Running perl script from within dzVents?
thorbj
Post by thorbj »
How can i run a perl script using dzventz?
I have tried this:
local OL_BULB_HALL = 153
        active = true,                  -- set to true to activate this script
                'OL_BULB_HALL',                 -- name of the device
        execute = function(domoticz, OL_BULB_HALL)
        if (OL_BULB_HALL.state == 'Off') then
                 os.execute('/home/pi/domoticz/scrips/perl/bulb_off');
        if (OL_BULB_HALL.state == 'On') then
                 os.execute('/home/pi/deomoticz/scripts/perl/bulb_on');
But nothings happens. No scripts is called when pressing the switch.
How can I do this?
Thanks.
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
thorbj
Re: Running perl script from within dzVents?
Post by thorbj »
I now have the following script running when a dummy switch is clicked:
-- DEVICE INDEX
-- 161 Lightify bulb A60RGBW 01
local OL_BULB_HALL = 161
                OL_BULB_HALL,
        execute = function(domoticz)
        local bulbHall = domoticz.devices[OL_BULB_HALL]
        if (bulbHall.state == 'off') then
                os.execute('~/Device-Osram-Lightify/bin/ol --hub 10.10.10.111 --name="A60RGBW 01" --Off')
        if (bulbHall.state == 'on') then
                os.execute('~/Device-Osram-Lightify/bin/ol --hub 10.10.10.111 --name="A60RGBW 01" --On')
It doesn't return any errors, but it doesn't execute the perl command either. Does anyone know what I'm doring wrong here?
This script gives the following log output when the dummy switch is clicked:
2016-11-01 22:01:15.329 User: Admin initiated a switch command (161/Lightify1/Off)
2016-11-01 22:01:15.486 LUA: Handling events for: "Lightify1", value: "Off"
2016-11-01 22:01:15.486 LUA: =====================================================
2016-11-01 22:01:15.486 LUA: >>> Handler: perl
2016-11-01 22:01:15.486 LUA: >>> Device: "Lightify1" Index: 161
2016-11-01 22:01:15.486 LUA: .....................................................
2016-11-01 22:01:15.503 LUA: .....................................................
2016-11-01 22:01:15.503 LUA: <<< Done
2016-11-01 22:01:15.503 LUA: -----------------------------------------------------
2016-11-01 22:01:15.330 (Dummy switch) Lighting 1 (Lightify1)
2016-11-01 22:01:17.432 User: Admin initiated a switch command (161/Lightify1/On)
2016-11-01 22:01:17.610 LUA: Handling events for: "Lightify1", value: "On"
2016-11-01 22:01:17.610 LUA: =====================================================
2016-11-01 22:01:17.610 LUA: >>> Handler: perl
2016-11-01 22:01:17.611 LUA: >>> Device: "Lightify1" Index: 161
2016-11-01 22:01:17.611 LUA: .....................................................
2016-11-01 22:01:17.633 LUA: .....................................................
2016-11-01 22:01:17.633 LUA: <<< Done
2016-11-01 22:01:17.633 LUA: -----------------------------------------------------
2016-11-01 22:01:17.433 (Dummy switch) Lighting 1 (Lightify1)
dannybloe
Post by dannybloe »
thorbj wrote:I now have the following script running when a dummy switch is clicked:
-- DEVICE INDEX
                OL_BULB_HALL,
Strange. So you are sure that you end up in the if-parts. Could it be that it cannot find the script? Maybe try a relative path from the script's location?
thorbj
Post by thorbj »
I'm pretty sure the if is correct, but I'm no expert in lua/perl/bash etc...
I tried changing to a relative path, but still nothing.
The script, perl.lua:
-- DEVICE INDEX
                OL_BULB_HALL,
if (bulbHall.state == "Off") then
                        os.execute('/home/pi/Device-Osram-Lightify/bin/ol --hub 10.10.10.111 --name="A60RGBW 01" --Off')
                        print("Lys gang av")
if (bulbHall.state == "On") then
                    os.execute('/home/pi/Device-Osram-Lightify/bin/ol --hub 10.10.10.111 --name="A60RGBW 01" --On')
                        print("Lys gang på")
Also it runs twice:
2016-11-02 13:35:41.105 User: Admin initiated a switch command (161/Lightify1/Off)
2016-11-02 13:35:41.225 LUA: Handling events for: "Lightify1", value: "Off"
2016-11-02 13:35:41.225 LUA: =====================================================
2016-11-02 13:35:41.225 LUA: >>> Handler: perl
2016-11-02 13:35:41.225 LUA: >>> Device: "Lightify1" Index: 161
2016-11-02 13:35:41.225 LUA: .....................................................
2016-11-02 13:35:41.263 LUA: Lys gang av
2016-11-02 13:35:41.263 LUA: .....................................................
2016-11-02 13:35:41.264 LUA: <<< Done
2016-11-02 13:35:41.264 LUA: -----------------------------------------------------
2016-11-02 13:35:41.264 LUA: =====================================================
2016-11-02 13:35:41.264 LUA: >>> Handler: perl
2016-11-02 13:35:41.264 LUA: >>> Device: "Lightify1" Index: 161
2016-11-02 13:35:41.264 LUA: .....................................................
2016-11-02 13:35:41.312 LUA: Lys gang av
2016-11-02 13:35:41.312 LUA: .....................................................
2016-11-02 13:35:41.312 LUA: <<< Done
2016-11-02 13:35:41.312 LUA: -----------------------------------------------------
2016-11-02 13:35:41.106 (Dummy switch) Lighting 1 (Lightify1)
EDIT:
I've also made two perl scripts called bulb_off.pl and bulb_on.pl, and two bash scripts called lightify_bulb_on.sh, and lightify_bulb_off.sh. The bash scripts simply calls the perl scripts. They all work in shell.
I tried calling these scripts, both perl and bash, in the lua script instead of the ol --hub.... command. But no result here either.
Perl script bulb_on.pl
#!/usr/bin/perl
use Device::Osram::Lightify::Hub;
my $x = Device::Osram::Lightify::Hub->new( host => "10.10.10.111" );
foreach my $light ( $x->lights() ) {
    if ( $light->name() eq "A60RGBW 01" ) {
        $light->set_on();
        exit(0);
Bash script lightify_bulb_on.sh:
#!/bin/bash
#!/usr/bin/perl
#!/home/pi/Device-Osram-Lightify/bin/ol
perl /home/pi/domoticz/scripts/perl/bulb_on.pl > /dev/null 2>&1 &
echo "lightify_bulb_on finished"; > /dev/null 2>&1 &
As a side note, I have tried running these scripts directly form the switch, this results in a 512 error. Maybe because of perl?
lazara007
Post by lazara007 »
path was wrong, "t" was missing from srcipts (scrips)
   active = true,
   on = { 'wall_switch' },
   execute = function(domoticz, mySwitch)
         if domoticz.devices['wall_switch'].state == 'On' then
            os.execute('/home/pi/domoticz/scripts/limitless_rgb.sh')
            os.execute('/home/pi/domoticz/scripts/limitless_rgb_off.sh')
thorbj
Post by thorbj »
lazara007 wrote:path was wrong, "t" was missing from srcipts (scrips)
   active = true,
Haha, that was embarrassing... Thanks!
