.basename(__file__) + ' [option] [-C domoticzDeviceidx|all] \nOptions and arguments'
print '-d : debug output (also --debug)'
print '-h : print this help message and exit (also --help)'
print '-v : verbose'
print '-V : print the version number and exit (also --version)'
print '-R : redefines devices in the config file (also --redefine)'
def main(argv):
global isDebug
global isVerbose
global redefineDevices;redefineDevices = False
try:
opts, args = getopt.getopt(argv, 'dhvVR', ['help', 'debug', 'version', 'redefine'])
except getopt.GetoptError:
print_help(argv)
sys.exit(2)
for opt, arg in opts:
if opt in ('-h', '--help'):
print_help(argv)
sys.exit(0)
elif opt in ('-d', '--debug'):
isDebug = True
elif opt in ('-v'):
isVerbose = True
elif opt in ('-V', '--version'):
print PROGRAMNAME + ' ' + VERSION
sys.exit(0)
elif opt in ("-R", "--redefine"):
redefineDevices = True
if isDebug: print 'Debug is on'
if not tty: time.sleep( 5 ) # Give Domoticz some time to settle down from other commands running exactly at the 00 sec
global cfg; cfg = load_config()
global logFile; logFile = os.path.join(cfg['system']['tmpFolder'], os.path.basename(sys.argv[0]) + '.log')
global tokenDictionaryFile; tokenDictionaryFile = os.path.join(cfg['system']['tmpFolder'], 'nibeUpLink.plist')
if not connected_to_internet():
logToDomoticz(MSG_ERROR, 'No internet connection available')
sys.exit(0)
msgProgInfo = PROGRAMNAME + ' Version ' + VERSION
msgProgInfo += ' running on TTY console...' if tty else ' running as a CRON job...'
if isVerbose:
print msgProgInfo
logToDomoticz(MSG_EXEC, msgProgInfo)
if tty:
else:
sys.exit(0)
accessToken = validateTokens()
if redefineDevices and tty:
print '\nYou have requested to redefine the devices. By doing that, for each device found in your Nibe system, you will be asked if you want to redefine it. After going through the complete list, for any device that You answered \'Yes\' You will be asked if You want to create a Domoticz device for it.\n'
if not query_yes_no('Are You sure that you\'d like to redefine the devices', 'no'):
sys.exit(0)
sys.exit(0)
if __name__ == '__main__':
main(sys.argv[1:])
